Hi i had never test used the cli before - but because a customer must change my firmware i test it before our customer must use it.
For my test i use the newest version of cli and generate a batch file.
In this file this commands are used.
teensy_loader_cli -mmcu=mk20dx256 -s -v blink_slow_Teensy32.hex
pause
after i press the reset on teensy the following behavior happend:
the teensy cli loader downoadt the file which is from github - at the same time the teensy loader gui seems to be activated....
i didnt get an error message from cli - or teensy loader gui - or i had overseen - after this my teensy is'nt anymore recognised also after unplug amd plugin again.
On the same usb port flashing of another teensy works.
this is for me unbelievable bad - because i need the two last teensy which i had for tests - to find a failure in my firmware.
can you give me some advice how i can bring teensy loader back to live. At my working place i have many tools and programmers available.
Best regards,
Frank Münzner
pause
Best regards,
Frank Münzner
