Has anyone been able to use Teensy 3.5 at the 2MHz setting (which enables Very Low Power Run mode)?
I'm having frequent crashes. E.g., the code below often hangs at "SD.begin(chipSelect)". If it doesn't, it will hang at some point later. Things work fine, if I disable VLPR (still running at 2MHz). The same code works on Teensy 3.6 in VLPR mode.
#include <array>
const char* log_file_name = "log.bin";
void blink() {
delay(200);
//SMC_PMCTRL &= ~SMC_PMCTRL_RUNM(0b11); // disable VLPR
elapsedMillis timer;
elapsedMillis timer_sd_write;
pinMode(LED_BUILTIN, OUTPUT);
Serial1.begin(115200);
Serial1.println("Init SD card");
const auto chipSelect = BUILTIN_SDCARD;
if (!SD.begin(chipSelect)) {
Serial1.println("SD init failed.");
return;
Serial1.println("SD init done.");
size_t written_bytes = 0;
SD.remove(log_file_name);
File file = SD.open(log_file_name, FILE_WRITE);
if (!file) {
Serial1.println("Error opening log file.");
return;
size_t non_flushed_writes = 0;
size_t flush_cnt = 0;
uint32_t write_cnt = 0;
while(true) {
if(timer >= 5000) {
timer -= 5000;
blink();
if(timer_sd_write >= 10000) {
timer_sd_write -= 10000;
uint32_t start_time = millis();
static std::array<uint8_t, 16*1024> buffer = {};
file.write(buffer.data(), buffer.size());
written_bytes += buffer.size();
uint32_t end_time = millis();
uint32_t elapsed = end_time - start_time;
Serial1.print(write_cnt); Serial1.print(": ");
Serial1.print(" fsize: "); Serial1.print(written_bytes);
Serial1.print(" write time: ");
Serial1.println(elapsed);
non_flushed_writes++;
write_cnt++;
if(non_flushed_writes >= 20) {
file.flush();
Serial1.print("Flush time: "); Serial1.print(elapsed);
Serial1.print(" Flush count: "); Serial1.println(flush_cnt);
flush_cnt++;
asm volatile ("dsb");
asm volatile ("wfi");
void loop() { blink(); delay(500); }
