Marcus LaGrone
Pardon me as I can't post my code, but maybe someone can direct me where to poke the Teensy:
I have code that runs fine on a Teensy 3.6. It is running Optimised Fastest with LTO and is overclocked to 240MHz.
Everything is awesome (cue music).
However... I have three of these on the same board. all running the exact same code and on one, the I2S audio is jittering.
Same batch of Teensy 3.6, all programmed within minutes of each other yet one is always a problem.
I'm powering off of the 5V side with the 3.3V pins dangling, unconnected.
I'm showing 4.96V on the 5V rail and 3.28V on the 3.3V lines on the teensy 3.6.
If i run just a simple test code on the recalcitrant Teensy 3.6, it works fine overclocked to 240MHz.
With the real code: jitter
How dicey are the Teensy 3.6 running them overclocked? I've been doing this for five months now and this is the first time I've seen one misbehave.
Grounds look good, power is as above...
I've jumped extra grounds, I've jumped extra power and this one Teensy 3.6 just doesn't want to play nice.
I've washed both the Teensy and the board with alcohol and it made no difference.
Any suggestions on things to check or things that might help with an overclocked Teensy would be helpful.
<addition>
the trace for 5V power coming from the USB to the Vin was cut...
is it possible the cut was too deep and damaged something below?
--mjlg
<addition>
--mjlg
