Constantly changing serial port number?
shawn
The Teensy 3.2 I've been working with now changes its serial port number every time I upload new code. This is a fairly recent development. What could be the cause? Both the Arduino IDE and PlatformIO have trouble with this because they can't reuse the existing serial port window. My platform is the latest OSX with a 2.5-year-old MacBook Air.
Definitely not happening here on my Macbook Air (early 2015 model) running Sierra 10.12.4.
Before uploading:
After several uploads, same port:
the changing portnumber only happen in my applications if i use another teensy.
At this time i have used more than 90 teensy in my projects - every new teensy is a new com device.
With the same this behavior is unknown to me.
Ps.: My Os is Win7
@ Franky_74 This is standard Windows behavior. Whenever you add a device with a new serial number it assigns a new COM port. Couple of years ago we had massive issues in production due to that. Changing a registry setting finally fixed it. Google for "IgnoreHWSerNum"
That's exactly the way Microsoft and Apple designed their systems. Each Teensy is supposed to get its own unique COM port number (Windows) or device name (Mac). When you plug in a new Teensy, you get a new number. But the number is supposed to remain the same for each Teensy. If you plug the original Teensy in again, it's supposed to have the same number it did earlier. If you use 90 different boards, you get 90 numbers. If you plug each one in twice, you should *not* get 180 numbers. Each is supposed to retain the same number every time you plug it back in.
Mac and Windows both use the USB serial number to accomplish this. Every Teensy 3.x and LC has a unique serial number.
If you edit the USB code, in usb_desc.c, you can change the serial number to anything you like. You could set it to a constant, for example. Then your PC would believe it's seeing the exact same Teensy.
Same thing has just started happening to me. I've been using a number of teensy 3.6's and uploaded code and to date, I've only had to change serial port when changing the teensy.
However today, everytime I upload code to the same Teensy, it increments the serial port to the next one and I have to find it and reconnect to it. Osx Sierra, Arduino 1.8.5.
Also happens when I power cycle the teensy too.
Please give the latest beta version a try. It has new (hopefully improved) handling of port detection and a redesigned serial monitor which natively connects to the port (not using Java).
https://forum.pjrc.com/threads/50254-Teensyduino-1-42-Beta-3
When you use this, you should see the port twice in the Ports menu. The "Teensy" section is the native access, and the "Serial" section is the old Java-based stuff. Select it from the new part.
In this new version, we're able to collect a lot more info in Teensy Loader's Help > Verbose Info window. If things still are going awry, please open the verbose info window and use the Log menu to save all the message to a text file. Then you can post the file here (use "Go Advanced" to get the forum's editor that lets you attach a file to your message).
I'd really like to get to the bottom of this strange Mac problem, so I really hope you'll have a little time to use the beta version and capture that log file (and maybe redo a few times as we try to figure out what's really happening and come up with a fix).
So before upgrading, I verified it was still happening (1.41 Teensy loader BTW), also quit Arduino IDE and Teensy Loader and restarted them, again still happening.
Upgraded to 1.42 Beta 3 and set to the "Teensy" Port. Port still increments on every upload, however the difference now is Serial Monitor keeps track of the port change and I don't have to manually reselect the port each time, which is great.
Here's the verbose log across 2 uploads with the same device without disconnecting anything showing the port increment happening:
-- Previous Port --
08:11:56.081 (ports 5): Serial add callback
08:11:56.082 (ports 5):   name=/dev/cu.usbmodem423, loc=230000, vid=16c0, pid=0483, ver=0200
08:11:56.082 (ports 5):   found prior teensy at this loc, age=0.224
08:11:56.082 (ports 5):     name: /dev/cu.usbmodem423 (Teensy 3.6) Serial
08:39:27.167 (ports 5): got command: “list”
— Upload Pressed —
08:39:29.023 (post_compile 1): Begin, version=1.42-beta3
08:39:29.408 (loader): Teensy Loader 1.42-beta3, begin program
08:39:29.515 (loader): File "Test.ino.hex". 130812 bytes, 12% used
08:39:29.518 (loader): Listening for remote control on port 3149
08:39:29.518 (loader): initialized, showing main window
08:39:29.591 (loader): remote connection 9 opened
08:39:29.592 (post_compile 1): Sending command: comment: Teensyduino 1.42-beta3 - MACOSX (teensy_post_compile)
08:39:29.593 (loader): remote cmd from 9: "comment: Teensyduino 1.42-beta3 - MACOSX (teensy_post_compile)"
08:39:29.594 (loader): remote cmd from 9: "status"
08:39:29.607 (loader): HID/macos: no devices found
08:39:29.608 (post_compile 1): Status: 1, 0, 0, 0, 0, 0, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:29.608 (post_compile 1): Sending command: auto:on
08:39:29.608 (loader): remote cmd from 9: "auto:on"
08:39:29.609 (post_compile 1): Disconnect
08:39:29.623 (loader): remote connection 9 closed
08:39:29.629 (ports 5): got command: "list"
08:39:29.645 (post_compile 2): Begin, version=1.42-beta3
08:39:29.645 (loader): remote connection 9 opened
08:39:29.645 (post_compile 2): Sending command: comment: Teensyduino 1.42-beta3 - MACOSX (teensy_post_compile)
08:39:29.645 (loader): remote cmd from 9: "comment: Teensyduino 1.42-beta3 - MACOSX (teensy_post_compile)"
08:39:29.646 (loader): remote cmd from 9: "status"
08:39:29.646 (post_compile 2): Status: 1, 1, 0, 0, 0, 0, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:29.646 (post_compile 2): Disconnect
08:39:29.656 (post_compile 3): Running teensy_reboot: /Applications/Arduino185_Teensy3.6.app/Contents/Java/hardware/teensy/../tools/teensy_reboot
08:39:29.656 (loader): remote connection 9 closed
08:39:29.656 (loader): remote connection 9 opened
08:39:29.657 (loader): remote connection 9 closed
08:39:29.659 (reboot 4): Begin, version=1.42-beta3
08:39:29.659 (reboot 4): location = usb:230000
08:39:29.659 (reboot 4): Only location usb:230000 will be tried
08:39:29.659 (reboot 4): portlabel = HID=16c0:0478.ff9c.22 (Teensy 3.6) Bootloader
08:39:29.659 (reboot 4): portprotocol = Teensy
08:39:29.659 (reboot 4): USB device add callback
08:39:29.659 (reboot 4):   loc=230000, vid=16C0, pid=0483, ver=0200, ser=3251340
08:39:29.659 (reboot 4):   actual serailnum=325134
08:39:29.661 (loader): remote connection 9 opened
08:39:29.661 (reboot 4): USB device remove callback
08:39:29.661 (reboot 4): Serial add callback
08:39:29.662 (reboot 4):   name=/dev/cu.usbmodem423, loc=230000, vid=16c0, pid=0483, ver=0200
08:39:29.677 (reboot 4): Serial remove callback
08:39:29.680 (reboot 4): HID Manager started
08:39:29.681 (reboot 4): found Teensy Loader, version 1.42
08:39:29.681 (reboot 4): Sending command: show:arduino_attempt_reboot
08:39:29.681 (loader): remote cmd from 9: "show:arduino_attempt_reboot"
08:39:29.681 (loader): got request to show arduino rebooting message
08:39:29.682 (reboot 4): Sending command: comment: Teensyduino 1.42-beta3 - MACOSX (teensy_reboot)
08:39:29.691 (loader): remote cmd from 9: "comment: Teensyduino 1.42-beta3 - MACOSX (teensy_reboot)"
08:39:29.691 (loader): remote cmd from 9: "status"
08:39:29.691 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:29.691 (reboot 4): do_reset (serial) /dev/cu.usbmodem423
08:39:29.693 (loader): remote cmd from 9: "status"
08:39:29.693 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:29.693 (reboot 4): status read, retry 0
08:39:29.794 (loader): remote cmd from 9: "status"
08:39:29.794 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:29.794 (reboot 4): status read, retry 1
08:39:29.898 (loader): remote cmd from 9: "status"
08:39:29.899 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:29.899 (reboot 4): status read, retry 2
08:39:30.002 (loader): remote cmd from 9: "status"
08:39:30.003 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:30.003 (reboot 4): status read, retry 3
08:39:30.008 (ports 5): Serial remove callback
08:39:30.008 (ports 5): USB device remove callback
08:39:30.008 (ports 5): remove, loc=230000
08:39:30.008 (ports 5): usb_remove: usb:230000
08:39:30.008 (ports 5): del device: location=230000
08:39:30.010 (ports 5): USB device add callback
08:39:30.010 (ports 5):   loc=230000, vid=16C0, pid=0478, ver=0103, ser=0004F60E
08:39:30.010 (ports 5):   actual serailnum=325134
08:39:30.010 (ports 5):   found prior teensy at this loc, age=0.002
08:39:30.010 (ports 5):     name: [no_device] (Teensy 3.6) Bootloader
08:39:30.013 (loader): remote connection 10 opened
08:39:30.028 (ports 5): HID add callback, vid=16c0, pid=0478, ver=0103, loc=230000, use=ff9c:22
08:39:30.028 (ports 5):   found prior teensy at this loc, age=0.018
08:39:30.028 (ports 5):     name: HID=16c0:0478.ff9c.22 (Teensy 3.6) Bootloader
08:39:30.029 (loader): HID/macos: attach callback
08:39:30.106 (loader): remote cmd from 9: "status"
08:39:30.107 (loader): Device came online, code_size = 1048576
08:39:30.107 (loader): Board is: Teensy 3.6 (MK66FX1M0), version 1.03
08:39:30.129 (loader): File "Test.ino.hex". 130812 bytes, 12% used
08:39:30.130 (loader): set background IMG_ONLINE
08:39:30.153 (loader): File "Test.ino.hex". 130812 bytes, 12% used
08:39:30.155 (loader): elf size appears to be 1048576
08:39:30.155 (loader): elf binary data matches hex file
08:39:30.155 (loader): Code size from .elf file = 1048576
08:39:30.155 (loader): begin operation
08:39:30.169 (reboot 4): Status: 1, 1, 1, 1, 0, 1, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:30.203 (loader): flash, block=0, bs=1024, auto=1
08:39:30.205 (loader): flash, block=1, bs=1024, auto=1
08:39:30.206 (loader): flash, block=2, bs=1024, auto=1
08:39:30.217 (loader): flash, block=3, bs=1024, auto=1
08:39:30.507 (loader): remote cmd from 9: "status"
08:39:30.508 (reboot 4): Status: 1, 1, 1, 1, 0, 1, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:30.513 (loader): flash, block=4, bs=1024, auto=1
08:39:30.515 (loader): flash, block=5, bs=1024, auto=1
08:39:30.521 (loader): flash, block=6, bs=1024, auto=1
08:39:30.523 (loader): flash, block=7, bs=1024, auto=1
08:39:30.541 (loader): flash, block=8, bs=1024, auto=1
08:39:30.543 (loader): flash, block=9, bs=1024, auto=1
08:39:30.560 (loader): flash, block=10, bs=1024, auto=1
08:39:30.562 (loader): remote cmd from 9: "status"
08:39:30.562 (reboot 4): Status: 1, 1, 1, 1, 0, 1, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:30.562 (loader): flash, block=11, bs=1024, auto=1
08:39:30.564 (loader): flash, block=12, bs=1024, auto=1
08:39:30.582 (loader): flash, block=13, bs=1024, auto=1
08:39:30.584 (loader): flash, block=14, bs=1024, auto=1
08:39:30.601 (loader): flash, block=15, bs=1024, auto=1
08:39:30.603 (loader): flash, block=16, bs=1024, auto=1
08:39:30.621 (loader): remote cmd from 9: "status"
08:39:30.621 (reboot 4): Status: 1, 1, 1, 1, 0, 1, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:30.622 (loader): flash, block=17, bs=1024, auto=1
08:39:30.623 (loader): flash, block=18, bs=1024, auto=1
08:39:30.625 (loader): flash, block=19, bs=1024, auto=1
08:39:30.642 (loader): flash, block=20, bs=1024, auto=1
08:39:30.644 (loader): flash, block=21, bs=1024, auto=1
08:39:30.661 (loader): flash, block=22, bs=1024, auto=1
08:39:30.663 (loader): flash, block=23, bs=1024, auto=1
08:39:30.680 (loader): remote cmd from 9: "status"
08:39:30.680 (reboot 4): Status: 1, 1, 1, 1, 0, 1, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:30.680 (loader): flash, block=24, bs=1024, auto=1
08:39:30.682 (loader): flash, block=25, bs=1024, auto=1
08:39:30.700 (loader): flash, block=26, bs=1024, auto=1
08:39:30.702 (loader): flash, block=27, bs=1024, auto=1
08:39:30.704 (loader): flash, block=28, bs=1024, auto=1
08:39:30.722 (loader): flash, block=29, bs=1024, auto=1
08:39:30.723 (loader): flash, block=30, bs=1024, auto=1
08:39:30.742 (loader): remote cmd from 9: "status"
08:39:30.742 (reboot 4): Status: 1, 1, 1, 1, 0, 1, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:30.742 (loader): flash, block=31, bs=1024, auto=1
08:39:30.743 (loader): flash, block=32, bs=1024, auto=1
08:39:30.745 (loader): flash, block=33, bs=1024, auto=1
08:39:30.763 (loader): flash, block=34, bs=1024, auto=1
08:39:30.765 (loader): flash, block=35, bs=1024, auto=1
08:39:30.783 (loader): flash, block=36, bs=1024, auto=1
08:39:30.784 (loader): flash, block=37, bs=1024, auto=1
08:39:30.795 (reboot 4): status read, retry 4
08:39:30.795 (reboot 4): Success
08:39:30.795 (reboot 4): Disconnect
08:39:30.802 (loader): flash, block=38, bs=1024, auto=1
08:39:30.803 (loader): flash, block=39, bs=1024, auto=1
08:39:30.805 (loader): flash, block=40, bs=1024, auto=1
08:39:30.809 (ports 5): got command: "list"
08:39:30.815 (serialmon 6): Begin, version=1.42-beta3
08:39:30.815 (serialmon 6): teensy_serialmon, loc = usb:230000
08:39:30.815 (serialmon 6): USB device add callback
08:39:30.815 (serialmon 6):   loc=230000, vid=16C0, pid=0478, ver=0103, ser=0004F60E
08:39:30.815 (serialmon 6):   actual serailnum=325134
08:39:30.939 (loader): remote connection 11 opened
08:39:30.939 (serialmon 6): USB device remove callback
08:39:30.939 (serialmon 6): Serial add callback
08:39:30.940 (loader): remote connection 9 closed
08:39:30.940 (loader): flash, block=41, bs=1024, auto=1
08:39:30.951 (loader): flash, block=42, bs=1024, auto=1
08:39:30.953 (loader): flash, block=43, bs=1024, auto=1
08:39:30.955 (loader): flash, block=44, bs=1024, auto=1
08:39:30.955 (serialmon 6): Serial remove callback
08:39:30.956 (loader): flash, block=45, bs=1024, auto=1
08:39:30.959 (serialmon 6): HID Manager started
08:39:30.960 (serialmon 6): HID add callback, vid=16c0, pid=0478, ver=0103, loc=230000, use=ff9c:22
08:39:30.972 (loader): flash, block=46, bs=1024, auto=1
08:39:30.974 (loader): flash, block=47, bs=1024, auto=1
08:39:30.988 (loader): flash, block=48, bs=1024, auto=1
08:39:30.990 (loader): flash, block=49, bs=1024, auto=1
08:39:31.693 (loader): flash, block=126, bs=1024, auto=1
08:39:31.705 (loader): flash, block=127, bs=1024, auto=1
08:39:31.721 (loader): sending reboot
08:39:31.722 (loader): begin wait_until_offline
08:39:31.722 (loader): HID/macos: status: ok
08:39:32.045 (ports 5): HID remove callback
08:39:32.045 (ports 5): HID add callback, vid=16c0, pid=0478, ver=0103, loc=230000
08:39:32.045 (serialmon 6): HID remove callback
08:39:32.045 (serialmon 6): HID add callback, vid=16c0, pid=0478, ver=0103, loc=230000
08:39:32.045 (ports 5): USB device remove callback
08:39:32.045 (serialmon 6): USB device remove callback
08:39:32.045 (ports 5): remove, loc=230000
08:39:32.045 (ports 5): usb_remove: usb:230000
08:39:32.045 (ports 5): del device: location=230000
08:39:32.045 (serialmon 6): remove, loc=230000
08:39:32.045 (serialmon 6): del device: location=230000
08:39:32.047 (ports 5): USB device add callback
08:39:32.047 (serialmon 6): USB device add callback
08:39:32.047 (ports 5):   loc=230000, vid=16C0, pid=0483, ver=0200, ser=3251340
08:39:32.047 (ports 5):   actual serailnum=325134
08:39:32.047 (ports 5):   found prior teensy at this loc, age=0.002
08:39:32.047 (ports 5):     name: [no_device] (Teensy 3.6) Serial
08:39:32.047 (serialmon 6):   loc=230000, vid=16C0, pid=0483, ver=0200, ser=3251340
08:39:32.047 (serialmon 6):   actual serailnum=325134
08:39:32.082 (loader): HID/macos: detach callback: is currently open device
08:39:32.085 (loader): offline, waited 7
08:39:32.085 (loader): end operation, total time = 1.930 seconds
08:39:32.086 (loader): set background IMG_REBOOT_OK
08:39:32.088 (loader): redraw timer set, image 14 to show for 1200 ms
08:39:32.267 (loader): HID/macos: number of devices found = 0
08:39:32.267 (loader): HID/macos: no devices found (empty set)
08:39:32.552 (serialmon 6): Serial add callback
08:39:32.552 (ports 5): Serial add callback
08:39:32.552 (serialmon 6):   name=/dev/cu.usbmodem424, loc=230000, vid=16c0, pid=0483, ver=0200
08:39:32.552 (ports 5):   name=/dev/cu.usbmodem424, loc=230000, vid=16c0, pid=0483, ver=0200
08:39:32.552 (ports 5):   found prior teensy at this loc, age=0.505
08:39:32.552 (ports 5):     name: /dev/cu.usbmodem424 (Teensy 3.6) Serial
08:39:32.625 (serialmon 6): Opened /dev/cu.usbmodem424 Serial
08:39:32.625 (serialmon 6): Open required 4 attempts
08:39:33.288 (loader): redraw, image 9
08:39:34.306 (loader): Verbose Info event
— Port is now 424 --
08:39:45.493 (ports 5): got command: "list"
08:39:52.136 (ports 5): got command: "list"
— Upload pressed again --
08:39:52.137 (loader): remote connection 11 closed
08:39:53.015 (loader): file changed
08:39:53.048 (loader): File "Test.ino.hex". 130812 bytes, 12% used
08:39:53.839 (post_compile 7): Begin, version=1.42-beta3
08:39:53.840 (loader): remote connection 11 opened
08:39:53.842 (post_compile 7): Sending command: comment: Teensyduino 1.42-beta3 - MACOSX (teensy_post_compile)
08:39:53.848 (loader): remote cmd from 11: "comment: Teensyduino 1.42-beta3 - MACOSX (teensy_post_compile)"
08:39:53.892 (loader): remote cmd from 11: "status"
08:39:53.925 (post_compile 7): Status: 1, 1, 0, 1, 0, 0, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:53.925 (post_compile 7): Disconnect
08:39:53.944 (ports 5): got command: "list"
08:39:53.960 (post_compile 8): Begin, version=1.42-beta3
08:39:53.998 (loader): remote connection 14 opened
08:39:54.018 (post_compile 8): Sending command: comment: Teensyduino 1.42-beta3 - MACOSX (teensy_post_compile)
08:39:54.025 (loader): remote connection 11 closed
08:39:54.047 (loader): remote cmd from 14: "comment: Teensyduino 1.42-beta3 - MACOSX (teensy_post_compile)"
08:39:54.093 (loader): remote cmd from 14: "status"
08:39:54.121 (post_compile 8): Status: 1, 1, 0, 1, 0, 0, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:54.121 (post_compile 8): Disconnect
08:39:54.132 (post_compile 9): Running teensy_reboot: /Applications/Arduino185_Teensy3.6.app/Contents/Java/hardware/teensy/../tools/teensy_reboot
08:39:54.198 (loader): remote connection 11 opened
08:39:54.222 (reboot 10): Begin, version=1.42-beta3
08:39:54.222 (reboot 10): location = usb:230000
08:39:54.222 (reboot 10): portlabel = HID=16c0:0478.ff9c.22 (Teensy 3.6) Bootloader
08:39:54.222 (reboot 10): portprotocol = Teensy
08:39:54.222 (reboot 10): Only location usb:230000 will be tried
08:39:54.222 (reboot 10): USB device add callback
08:39:54.222 (reboot 10):   loc=230000, vid=16C0, pid=0483, ver=0200, ser=3251340
08:39:54.222 (reboot 10):   actual serailnum=325134
08:39:54.233 (loader): remote connection 15 opened
08:39:54.251 (reboot 10): USB device remove callback
08:39:54.252 (reboot 10): Serial add callback
08:39:54.252 (reboot 10):   name=/dev/cu.usbmodem424, loc=230000, vid=16c0, pid=0483, ver=0200
08:39:54.259 (loader): remote connection 11 closed
08:39:54.259 (loader): remote connection 14 closed
08:39:54.267 (reboot 10): Serial remove callback
08:39:54.271 (reboot 10): HID Manager started
08:39:54.271 (reboot 10): found Teensy Loader, version 1.42
08:39:54.271 (reboot 10): Sending command: show:arduino_attempt_reboot
08:39:54.329 (loader): remote cmd from 15: "show:arduino_attempt_reboot"
08:39:54.339 (loader): got request to show arduino rebooting message
08:39:54.343 (reboot 10): Sending command: comment: Teensyduino 1.42-beta3 - MACOSX (teensy_reboot)
08:39:54.357 (loader): remote cmd from 15: "comment: Teensyduino 1.42-beta3 - MACOSX (teensy_reboot)"
08:39:54.393 (loader): remote cmd from 15: "status"
08:39:54.415 (reboot 10): Status: 1, 1, 0, 1, 0, 0, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:54.415 (reboot 10): do_reset (serial) /dev/cu.usbmodem424
08:39:54.417 (loader): remote cmd from 15: "status"
08:39:54.455 (reboot 10): Status: 1, 1, 0, 1, 0, 0, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:54.455 (reboot 10): status read, retry 0
08:39:54.559 (loader): remote cmd from 15: "status"
08:39:54.578 (reboot 10): Status: 1, 1, 0, 1, 0, 0, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:54.578 (reboot 10): status read, retry 1
08:39:54.681 (loader): remote cmd from 15: "status"
08:39:54.691 (reboot 10): Status: 1, 1, 0, 1, 0, 0, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:54.691 (reboot 10): status read, retry 2
08:39:54.711 (ports 5): Serial remove callback
08:39:54.711 (ports 5): USB device remove callback
08:39:54.712 (ports 5): remove, loc=230000
08:39:54.712 (ports 5): usb_remove: usb:230000
08:39:54.712 (ports 5): del device: location=230000
08:39:54.714 (ports 5): USB device add callback
08:39:54.714 (ports 5):   loc=230000, vid=16C0, pid=0478, ver=0103, ser=0004F60E
08:39:54.714 (ports 5):   actual serailnum=325134
08:39:54.714 (ports 5):   found prior teensy at this loc, age=0.002
08:39:54.714 (ports 5):     name: [no_device] (Teensy 3.6) Bootloader
08:39:54.735 (ports 5): HID add callback, vid=16c0, pid=0478, ver=0103, loc=230000, use=ff9c:22
08:39:54.735 (ports 5):   found prior teensy at this loc, age=0.021
08:39:54.735 (ports 5):     name: HID=16c0:0478.ff9c.22 (Teensy 3.6) Bootloader
08:39:54.806 (loader): remote cmd from 15: "status"
08:39:54.841 (loader): HID/macos: attach callback
08:39:54.872 (loader): Device came online, code_size = 1048576
08:39:54.875 (loader): Board is: Teensy 3.6 (MK66FX1M0), version 1.03
08:39:54.899 (loader): File "Test.ino.hex". 130812 bytes, 12% used
08:39:54.902 (loader): set background IMG_ONLINE
08:39:54.929 (loader): File "Test.ino.hex". 130812 bytes, 12% used
08:39:54.935 (loader): elf size appears to be 1048576
08:39:54.937 (loader): elf binary data matches hex file
08:39:54.939 (loader): Code size from .elf file = 1048576
08:39:54.941 (loader): begin operation
08:39:54.948 (reboot 10): Status: 1, 1, 1, 2, 0, 1, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:55.006 (loader): remote cmd from 15: "status"
08:39:55.019 (reboot 10): Status: 1, 1, 1, 2, 0, 1, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:55.041 (loader): flash, block=0, bs=1024, auto=1
08:39:55.059 (loader): flash, block=1, bs=1024, auto=1
08:39:55.104 (loader): remote cmd from 15: "status"
08:39:55.118 (reboot 10): Status: 1, 1, 1, 2, 0, 1, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:55.141 (loader): flash, block=2, bs=1024, auto=1
08:39:55.173 (loader): flash, block=3, bs=1024, auto=1
08:39:55.355 (loader): remote cmd from 15: "status"
08:39:55.374 (reboot 10): Status: 1, 1, 1, 2, 0, 1, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:55.390 (loader): flash, block=4, bs=1024, auto=1
08:39:55.423 (loader): flash, block=5, bs=1024, auto=1
08:39:55.463 (loader): remote cmd from 15: "status"
08:39:55.475 (reboot 10): Status: 1, 1, 1, 2, 0, 1, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:55.495 (loader): flash, block=6, bs=1024, auto=1
08:39:55.522 (loader): flash, block=7, bs=1024, auto=1
08:39:55.574 (loader): remote cmd from 15: "status"
08:39:55.576 (reboot 10): Status: 1, 1, 1, 2, 0, 1, /var/folders/55/70rwhwm92410110v5fy13skm0000gn/T/arduino_build_442801/, Test.ino.hex
08:39:55.599 (loader): flash, block=8, bs=1024, auto=1
08:39:55.628 (reboot 10): status read, retry 3
08:39:55.628 (reboot 10): Success
08:39:55.628 (reboot 10): Disconnect
08:39:55.632 (loader): flash, block=9, bs=1024, auto=1
08:39:55.634 (loader): flash, block=10, bs=1024, auto=1
08:39:55.635 (loader): flash, block=11, bs=1024, auto=1
08:39:55.636 (loader): flash, block=12, bs=1024, auto=1
08:39:55.641 (ports 5): got command: "list"
08:39:55.642 (ports 5): got command: "list"
08:39:55.648 (serialmon 11): Begin, version=1.42-beta3
08:39:55.648 (serialmon 11): teensy_serialmon, loc = usb:230000
08:39:55.648 (serialmon 11): USB device add callback
08:39:55.648 (serialmon 11):   loc=230000, vid=16C0, pid=0478, ver=0103, ser=0004F60E
08:39:55.648 (serialmon 11):   actual serailnum=325134
08:39:55.729 (loader): remote connection 15 closed
08:39:55.771 (loader): remote connection 11 opened
08:39:55.786 (serialmon 11): USB device remove callback
08:39:55.786 (serialmon 11): Serial add callback
08:39:55.803 (serialmon 11): Serial remove callback
08:39:55.807 (serialmon 11): HID Manager started
08:39:55.807 (serialmon 11): HID add callback, vid=16c0, pid=0478, ver=0103, loc=230000, use=ff9c:22
08:39:55.812 (loader): flash, block=13, bs=1024, auto=1
08:39:55.813 (loader): flash, block=14, bs=1024, auto=1
08:39:55.896 (loader): flash, block=15, bs=1024, auto=1
08:39:59.739 (loader): flash, block=126, bs=1024, auto=1
08:39:59.772 (loader): flash, block=127, bs=1024, auto=1
08:39:59.817 (loader): sending reboot
08:39:59.821 (loader): begin wait_until_offline
08:39:59.823 (loader): HID/macos: status: ok
08:40:00.086 (ports 5): HID remove callback
08:40:00.086 (ports 5): HID add callback, vid=16c0, pid=0478, ver=0103, loc=230000
08:40:00.086 (serialmon 11): HID remove callback
08:40:00.086 (serialmon 11): HID add callback, vid=16c0, pid=0478, ver=0103, loc=230000
08:40:00.086 (loader): HID/macos: detach callback: is currently open device
08:40:00.087 (ports 5): USB device remove callback
08:40:00.087 (ports 5): remove, loc=230000
08:40:00.087 (ports 5): usb_remove: usb:230000
08:40:00.087 (ports 5): del device: location=230000
08:40:00.087 (serialmon 11): USB device remove callback
08:40:00.087 (serialmon 11): remove, loc=230000
08:40:00.087 (serialmon 11): del device: location=230000
08:40:00.088 (ports 5): USB device add callback
08:40:00.088 (serialmon 11): USB device add callback
08:40:00.089 (ports 5):   loc=230000, vid=16C0, pid=0483, ver=0200, ser=3251340
08:40:00.089 (ports 5):   actual serailnum=325134
08:40:00.089 (ports 5):   found prior teensy at this loc, age=0.002
08:40:00.089 (ports 5):     name: [no_device] (Teensy 3.6) Serial
08:40:00.089 (serialmon 11):   loc=230000, vid=16C0, pid=0483, ver=0200, ser=3251340
08:40:00.089 (serialmon 11):   actual serailnum=325134
08:40:00.134 (loader): offline, waited 5
08:40:00.172 (loader): end operation, total time = 5.229 seconds
08:40:00.186 (loader): set background IMG_REBOOT_OK
08:40:00.191 (loader): redraw timer set, image 14 to show for 1200 ms
08:40:00.293 (loader): HID/macos: number of devices found = 0
08:40:00.308 (loader): HID/macos: no devices found (empty set)
08:40:00.315 (serialmon 11): Serial add callback
08:40:00.316 (serialmon 11):   name=/dev/cu.usbmodem425, loc=230000, vid=16c0, pid=0483, ver=0200
08:40:00.385 (serialmon 11): Opened /dev/cu.usbmodem425 Serial
08:40:00.385 (serialmon 11): Open required 4 attempts
08:40:01.392 (loader): redraw, image 9
— Port is now 525 --
