Hi.
So my new Audio Shield is assembled and mounted on Teensy 3.2. The 'WavFilePlayer' example code plays perfectly using the example files here:
https://www.pjrc.com/teensy/td_libs_AudioDataFiles.html
But, the attached file won't play (had to zip it to make uploader happy). Don't know if it's the bit rate or some formatting problem. As a guess, I tried using the Raw player. That didn't work either. Would appreciate any advice on converting it to a format that will play.
Thanks.
Thanks.
