/* Audio Library for Teensy 3.X
* Copyright (c) 2014, Paul Stoffregen, paul@pjrc.com
* Modified by Macaba
* then by Manicksan to n-input and n-output c++ template
* Development of this audio library was funded by PJRC.COM, LLC by sales of
* Teensy and Audio Adaptor boards. Please support PJRC's efforts to develop
* open source software by purchasing Teensy or other PJRC products.
* THE SOFTWARE.
#ifndef mixercrosspoint16_h_
#define mixercrosspoint16_h_
#include "Arduino.h"
#include "AudioStream.h"
template <int NI, int NO> class AudioMixerCrosspoint : public AudioStream
#if defined(KINETISK)
public:
AudioMixerCrosspoint(void) : AudioStream(NI, inputQueueArray) {
for (int i=0; i<NO; i++) {
outputGains[NO] = 1.0;
for(int j=0; j<NI; j++) {
gains[i][j] = 1.0;
integerMultipliers[i][j] = 65536;
virtual void update(void);
void gain(unsigned int bus, unsigned int channel, float gain) {
if (bus >= NO) return;
if (channel >= NI) return;
if (gain > 32767.0f) gain = 32767.0f;
else if (gain < -32767.0f) gain = -32767.0f;
gains[bus][channel] = gain;
integerMultipliers[bus][channel] = gains[bus][channel] * outputGains[bus] * 65536.0f;
void outputGain(unsigned int bus, float gain) {
if (bus >= 16) return;
outputGains[bus] = gain;
for (int i=0; i<NI; i++) {
integerMultipliers[bus][i] = gains[bus][i] * outputGains[bus] * 65536.0f;
private:
float gains[NO][NI]; //For each bus n, there are x inputs -> gains[n][x]
float outputGains[NO]; //For each bus, there is an output gain
int32_t integerMultipliers[NO][NI]; //Computed channel/bus gains with bus output gain mixed in
audio_block_t *inputQueueArray[NI];
#elif defined(KINETISL)
public:
outputGains[i] = 1.0;
gains[i][j] = 1.0;
integerMultipliers[i][j] = 256
void gain(unsigned int bus,unsigned int channel, float gain) {
if (gain > 127.0f) gain = 127.0f;
else if (gain < -127.0f) gain = -127.0f;
integerMultipliers[bus][channel] = gains[bus][channel] * outputGains[bus] * 256.0f;
calculateIntegerMultipliers(bus);
integerMultipliers[bus][i] = gains[bus][i] * outputGains[bus] * 256.0f;
private:
int16_t integerMultipliers[NO][NI]; //Computed channel/bus gains with bus output gain mixed in
//#include "mixer_crosspoint_16.h"
#include "utility/dspinst.h"
// the following Forward declarations
// must be defined when we use template
// the compiler throws some warnings that should be errors otherwise
static inline int32_t signed_multiply_32x16b(int32_t a, uint32_t b);
static inline int32_t signed_multiply_32x16t(int32_t a, uint32_t b);
static inline int32_t signed_saturate_rshift(int32_t val, int bits, int rshift);
static inline uint32_t pack_16b_16b(int32_t a, int32_t b);
static inline uint32_t signed_add_16_and_16(uint32_t a, uint32_t b);
#define MULTI_UNITYGAIN 65536
static void applyGain(int16_t *data, int32_t mult)
uint32_t *p = (uint32_t *)data;
const uint32_t *end = (uint32_t *)(data + AUDIO_BLOCK_SAMPLES);
do {
uint32_t tmp32 = *p; // read 2 samples from *data
int32_t val1 = signed_multiply_32x16b(mult, tmp32);
int32_t val2 = signed_multiply_32x16t(mult, tmp32);
val1 = signed_saturate_rshift(val1, 16, 0);
val2 = signed_saturate_rshift(val2, 16, 0);
*p++ = pack_16b_16b(val2, val1);
} while (p < end);
static void applyGainThenAdd(int16_t *data, const int16_t *in, int32_t mult)
uint32_t *dst = (uint32_t *)data;
const uint32_t *src = (uint32_t *)in;
if (mult == MULTI_UNITYGAIN) {
do {
uint32_t tmp32 = *dst;
*dst++ = signed_add_16_and_16(tmp32, *src++);
tmp32 = *dst;
} while (dst < end);
do {
uint32_t tmp32 = *src++; // read 2 samples from *data
tmp32 = pack_16b_16b(val2, val1);
uint32_t tmp32b = *dst;
*dst++ = signed_add_16_and_16(tmp32, tmp32b);
#define MULTI_UNITYGAIN 256
const int16_t *end = data + AUDIO_BLOCK_SAMPLES;
do {
int32_t val = *data * mult;
*data++ = signed_saturate_rshift(val, 16, 0);
} while (data < end);
static void applyGainThenAdd(int16_t *dst, const int16_t *src, int32_t mult)
const int16_t *end = dst + AUDIO_BLOCK_SAMPLES;
do {
int32_t val = *dst + *src++;
*dst++ = signed_saturate_rshift(val, 16, 0);
do {
int32_t val = *dst + ((*src++ * mult) >> 8); // overflow possible??
template <int NI, int NO> void AudioMixerCrosspoint::update(void)
audio_block_t *in[NI], *out=NULL;
unsigned int channel;
unsigned int bus;
unsigned int sample;
//First get audio_blocks to all the input channels as readonly.
//Readonly because we'll be using them multiple times so don't want to modify contents.
for (channel=0; channel < NI; channel++) {
in[channel] = receiveReadOnly(channel);
//Now crosspoint mix.
for(bus=0; bus < NO; bus++) {
out = allocate(); //get an audio_block that we'll sum the other channels to
for(sample=0; sample < AUDIO_BLOCK_SAMPLES; sample++){
out->data[sample] = 0;
//Using explicit loop instead of memset reduced CPU usage from 53% to 48.50%
//memset(out->data, 0, AUDIO_BLOCK_SAMPLES * sizeof(int16_t));
if(out){
if (in[channel]) {
applyGainThenAdd(out->data, in[channel]->data, integerMultipliers[bus][channel]);
transmit(out, bus);
release(out);
//Now release all the input audio_blocks
if(in[channel])
release(in[channel]);
// this class and function forces include
// of functions applyGainThenAdd and applyGain used by the template
class DummyClassCrossPointMixer
public:
virtual void dummyFunction();
void DummyClassCrossPointMixer::dummyFunction() {
applyGainThenAdd(0, 0, 0);
applyGain(0,0);
