shapingstuff
I have been trying to get my Teensy 3.6 and Propshield to play mp3 files from the onboard sd card.
It isn't working at all and guidance would be much appreciated.
I have connected the following pins:
Teensy 3.6 ----------------> Propshield
DA0 ----------------> DAC
Analog GND ----------------> Agnd
VIN -----------------> 5V
GND -----------------> GND
I have connected the boards directly to each other and so there are other pins connected - but nothing that shouldn't be. The DAC0 pin is connected to DAC via a cable. I am not using any external power other than USB. I have tried the EXTERNAL option and connected 5V and GND to a 5v supply alongside the speaker terminals but this never worked either (I assume that is power for the amp?).
The SD card told me it was playing the file and I have also tried using the sinewave option to generating sound but nothing.
I have been using code I found on the forum as following any help is much apreciated.
// from: https://forum.pjrc.com/threads/33328-Prop-Shield-Beta-Test?p=99236&viewfull=1#post99236
// modified by Michael Meissner
AudioSynthWaveformSine sine1; //xy=180,469
AudioOutputAnalog dac1; //xy=380,468
AudioConnection patchCord1(sine1, dac1);
int freq = 1000;
while (!Serial)
Serial.println("Setting up");
pinMode(5, OUTPUT);
digitalWrite(5, 1); // Enable Amplified.
AudioMemory(12);
sine1.amplitude(1.0);
sine1.frequency(freq);
Serial.println("Send + to increase freq, - to decrease freq, a to turn off amp, A to turn on amp, or num for freq.");
if (Serial.available()) {
int ch = Serial.read();
switch (ch)
case '+':
freq += 100;
Serial.print ("New frequency ");
Serial.println (freq);
case '-':
freq -= 100;
case 'a':
digitalWrite (5, 0);
Serial.println ("Amp off");
case 'A':
digitalWrite (5, 1);
Serial.println ("Amp on");
case '0':
case '1':
case '2':
case '3':
case '4':
case '5':
case '6':
case '7':
case '8':
case '9':
bool looping = true;
freq = ch - '0';
do
if (Serial.available ())
ch = Serial.read ();
if (ch >= '0' && ch <= '9')
freq = (freq * 10) + (ch - '0');
looping = false;
while (looping);
case ' ':
case '\n':
case '\t':
case '\r':
default:
Serial.print ("Unknown character '");
Serial.print ((char) ch);
Serial.print ("'");
