Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 26 to 50 of 82
Thread: Teensy 3.6 USB MIDI host development status
  1. #26
    I tested the transmit with 2 different guitar processors both with midi class compliant usb ports and it worked like a charm, i was able to fully read all the date and transmit program change and control change, neither processor listens to real time nor note or anything other than program, control and sysex tho but so far it worked great!
  2. #27
    I did some more testing and i was able to receive and transmit program, control and note on/off using a teensy 3.2 as the device,i didnt send data at crazy speeds i used 2 foot controllers to send data back and forth from the device to the host and vice versa by pressing a footswitch, all and all its working great so far!
  3. #28
    Hi Paul, i tested your latest commit which included transmitting SysEx and retrieving the SysEx array, transmit is working great, i was able to send sysex to my guitar controller and it read them properly, the only issue i'm having is with the Host reading the midi SysEx from my guitar processor.
    I tested it also with a teensy 3.2 sending sysex to the 3.6 and those message are read properly, however any messages from my guitar processor are not.
    The one thing i notice is that my processor sends every byte separately, on the midi.cpp type1 is always 5.
    I'm not very good at describing things so I ran the USBHost_t36 in debug and i copied the output, in this log I'm sending 1 sysex message and my processor reads it perfectly, the processor then sends a couple of messages which you can see below.
    By the way, my mac reads the sysex from my guitar processor perfectly.
    sizeof Device = 36
    sizeof Pipe = 96
    sizeof Transfer = 64
    power up USBHS PHY
    port change: 10001803
    connect
    begin reset
    port change: 10001805
    port enabled
    end recovery
    new_Device: 12 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    enumeration:
    enumeration:
    enumeration:
    enumeration:
    Config data length = 101
    enumeration:
    bNumInterfaces = 2
    bConfigurationValue = 1
    enumeration:
    Descriptor 4 = INTERFACE
    MIDIDevice claim this=1FFF20E0
    len = 92
    Descriptor 36 = ???
    len = 74
    Interface is MIDI
    type: 36, len: 7
    MIDI Header (ignored)
    type: 36, len: 6
    MIDI IN Jack (ignored)
    type: 36, len: 6
    type: 36, len: 9
    MIDI OUT Jack (ignored)
    type: 36, len: 9
    type: 5, len: 9
    MIDI Endpoint: 1
    tx_size = 64
    type: 37, len: 5
    MIDI Endpoint Jack Association (ignored)
    type: 5, len: 9
    MIDI Endpoint: 81
    rx_size = 64
    type: 37, len: 5
    new_Pipe
    new_Pipe
    Descriptor 36 = ???
    Descriptor 36 = ???
    Descriptor 36 = ???
    Descriptor 36 = ???
    Descriptor 36 = ???
    Descriptor 5 = ENDPOINT
    Descriptor 37 = ???
    Descriptor 37 = ???
    MIDIDevice transmit complete
    MIDI Data: 04 F0 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    MIDI Data: 04 01 74 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    MIDI Data: 04 29 00 24 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    MIDI Data: 06 F7 F7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    MIDIDevice Receive
    MIDI Data: 05 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 78
    queue another receive packet
    read: F005
    MIDIDevice Receive
    MIDI Data: 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 78
    read: 5
    MIDIDevice Receive
    MIDI Data: 05 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 78
    read: 105
    MIDIDevice Receive
    MIDI Data: 05 74 00 00 05 08 00 00 05 29 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 75
    read: 7405
    read: 805
    read: 2905
    read: 5
    MIDIDevice Receive
    MIDI Data: 05 24 00 00 05 F7 00 00 05 29 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 77
    read: 2405
    read: F705
    MIDIDevice Receive
    MIDI Data: 05 F0 00 00 05 F7 00 00 05 29 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 78
    read: F005
    MIDIDevice Receive
    MIDI Data: 05 00 00 00 05 F7 00 00 05 29 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 78
    read: 5
    MIDIDevice Receive
    MIDI Data: 05 01 00 00 05 F7 00 00 05 29 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 78
    read: 105
    MIDIDevice Receive
    MIDI Data: 05 74 00 00 05 08 00 00 05 0E 00 00 05 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 75
    read: 7405
    read: 805
    read: E05
    read: 105
    MIDIDevice Receive
    MIDI Data: 05 4C 00 00 05 10 00 00 05 0E 00 00 05 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 77
    read: 4C05
    read: 1005
    MIDIDevice Receive
    MIDI Data: 05 53 00 00 05 06 00 00 05 03 00 00 05 4E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 75
    read: 5305
    read: 605
    read: 305
    read: 4E05
    MIDIDevice Receive
    MIDI Data: 05 18 00 00 05 63 00 00 05 03 00 00 05 4E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 77
    read: 1805
    read: 6305
    MIDIDevice Receive
    MIDI Data: 05 06 00 00 05 03 00 00 05 56 00 00 05 4E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 76
    read: 605
    read: 305
    read: 5605
    MIDIDevice Receive
    MIDI Data: 05 00 00 00 05 24 00 00 05 56 00 00 05 4E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 77
    read: 5
    read: 2405
    MIDIDevice Receive
    MIDI Data: 05 06 00 00 05 02 00 00 05 5E 00 00 05 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 75
    read: 605
    read: 205
    read: 5E05
    read: 2805
    MIDIDevice Receive
    MIDI Data: 05 03 00 00 05 07 00 00 05 5E 00 00 05 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 77
    read: 305
    read: 705
    MIDIDevice Receive
    MIDI Data: 05 02 00 00 05 66 00 00 05 7C 00 00 05 3F 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 74
    read: 205
    read: 6605
    read: 7C05
    read: 3F05
    read: 7805
    MIDIDevice Receive
    MIDI Data: 05 00 00 00 05 66 00 00 05 7C 00 00 05 3F 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 78
    read: 5
    MIDIDevice Receive
    MIDI Data: 05 68 00 00 05 00 00 00 05 1C 00 00 05 3F 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 76
    read: 6805
    read: 5
    read: 1C05
    MIDIDevice Receive
    MIDI Data: 05 78 00 00 05 03 00 00 05 1C 00 00 05 3F 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 77
    read: 7805
    read: 305
    MIDIDevice Receive
    MIDI Data: 05 6A 00 00 05 00 00 00 05 24 00 00 05 78 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 75
    read: 6A05
    read: 5
    read: 2405
    read: 7805
    MIDIDevice Receive
    MIDI Data: 05 02 00 00 05 70 00 00 05 38 00 00 05 78 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 76
    read: 205
    read: 7005
    read: 3805
    MIDIDevice Receive
    MIDI Data: 05 33 00 00 05 07 00 00 05 38 00 00 05 78 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 77
    read: 3305
    read: 705
    MIDIDevice Receive
    MIDI Data: 05 03 00 00 05 42 00 00 05 38 00 00 05 78 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 77
    read: 305
    read: 4205
    MIDIDevice Receive
    MIDI Data: 05 7C 00 00 05 4F 00 00 05 7A 00 00 05 03 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 75
    read: 7C05
    read: 4F05
    read: 7A05
    read: 305
    MIDIDevice Receive
    MIDI Data: 05 0E 00 00 05 7D 00 00 05 47 00 00 05 03 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 76
    read: E05
    read: 7D05
    read: 4705
    MIDIDevice Receive
    MIDI Data: 05 06 00 00 05 02 00 00 05 47 00 00 05 03 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 77
    read: 605
    read: 205
    MIDIDevice Receive
    MIDI Data: 05 16 00 00 05 41 00 00 05 53 00 00 05 07 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 75
    read: 1605
    read: 4105
    read: 5305
    read: 705
    MIDIDevice Receive
    MIDI Data: 05 00 00 00 05 1A 00 00 05 53 00 00 05 07 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 77
    read: 5
    read: 1A05
    MIDIDevice Receive
    MIDI Data: 05 49 00 00 05 1A 00 00 05 53 00 00 05 07 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 78
    read: 4905
    MIDIDevice Receive
    MIDI Data: 05 13 00 00 05 1A 00 00 05 53 00 00 05 07 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 78
    read: 1305
    MIDIDevice Receive
    MIDI Data: 05 78 00 00 05 1A 00 00 05 53 00 00 05 07 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 78
    read: 7805
    MIDIDevice Receive
    MIDI Data: 05 03 00 00 05 26 00 00 05 51 00 00 05 73 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 75
    read: 305
    read: 2605
    read: 5105
    read: 7305
    MIDIDevice Receive
    MIDI Data: 05 06 00 00 05 02 00 00 05 42 00 00 05 73 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 76
    read: 605
    read: 205
    read: 4205
    MIDIDevice Receive
    MIDI Data: 05 01 00 00 05 60 00 00 05 07 00 00 05 73 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 76
    read: 105
    read: 6005
    read: 705
    MIDIDevice Receive
    MIDI Data: 05 F7 00 00 05 F0 00 00 05 00 00 00 05 73 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 76
    read: F705
    read: F005
    read: 5
    MIDIDevice Receive
    MIDI Data: 05 01 00 00 05 F0 00 00 05 00 00 00 05 73 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 78
    read: 105
    MIDIDevice Receive
    MIDI Data: 05 74 00 00 05 08 00 00 05 29 00 00 05 00 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 75
    read: 7405
    read: 805
    read: 2905
    read: 5
    MIDIDevice Receive
    MIDI Data: 05 24 00 00 05 F7 00 00 05 29 00 00 05 00 00 00 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    rx_size = 64
    avail = 77
    read: 2405
    read: F705
  4. #29
    19,703
    Quote Originally Posted by neroroxxx View Post
    That's definitely not USB MIDI class compliant. I'll try to come up with a workaround anyway....
  5. #30
    Hi Paul, thank you for the quick reply, i find it odd because it's supposed to be MIDI class compliant, and also it's strange that my mac reads the messages without any issues using a midi monitor and using the Web MIDI Api on chrome.
    Before you had the USBHost on the 3.6 working with MIDI i was using a 3.2 with a circuits at home usb host shield, i had a similar issue reading sysex from my processor so what i had to do was check each message for an 0xF0 and an 0xF7, If i received an 0xF0 then i would start adding that and any other bytes to the sysex array until i received a 0xF7 at which point the message was complete, then i would ignore any other messages until i got an 0xF0 again, inefficient but it did the job.
    Thank you again for your help!!!
  6. #31
  7. #32
    Paul you truly Rock!
    Yes it works great now, i tested it with my processor and with a teensy 3.2 as well and it's reading all sysexs from both, I'll do some more testing and let you know how it works out :-)
    While I have you here, 2 quick things,
    #1 may i suggest that both the USBHost_t36 and the usbMIDI have the SYSEX_MAX_LEN be at least 255? teensys have enough RAM to where a size like that wouldn't really make a big difference so it would be great if it's that way by default.
    #2 I don't really use github so i have to learn it before i can submit a suggestion to the code but i added a public function to USBHost_t36.h to get the port_state variable, that way i can tell that a usb device is connected and i can try to communicate with it., Could you add something like that to the USB Host?
    this is what i added
    USBHost_t36.h, in the USBHost class public:
    static uint8_t getUsbPortState();
    ehci.cpp
    uint8_t USBHost::getUsbPortState()
    return port_state;
  8. #33
    19,703
    This isn't necessarily a final decision, but the buffer is currently 290 on Teensy 3.1 to 3.6. It's only 60 bytes on the 4 smaller boards.
    You're supposed to be able to just test every device as a boolean, just like "while (!Serial) ;" to wait for the Arduino Serial Monitor. This is built into the base class, so it works for all the host lib's devices.
    There's also functions to query the vendor and product ID numbers, and manufacturer, product and serial number strings. These are also in the base class, so they work on MIDI, keyboards, joystick, etc.
  9. #34
    Ok that's great to know, i was able to get it all working, thank you so much for all your work and your help!
  10. #35
    19,703
    I rolled all the MIDI changes up in a beta installer.
    https://forum.pjrc.com/threads/49078...no-1-41-Beta-3
  11. #36
    Paul on USBHost_t36 on the midi.cpp looks like there's a typo on line 394, the note on msg_type should be 0x90 and off should be 0x80 but looks like they are 0x9 and 0x8 respectively.
  12. #37
    19,703
    Thanks. Fixed that and some other minor issues, and added more examples.
  13. #38
    Mar 2014
    New Ulm, Mn
    21
    Hey... I'm just catching up here...
    Just to say... regarding the Interface 16x16 example code and a note therein about a "real" application...
    Uhm... I need this as a musician... just the way it is... because it's the software and hardware at each end of the "cables" where the work gets done.
    This solves a real need I have with connecting 2 music workstations together just using usb alone. Let you know if there's any issues.
  14. #39
    Feb 2018
    7
    hi
    i am trying to connect a Roland VT-3 voice transformer to the teensy 3.6 using USBHost_t36 , but I am not getting any luck, running in debug mode I get, the following, it doesnt look good to me, can anyone comment?
    Paul
    sizeof Device = 36
    sizeof Pipe = 96
    power up USBHS PHY
    connect
    begin reset
    port change: 18001205
    port enabled
    end recovery
    new_Device: 480 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    enumeration:
    enumeration:
    enumeration:
    enumeration:
    Config data length = 176
    enumeration:
    bNumInterfaces = 4
    enumeration:
    USBHub memory usage = 960
    USBHub claim_device this=1FFF26E0
    USBHub claim_device this=1FFF2AA0
    MIDIDevice claim this=1FFF2020
    len = 167
    len = 158
    Descriptor 36 = ???
    len = 143
    Descriptor 36 = ???
    Descriptor 36 = ???
    Descriptor 37 = ???
    len = 102
    len = 93
    Descriptor 36 = ???
    Descriptor 36 = ???
    Descriptor 37 = ???
    len = 52
    Descriptor 36 = ???
    len = 23
  15. #40
    The roland site says the usb port is for audio doesnt say its for midi, when u connect it to your computer does it show up as a midi device?
  16. #41
    I believe the Roland devices use proprietary drivers (they aren't class compliant) so you won't be able to use them with this host implementation
  17. #42
    Feb 2018
    7
    Thanks, I thought this may be the case, it is definitely midi, but I guess also audio, shame was hoping to use the Teensy, I will have to put a raspberry pi in to control it, like I did the last time.
  18. #43
    19,703
    Does the Pi have a driver for the special MIDI this device uses?
  19. #44
    Feb 2018
    7
    I don’t think so, as I remember I just plugged it in and it worked
  20. #45
    19,703
    Then there's a good chance this can work. The MIDI host code is still pretty new. There may just be some subtle difference.
    We're going to need to capture the complete config descriptor....
  21. #46
    Feb 2018
    7
    Ok, how would I get this? Unfortunately it’s at work so won’t be able to get it sorted until Monday
  22. #47
    Feb 2018
    7
    well ive got the device descriptor using Thesycon USB descriptor tool as follows is this any help thanks
    Paul
    Information for device VT-3 (VID=0x0582 PID=0x017A):
    Connection Information:
    Device current bus speed: HighSpeed
    Device supports USB 1.1 specification
    Device supports USB 2.0 specification
    Device address: 0x0005
    Current configuration value: 0x01
    Number of open pipes: 2
    Device Descriptor:
    0x12 bLength
    0x01 bDescriptorType
    0x0200 bcdUSB
    0xFF bDeviceClass (Vendor specific)
    0x00 bDeviceSubClass
    0xFF bDeviceProtocol
    0x40 bMaxPacketSize0 (64 bytes)
    0x0582 idVendor
    0x017A idProduct
    0x0100 bcdDevice
    0x01 iManufacturer "Roland"
    0x02 iProduct "VT-3"
    0x00 iSerialNumber
    0x01 bNumConfigurations
    Device Qualifier Descriptor:
    0x0A bLength
    0x06 bDescriptorType
    0x0200 bcdUSB
    0x00 bReserved
    Configuration Descriptor:
    0x09 bLength
    0x02 bDescriptorType
    0x00B0 wTotalLength (176 bytes)
    0x04 bNumInterfaces
    0x01 bConfigurationValue
    0x00 iConfiguration
    0x80 bmAttributes (Bus-powered Device)
    0xFA bMaxPower (500 mA)
    Interface Descriptor:
    0x09 bLength
    0x04 bDescriptorType
    0x00 bInterfaceNumber
    0x00 bAlternateSetting
    0x00 bNumEndPoints
    0xFF bInterfaceClass (Vendor specific)
    0xFF bInterfaceSubClass
    0x00 bInterfaceProtocol
    0x00 iInterface
    0x09 bLength
    0x01 bInterfaceNumber
    0x00 bNumEndPoints
    0x02 bInterfaceSubClass
    0x02 bInterfaceProtocol
    0x00 iInterface
    Unknown Descriptor:
    0x06 bLength
    0x24 bDescriptorType
    Hex dump:
    0x06 0x24 0xF1 0x01 0x00 0x00
    0x09 bLength
    0x01 bAlternateSetting
    0x01 bNumEndPoints
    0x00 iInterface
    Unknown Descriptor:
    0x07 bLength
    Hex dump:
    0x07 0x24 0x01 0x01 0x00 0x01 0x00
    Unknown Descriptor:
    0x0B bLength
    Hex dump:
    0x0B 0x24 0x02 0x01 0x02 0x04 0x18 0x01 0x00 0x77
    0x01
    Endpoint Descriptor:
    0x07 bLength
    0x05 bDescriptorType
    0x0D bEndpointAddress (OUT endpoint 13)
    0x05 bmAttributes (Transfer: Isochronous / Synch: Asynchronous / Usage: Data)
    0x0070 wMaxPacketSize (1 x 112 bytes)
    0x01 bInterval
    Unknown Descriptor:
    0x07 bLength
    0x25 bDescriptorType
    Hex dump:
    0x07 0x25 0x01 0x00 0x00 0x00 0x00
    0x09 bLength
    0x02 bInterfaceNumber
    0x00 bNumEndPoints
    0x01 bInterfaceProtocol
    0x00 iInterface
    0x09 bLength
    0x01 bNumEndPoints
    0x00 iInterface
    Unknown Descriptor:
    0x07 bLength
    Hex dump:
    0x07 0x24 0x01 0x07 0x00 0x01 0x00
    Unknown Descriptor:
    0x0B bLength
    Hex dump:
    0x0B 0x24 0x02 0x01 0x04 0x04 0x18 0x01 0x00 0x77
    0x01
    0x07 bLength
    0x8E bEndpointAddress (IN endpoint 14)
    0x25 bmAttributes (Transfer: Isochronous / Synch: Asynchronous / Usage: Implicit)
    0x00E0 wMaxPacketSize (1 x 224 bytes)
    0x01 bInterval
    Unknown Descriptor:
    0x07 bLength
    Hex dump:
    0x09 bLength
    0x03 bInterfaceNumber
    0x02 bNumEndPoints
    0x03 bInterfaceSubClass
    0x00 iInterface
    Unknown Descriptor:
    0x06 bLength
    Hex dump:
    0x06 0x24 0xF1 0x02 0x01 0x01
    0x07 bLength
    0x03 bEndpointAddress (OUT endpoint 3)
    0x02 bmAttributes (Transfer: Bulk / Synch: None / Usage: Data)
    0x0200 wMaxPacketSize (512 bytes)
    0x01 bInterval
    0x07 bLength
    0x84 bEndpointAddress (IN endpoint 4)
    0x00 bInterval
    0x09 bLength
    0x02 bNumEndPoints
    0x00 iInterface
    0x07 bLength
    0x03 bmAttributes (Transfer: Interrupt / Synch: None / Usage: Data)
    0x0200 wMaxPacketSize (1 x 512 bytes)
    0x01 bInterval
    0x07 bLength
    0x85 bEndpointAddress (IN endpoint 5)
    0x01 bInterval
    Other Speed Configuration Descriptor:
    0x09 bLength
    0x07 bDescriptorType
    0x002D wTotalLength (45 bytes)
    0x04 bNumInterfaces
    0x00 iConfiguration
    0x09 bLength
    0x00 bNumEndPoints
    0x00 iInterface
    0x09 bLength
    0x00 bNumEndPoints
    0x00 iInterface
    0x09 bLength
    0x00 bNumEndPoints
    0x00 iInterface
    0x09 bLength
    0x00 bNumEndPoints
    0x00 iInterface
    Microsoft OS Descriptor is not available. Error code: 0x0000001F
    String Descriptor Table
    Index LANGID String
    0x00 0x0000 0x0409
    0x01 0x0409 "Roland"
    0x02 0x0409 "VT-3"
    Connection path for device:
    Intel(R) 8 Series/C220 Series USB EHCI #2 - 8C2D
    Root Hub
    Generic USB Hub
    Generic USB Hub
    VT-3 (VID=0x0582 PID=0x017A) Port: 1
    Running on: Windows 8.1
    Brought to you by TDD v2.10.0, Feb 2 2018, 10:25:51
  23. #48
    19,703
    I'm sad to say, this part means it is certainly not a "class compliant" MIDI device.
    This thing has a lot of interface descriptors too. Every single one of them also has this.
    If it were a class compliant interface within a non-compliant device, we could just add a quick hack to detect it. But sadly, it seems everything about this device is "Vendor specific" interfaces and protocols.
    To get this working, someone would need to write a driver within USBHost_t36. If there's a driver within the Linux kernel, that could be a good shortcut to leaning the necessary info, but of course the code isn't portable to USBHost_t36. A driver would need to be crafted pretty much from scratch from the info in Linux (or any other source, if there is any other public info....)
  24. #49
    Feb 2018
    7
    ok, thanks for looking, back to the drawing board
    Paul
  25. #50
    I have a Beagle USB protocol analyzer and Roland TB-3, TR-8, MX-1 (no VT-3 unfortunately) if it may help to identify if one of the vendor specific interfaces uses standard USB MIDI packets in some way...
