Audio adapter stream to USB --> receive in MAX 7 with ASIO4ALL
Anybody tried to work with ASIO4ALL with the Teensy as Audio card? or specifically with MAX7 and Teensy?
- I am working with Win10. working with Teensy3.2 and Teensy Audio Board.
- They Teensy configured in the Teensyduino\Arduino USB Type : Audio
- While not working with any audio software, "Digital Audio Interface" is available in the Playback\Recording. I got the Audio (coming from the LINEIN) from the recording device, I can listen to the audio from the headphone connected to my PC.
After Opening MAX7, I created a new Template = audiostart and I configure the driver to be ASIO4ALL v2, in the ASIO I configured the Teensy Audio IN.
While turning the MAX on, the ~adc object not getting any audio from the teensy and I see that something is changing in the ASIO4ALL icon down with some red icon..
Anyone have experience with ASIO4ALL & teensy or with MAX7 with other driver?
Any suggestion will be great!
Thanks !
Alon
ASIO needs exclusive control over the device. Don't make Teensy the default recording device in the Windows sound config.
Originally Posted by
tni
hi tni,
Thanks, I just tried what you said, the Teensy now is not the default recording device and still I got red exclamation mark flashing..
no signal in the meters of the ~adc element.
while deactivate the teensy in the ASIO4ALL and activate the "HD Audio Microphone 2" I got signal in the MAX..
Any other suggestions?
Anyone worked with the MAX\MSP using the Teensy as Audio interface?
Please, does anyone worked with other DAW and can tell me which driver is the best to get low latency while recieving audio from the teensy ? (AudioOutputUSB)
Currently I am working with asio4all but once in a while there are "knaks" that sound like problem with the buffering (I tried to play with the Audio buffer size and 512 works the best, but still those noises)
Hello alonper,
We meet again! I know this post is old, but I remember colaborating with you regarding an ADC for your guitar pickups. Right?
I'm trying to get the Teensy to work with ASIO4ALL. No luck. My post is here:
https://forum.pjrc.com/threads/61051...tency-Playback
Are you still interested in making this work?
Jay
- You may not post replies
- You may not edit your posts
Forum Rules
