Page 2 of 2 FirstFirst 1 2
Results 26 to 36 of 36
Thread: Teensy based multistage distortion modeling pedal
  1. #26
    Apr 2019
    Northwest Ohio
    4
    I know this is an old thread, but has anyone successfully ported over the array to the standard audio library waveshape?
  2. #27
    Aug 2015
    Scotland
    142
    @scruffy - I've ported them over, let me know if you're looking for them
  3. #28
    Oct 2019
    1
    Very very good job.
    Can you indicate with which versions you compiled because me, with the latest versions downloaded, I only have compilation errors (in menu.cpp, in multistagedist.cpp, in waveshaper.cpp, etc )
  4. #29
    Aug 2015
    Scotland
    142
    Quote Originally Posted by marbeuhan08 View Post
    Very very good job.
    Hi marbeuhan08, if you were referring to my post at #27 - it is only referring to the tube response data files that @scruffy was looking for and whether they're converted to a format for the standard Audio Library Waveshaper object. I haven't tried to compile the entire project. Cheers, Paul
  5. #30
    Oct 2019
    16
    Quote Originally Posted by houtson View Post
    Hello @houtson
    I would be very glad, if you could share those tables for the standard audio library waveshaper module. Where can I find them?
  6. #31
    Aug 2015
    Scotland
    142
    Hi @flo
    I've attached the wavetables below, some notes:
    - I've converted them to 513 samples from the original 2001
    - I've also included a version of one of them at 1025 samples (12ax7)
    - In the source file they say they are mapped -32767 to 32767 but they look as thought they are mapped 0-32767 and that's what I've assumed re-mapping to -1.0 - 1.0
    - a couple of them (12au and kt88) don't use the full range, not sure if this is correct / intended
    If you need them converted to any different sizes of arrays just let me know. Cheers Paul
ID:	19028Click image for larger version.
ID:	19030Click image for larger version.
    // tube input stage response curves sourced from TeensyDist (https://github.com/jcugnoni/TeensyDist) who sourced from Guitarix tables (http://guitarix.org) => THANKS !!
    // inverted and resampled for Teensy Audio Lib - AudioEffectWaveshaper (-1.0 - 1.0 513 samples)
    const float wave_shape_tube_12at7 [513] = {-0.7878252,-0.7845943,-0.7813367,-0.7780526,-0.7747419,-0.771405,-0.7680417,-0.7646523,-0.7612367,-0.7577952,-0.7543278,-0.7508345,-0.7473155,-0.7437709,-0.7402008,-0.7366052,-0.7329844,-0.7293385,-0.7256674,-0.7219714,-0.7182505,-0.7145048,-0.7107343,-0.7069392,-0.7031196,-0.6992757,-0.6954075,-0.6915152,-0.6875988,-0.6836584,-0.6796942,-0.6757062,-0.6716946,-0.6676593,-0.6636004,-0.6595184,-0.6554129,-0.6512844,-0.6471328,-0.6429582,-0.6387607,-0.6345405,-0.6302976,-0.6260321,-0.621744,-0.6174334,-0.6131006,-0.6087456,-0.6043684,-0.5999693,-0.5955482,-0.5911052,-0.5866405,-0.582154,-0.577646,-0.5731163,-0.5685652,-0.5639927,-0.5593991,-0.5547842,-0.5501482,-0.5454913,-0.5408133,-0.5361145,-0.531395,-0.5266545,-0.5218935,-0.5171119,-0.5123098,-0.5074872,-0.5026444,-0.4977812,-0.4928978,-0.4879943,-0.4830708,-0.4781271,-0.4731635,-0.4681799,-0.4631765,-0.4581534,-0.4531106,-0.4480482,-0.4429661,-0.4378646,-0.4327435,-0.4276031,-0.4224433,-0.417264,-0.4120656,-0.4068479,-0.4016111,-0.3963552,-0.3910803,-0.3857863,-0.3804734,-0.3751416,-0.3697909,-0.3644212,-0.3590328,-0.3536256,-0.3481997,-0.3427552,-0.337292,-0.3318102,-0.3263099,-0.320791,-0.3152537,-0.3096979,-0.3041236,-0.2985308,-0.2929197,-0.2872903,-0.2816426,-0.2759765,-0.2702923,-0.2645898,-0.258869,-0.2531301,-0.247373,-0.2415976,-0.2358041,-0.2299925,-0.2241628,-0.2183151,-0.2124492,-0.2065654,-0.2006634,-0.1947435,-0.1888055,-0.1828494,-0.1768753,-0.1708832,-0.1648731,-0.158845,-0.152799,-0.1467349,-0.1406529,-0.134553,-0.128435,-0.122299,-0.116145,-0.109973,-0.103783,-0.09757504,-0.09134907,-0.08510508,-0.07884308,-0.07256305,-0.06626499,-0.05994888,-0.05361465,-0.0472623,-0.04089186,-0.03450332,-0.02809666,-0.02167186,-0.01522891,-0.008767786,-0.002288466,0.004209068,0.01072484,0.01725898,0.0238114,0.03038213,0.03697119,0.0435786,0.05020439,0.05684859,0.06351122,0.07019229,0.07689186,0.08360997,0.09034669,0.09710196,0.1038758,0.1106683,0.1174794,0.1243091,0.1311575,0.1380245,0.1449103,0.1518147,0.158738,0.1656799,0.1726406,0.1796199,0.1866178,0.1936344,0.2006695,0.2077231,0.2147952,0.2218855,0.228994,0.2361207,0.2432653,0.2504275,0.2576071,0.2648038,0.2720172,0.279247,0.2864925,0.2937533,0.3010286,0.3083177,0.3156196,0.3229333,0.3302574,0.3375906,0.3449311,0.352277,0.3596261,0.3669758,0.3743232,0.3816651,0.3889975,0.3963161,0.4036163,0.4108926,0.4181389,0.4253488,0.4325148,0.4396291,0.4466833,0.4536682,0.4605743,0.4673913,0.4741094,0.4807185,0.4872088,0.4935706,0.4997948,0.5058734,0.5117989,0.5175653,0.5231676,0.5286018,0.5338652,0.5389574,0.5438786,0.5486302,0.5532144,0.5576344,0.561894,0.5659978,0.5699508,0.5737581,0.5774246,0.5809565,0.5843595,0.5876392,0.5908014,0.5938512,0.5967941,0.5996352,0.6023792,0.6050309,0.6075948,0.6100746,0.6124749,0.6147996,0.6170523,0.6192364,0.6213551,0.6234116,0.6254087,0.6273493,0.6292357,0.6310704,0.6328557,0.6345939,0.636287,0.6379371,0.6395458,0.641115,0.6426462,0.6441411,0.645601,0.6470275,0.6484216,0.6497846,0.651118,0.6524226,0.6536997,0.6549502,0.6561751,0.6573753,0.6585516,0.6597049,0.660836,0.6619455,0.6630343,0.664103,0.6651523,0.6661828,0.6671951,0.6681898,0.6691674,0.6701285,0.6710734,0.6720028,0.672917,0.6738165,0.6747018,0.6755732,0.6764311,0.6772759,0.678108,0.6789277,0.6797354,0.6805313,0.6813158,0.682089,0.6828515,0.6836033,0.6843449,0.6850764,0.6857981,0.6865102,0.687213,0.6879067,0.6885914,0.6892675,0.689935,0.6905942,0.6912453,0.6918885,0.6925239,0.6931517,0.6937721,0.6943853,0.6949914,0.6955904,0.6961826,0.6967682,0.6973472,0.6979198,0.6984862,0.6990464,0.6996006,0.7001489,0.7006914,0.7012283,0.7017595,0.7022852,0.7028056,0.7033207,0.7038307,0.7043356,0.7048355,0.7053306,0.7058208,0.7063063,0.7067872,0.7072635,0.7077353,0.7082028,0.7086659,0.7091247,0.7095795,0.7100301,0.7104766,0.7109192,0.7113579,0.7117927,0.7122238,0.7126511,0.7130747,0.7134948,0.7139112,0.7143242,0.7147338,0.71514,0.7155429,0.7159424,0.7163387,0.7167318,0.7171218,0.7175087,0.7178925,0.7182733,0.7186512,0.7190261,0.7193982,0.7197675,0.7201339,0.7204975,0.7208585,0.7212167,0.7215723,0.7219253,0.7222757,0.7226236,0.722969,0.7233118,0.7236523,0.7239904,0.724326,0.7246593,0.7249903,0.725319,0.7256454,0.7259696,0.7262917,0.7266115,0.7269291,0.7272447,0.7275582,0.7278696,0.7281789,0.7284862,0.7287915,0.7290949,0.7293963,0.7296958,0.7299933,0.730289,0.7305829,0.7308749,0.7311651,0.7314534,0.73174,0.7320248,0.732308,0.7325894,0.7328691,0.7331471,0.7334235,0.7336981,0.7339712,0.7342427,0.7345126,0.7347809,0.7350477,0.7353129,0.7355766,0.7358388,0.7360995,0.7363588,0.7366166,0.7368729,0.7371278,0.7373812,0.7376333,0.737884,0.7381333,0.7383813,0.7386279,0.7388732,0.7391171,0.7393598,0.7396012,0.7398413,0.7400801,0.7403176,0.740554,0.7407891,0.7410229,0.7412556,0.741487,0.7417173,0.7419464,0.7421744,0.7424011,0.7426268,0.7428513,0.7430747,0.743297,0.7435182,0.7437382,0.7439573,0.7441752,0.744392,0.7446079,0.7448227,0.7450364,0.7452492,0.7454609,0.7456716,0.7458813,0.74609,0.7462977,0.7465045,0.7467102,0.7469151,0.747119,0.747322,0.747524,0.7477251,0.7479253,0.7481245,0.7483229,0.7485204,0.748717,0.7489127,0.7491075,0.7493016,0.7494947,0.7496869,0.7498783,0.750069,0.7502587,0.7504476,0.7506357,0.7508231,0.7510096,0.7511953,0.7513802,0.7515643,0.7517477,0.7519303,0.7521121,0.7522931,0.7524734};
    const float wave_shape_tube_6v6 [513] = {-0.9193002,-0.9172585,-0.9151811,-0.9130678,-0.9109185,-0.908733,-0.9065112,-0.9042532,-0.9019588,-0.8996278,-0.8972603,-0.8948562,-0.8924152,-0.8899376,-0.8874233,-0.8848722,-0.8822845,-0.87966,-0.8769987,-0.8743008,-0.8715662,-0.8687949,-0.8659868,-0.8631421,-0.860261,-0.8573433,-0.8543893,-0.8513988,-0.8483722,-0.8453094,-0.8422105,-0.8390755,-0.8359047,-0.8326979,-0.8294553,-0.8261772,-0.8228635,-0.8195146,-0.8161303,-0.8127109,-0.8092566,-0.8057674,-0.8022434,-0.7986847,-0.7950915,-0.7914638,-0.787802,-0.7841061,-0.7803763,-0.7766127,-0.7728155,-0.7689848,-0.7651207,-0.7612236,-0.7572931,-0.7533298,-0.7493336,-0.7453049,-0.7412437,-0.7371503,-0.7330246,-0.728867,-0.7246774,-0.7204562,-0.7162035,-0.7119191,-0.7076035,-0.7032567,-0.698879,-0.6944704,-0.6900311,-0.6855613,-0.6810611,-0.6765305,-0.67197,-0.6673793,-0.6627585,-0.6581082,-0.6534281,-0.6487187,-0.6439799,-0.6392119,-0.6344149,-0.6295888,-0.6247339,-0.6198503,-0.6149381,-0.6099973,-0.6050281,-0.6000307,-0.5950052,-0.5899516,-0.5848702,-0.5797609,-0.5746239,-0.5694594,-0.5642673,-0.5590477,-0.5538008,-0.5485267,-0.5432255,-0.5378972,-0.532542,-0.52716,-0.5217512,-0.5163157,-0.5108536,-0.505365,-0.4998497,-0.4943082,-0.4887403,-0.4831462,-0.4775259,-0.4718795,-0.4662071,-0.4605086,-0.4547843,-0.4490341,-0.443258,-0.4374561,-0.4316284,-0.4257751,-0.4198962,-0.4139917,-0.4080617,-0.4021061,-0.3961251,-0.3901186,-0.3840868,-0.3780293,-0.3719466,-0.3658385,-0.3597051,-0.3535464,-0.3473625,-0.3411533,-0.3349188,-0.3286591,-0.3223741,-0.3160639,-0.3097283,-0.3033675,-0.2969814,-0.2905701,-0.2841335,-0.2776716,-0.2711844,-0.264672,-0.2581342,-0.2515711,-0.2449824,-0.2383683,-0.2317288,-0.2250638,-0.2183732,-0.2116571,-0.2049154,-0.1981481,-0.191355,-0.1845362,-0.1776917,-0.170821,-0.1639244,-0.1570019,-0.1500533,-0.1430785,-0.1360775,-0.1290503,-0.1219966,-0.1149165,-0.1078099,-0.1006766,-0.09351643,-0.08632947,-0.07911558,-0.07187469,-0.06460667,-0.05731142,-0.04998885,-0.04263884,-0.03526129,-0.02785609,-0.02042301,-0.01296201,-0.005473034,0.002044014,0.009589233,0.01716271,0.02476454,0.03239479,0.04005352,0.04774078,0.0554566,0.06320116,0.07097428,0.07877589,0.08660592,0.09446423,0.1023506,0.1102649,0.1182067,0.1261756,0.1341711,0.1421927,0.1502396,0.1583108,0.1664053,0.1745216,0.1826582,0.1908133,0.1989848,0.20717,0.2153661,0.2235697,0.2317769,0.2399831,0.2481832,0.2563715,0.2645415,0.272686,0.2807969,0.2888655,0.2968823,0.304837,0.3127188,0.3205158,0.3282169,0.33581,0.3432836,0.3506261,0.3578268,0.3648753,0.3717628,0.3784811,0.3850239,0.3913856,0.3975621,0.4035519,0.4093543,0.4149699,0.4204004,0.4256485,0.4307179,0.4356129,0.4403385,0.4449001,0.4493028,0.4535529,0.4576567,0.4616201,0.4654494,0.4691502,0.4727284,0.4761896,0.4795391,0.4827821,0.4859237,0.4889679,0.49192,0.4947842,0.4975646,0.5002652,0.5028895,0.505441,0.5079229,0.5103386,0.5126908,0.5149823,0.5172155,0.5193933,0.5215179,0.5235915,0.5256163,0.5275943,0.5295274,0.5314172,0.5332656,0.5350741,0.5368441,0.5385772,0.5402747,0.5419381,0.5435684,0.545167,0.5467348,0.5482731,0.5497827,0.5512647,0.55272,0.5541493,0.5555536,0.5569338,0.5582905,0.5596245,0.5609366,0.5622273,0.5634974,0.5647474,0.5659779,0.5671895,0.5683827,0.569558,0.570716,0.5718571,0.5729818,0.5740906,0.5751839,0.5762619,0.5773253,0.5783744,0.5794094,0.5804307,0.5814388,0.5824339,0.5834163,0.5843864,0.5853445,0.5862908,0.5872256,0.5881492,0.5890618,0.5899637,0.5908551,0.5917362,0.5926073,0.5934686,0.5943204,0.5951627,0.5959959,0.5968201,0.5976354,0.5984421,0.5992404,0.6000304,0.6008122,0.6015861,0.6023522,0.6031107,0.6038616,0.6046053,0.6053416,0.6060709,0.6067933,0.6075088,0.6082175,0.6089198,0.6096156,0.610305,0.6109881,0.6116652,0.6123363,0.6130014,0.6136608,0.6143144,0.6149623,0.6156048,0.6162418,0.6168735,0.6174999,0.6181212,0.6187373,0.6193485,0.6199548,0.6205562,0.6211528,0.6217446,0.6223319,0.6229146,0.6234929,0.6240667,0.6246361,0.6252013,0.6257622,0.626319,0.6268716,0.6274202,0.6279649,0.6285055,0.6290424,0.6295754,0.6301045,0.6306301,0.6311519,0.6316701,0.6321848,0.6326959,0.6332036,0.6337078,0.6342086,0.6347061,0.6352004,0.6356913,0.6361791,0.6366637,0.6371452,0.6376236,0.6380989,0.6385712,0.6390406,0.639507,0.6399705,0.6404312,0.640889,0.641344,0.6417962,0.6422458,0.6426926,0.6431368,0.6435783,0.6440172,0.6444536,0.6448874,0.6453187,0.6457475,0.6461739,0.6465978,0.6470193,0.6474385,0.6478552,0.6482697,0.6486819,0.6490918,0.6494994,0.6499048,0.6503081,0.6507092,0.651108,0.6515048,0.6518995,0.652292,0.6526825,0.6530709,0.6534574,0.6538418,0.6542243,0.6546047,0.6549833,0.6553599,0.6557347,0.6561075,0.6564785,0.6568475,0.6572149,0.6575803,0.657944,0.6583059,0.6586661,0.6590245,0.6593812,0.6597362,0.6600895,0.6604411,0.660791,0.6611393,0.661486,0.661831,0.6621745,0.6625164,0.6628567,0.6631954,0.6635326,0.6638682,0.6642024,0.664535,0.6648662,0.6651959,0.6655241,0.6658509,0.6661762,0.6665001,0.6668226,0.6671437,0.6674634,0.6677817,0.6680987,0.6684143,0.6687285,0.6690415,0.6693531,0.6696634,0.6699724,0.6702801,0.6705865,0.6708917,0.6711956,0.6714983,0.6717997,0.6720999,0.6723989,0.6726967,0.6729933,0.6732888,0.673583,0.673876,0.6741679,0.6744587,0.6747482,0.6750367,0.6753241,0.6756103,0.6758955,0.6761795,0.6764624,0.6767443,0.6770251,0.6773048,0.6775835,0.677861,0.6781376,0.6784132,0.6786877,0.6789612,0.6792337};
    const float wave_shape_tube_12ax7 [513] = {-0.9998356,-0.9998285,-0.9998211,-0.9998131,-0.9998046,-0.9997956,-0.9997859,-0.9997756,-0.9997646,-0.9997528,-0.9997402,-0.9997269,-0.9997126,-0.9996973,-0.9996811,-0.9996637,-0.9996451,-0.9996254,-0.9996043,-0.9995818,-0.9995577,-0.9995321,-0.9995048,-0.9994756,-0.9994445,-0.9994113,-0.9993759,-0.9993382,-0.9992979,-0.999255,-0.9992092,-0.9991604,-0.9991084,-0.9990528,-0.9989937,-0.9989306,-0.9988633,-0.9987917,-0.9987153,-0.998634,-0.9985473,-0.9984549,-0.9983565,-0.9982517,-0.9981401,-0.9980212,-0.9978947,-0.9977599,-0.9976166,-0.997464,-0.9973016,-0.997129,-0.9969453,-0.9967499,-0.9965422,-0.9963214,-0.9960868,-0.9958375,-0.9955727,-0.9952915,-0.994993,-0.9946762,-0.9943401,-0.9939836,-0.9936056,-0.9932048,-0.9927801,-0.9923303,-0.9918541,-0.99135,-0.9908168,-0.9902529,-0.9896568,-0.9890271,-0.988362,-0.98766,-0.9869192,-0.986138,-0.9853147,-0.9844475,-0.9835346,-0.9825742,-0.9815643,-0.980503,-0.9793884,-0.9782187,-0.9769915,-0.9757051,-0.9743575,-0.9729471,-0.9714716,-0.9699293,-0.9683182,-0.9666366,-0.9648825,-0.9630542,-0.9611499,-0.9591675,-0.9571057,-0.954963,-0.9527378,-0.9504287,-0.9480343,-0.9455533,-0.9429844,-0.9403264,-0.9375783,-0.9347389,-0.9318069,-0.928782,-0.9256635,-0.9224505,-0.9191425,-0.9157391,-0.9122396,-0.9086438,-0.9049515,-0.9011623,-0.8972758,-0.8932921,-0.8892113,-0.8850336,-0.8807591,-0.876388,-0.8719205,-0.867357,-0.8626977,-0.8579431,-0.8530936,-0.8481492,-0.8431109,-0.8379794,-0.8327552,-0.827439,-0.8220314,-0.8165331,-0.8109448,-0.8052673,-0.7995013,-0.7936474,-0.7877063,-0.781679,-0.7755664,-0.7693694,-0.7630886,-0.7567251,-0.7502796,-0.743753,-0.7371461,-0.7304597,-0.7236946,-0.7168516,-0.7099317,-0.7029359,-0.6958649,-0.6887197,-0.681501,-0.6742097,-0.6668467,-0.6594127,-0.6519088,-0.644335,-0.6366929,-0.6289831,-0.6212065,-0.6133639,-0.6054561,-0.5974838,-0.5894479,-0.5813491,-0.5731882,-0.5649658,-0.5566826,-0.5483397,-0.5399376,-0.5314772,-0.5229592,-0.5143844,-0.5057536,-0.4970673,-0.4883265,-0.4795317,-0.4706835,-0.4617828,-0.4528304,-0.4438271,-0.4347736,-0.4256707,-0.4165191,-0.4073196,-0.3980731,-0.3887803,-0.3794421,-0.3700592,-0.3606327,-0.3511635,-0.3416527,-0.3321014,-0.3225107,-0.3128818,-0.303216,-0.2935148,-0.2837798,-0.2740125,-0.2642147,-0.2543888,-0.244537,-0.2346618,-0.2247661,-0.2148531,-0.2049264,-0.19499,-0.1850484,-0.1751067,-0.1651704,-0.155246,-0.1453405,-0.1354616,-0.1256179,-0.1158189,-0.1060748,-0.09639668,-0.08679653,-0.07728693,-0.06788112,-0.0585936,-0.04943768,-0.04042734,-0.03157631,-0.02289781,-0.01440425,-0.006106971,0.001984002,0.009860178,0.01751473,0.02494214,0.03213862,0.03910363,0.04583734,0.05234143,0.05861896,0.06467417,0.07051229,0.07613934,0.08156197,0.08678727,0.0918219,0.09667389,0.1013512,0.1058616,0.1102124,0.114411,0.1184645,0.1223798,0.1261635,0.129822,0.1333613,0.1367865,0.1401037,0.1433183,0.1464351,0.1494588,0.1523937,0.1552441,0.1580138,0.1607065,0.1633258,0.1658749,0.1683566,0.1707743,0.1731308,0.1754286,0.1776702,0.1798581,0.1819943,0.184081,0.1861202,0.1881137,0.1900632,0.1919705,0.1938372,0.1956649,0.1974549,0.1992088,0.2009277,0.202613,0.2042658,0.2058871,0.2074782,0.2090398,0.2105731,0.212079,0.2135584,0.2150122,0.2164411,0.2178459,0.2192274,0.2205863,0.2219233,0.2232389,0.2245337,0.2258085,0.2270638,0.2283001,0.229518,0.230718,0.2319006,0.2330662,0.2342153,0.2353484,0.2364657,0.2375677,0.2386549,0.2397276,0.2407861,0.2418309,0.2428622,0.2438805,0.2448859,0.2458788,0.2468594,0.2478281,0.2487851,0.2497307,0.2506652,0.2515888,0.2525018,0.2534043,0.2542966,0.2551789,0.2560515,0.2569145,0.2577681,0.2586125,0.2594479,0.2602745,0.2610925,0.2619021,0.2627033,0.2634964,0.2642815,0.2650589,0.2658285,0.2665906,0.2673452,0.2680927,0.268833,0.2695663,0.2702928,0.2710125,0.2717256,0.2724322,0.2731324,0.2738263,0.274514,0.2751956,0.2758713,0.2765411,0.2772051,0.2778635,0.2785163,0.2791636,0.2798055,0.280442,0.2810734,0.2816995,0.2823206,0.2829368,0.2835479,0.2841543,0.2847559,0.2853528,0.2859451,0.2865329,0.2871161,0.2876949,0.2882694,0.2888395,0.2894055,0.2899672,0.2905249,0.2910785,0.2916281,0.2921738,0.2927156,0.2932535,0.2937877,0.2943181,0.2948449,0.295368,0.2958875,0.2964036,0.2969161,0.2974252,0.2979308,0.2984332,0.2989322,0.2994279,0.2999204,0.3004098,0.3008959,0.301379,0.301859,0.302336,0.30281,0.303281,0.3037491,0.3042143,0.3046767,0.3051362,0.305593,0.306047,0.3064983,0.3069468,0.3073928,0.3078361,0.3082768,0.308715,0.3091505,0.3095836,0.3100142,0.3104424,0.3108681,0.3112915,0.3117124,0.312131,0.3125473,0.3129613,0.313373,0.3137825,0.3141897,0.3145947,0.3149976,0.3153982,0.3157968,0.3161933,0.3165876,0.3169799,0.3173702,0.3177584,0.3181446,0.3185288,0.3189111,0.3192914,0.3196698,0.3200463,0.3204209,0.3207936,0.3211645,0.3215335,0.3219007,0.3222661,0.3226297,0.3229916,0.3233517,0.3237101,0.3240668,0.3244218,0.324775,0.3251267,0.3254766,0.3258249,0.3261716,0.3265167,0.3268602,0.3272021,0.3275425,0.3278813,0.3282186,0.3285543,0.3288885,0.3292213,0.3295525,0.3298823,0.3302106,0.3305375,0.3308629,0.3311869,0.3315095,0.3318307,0.3321506,0.332469,0.3327861,0.3331018,0.3334162,0.3337293,0.3340411,0.3343515,0.3346606,0.3349685,0.3352751,0.3355804,0.3358845,0.3361873,0.3364889,0.3367893,0.3370884,0.3373863,0.3376831,0.3379787,0.338273,0.3385662,0.3388583,0.3391492,0.339439,0.3397276,0.3400151,0.3403015,0.3405868,0.340871,0.3411541,0.3414361,0.341717};
    const float wave_shape_tube_12au7 [513] = {-0.01758699,-0.01578921,-0.01399054,-0.01219097,-0.0103905,-0.008589149,-0.006786915,-0.004983807,-0.00317983,-0.00137499,0.0004307067,0.002237256,0.004044652,0.005852886,0.007661953,0.009471844,0.01128255,0.01309408,0.0149064,0.01671953,0.01853345,0.02034815,0.02216364,0.0239799,0.02579692,0.0276147,0.02943323,0.0312525,0.03307251,0.03489325,0.03671471,0.03853688,0.04035977,0.04218335,0.04400762,0.04583257,0.04765821,0.0494845,0.05131146,0.05313907,0.05496732,0.05679621,0.05862572,0.06045585,0.06228659,0.06411794,0.06594988,0.06778239,0.06961549,0.07144915,0.07328337,0.07511814,0.07695345,0.07878928,0.08062564,0.0824625,0.08429988,0.08613774,0.08797608,0.0898149,0.09165418,0.09349392,0.09533409,0.0971747,0.09901573,0.1008572,0.102699,0.1045412,0.1063839,0.1082269,0.1100702,0.1119139,0.1137579,0.1156023,0.1174469,0.1192919,0.1211372,0.1229827,0.1248285,0.1266746,0.1285209,0.1303675,0.1322142,0.1340612,0.1359084,0.1377558,0.1396033,0.141451,0.1432988,0.1451468,0.1469949,0.1488431,0.1506914,0.1525398,0.1543882,0.1562367,0.1580852,0.1599338,0.1617824,0.1636309,0.1654795,0.167328,0.1691765,0.1710249,0.1728733,0.1747216,0.1765697,0.1784178,0.1802657,0.1821135,0.1839611,0.1858085,0.1876557,0.1895028,0.1913496,0.1931961,0.1950424,0.1968884,0.1987342,0.2005796,0.2024247,0.2042695,0.2061139,0.2079579,0.2098016,0.2116448,0.2134876,0.21533,0.2171719,0.2190133,0.2208543,0.2226947,0.2245346,0.2263739,0.2282127,0.2300509,0.2318885,0.2337254,0.2355617,0.2373974,0.2392324,0.2410666,0.2429002,0.244733,0.2465651,0.2483964,0.2502269,0.2520565,0.2538854,0.2557133,0.2575405,0.2593667,0.2611919,0.2630163,0.2648397,0.2666621,0.2684835,0.2703039,0.2721232,0.2739415,0.2757587,0.2775747,0.2793897,0.2812035,0.2830161,0.2848275,0.2866377,0.2884467,0.2902544,0.2920608,0.2938659,0.2956696,0.2974721,0.299273,0.3010727,0.3028708,0.3046675,0.3064628,0.3082565,0.3100486,0.3118393,0.3136283,0.3154156,0.3172013,0.3189853,0.3207676,0.3225481,0.3243268,0.3261037,0.3278786,0.3296516,0.3314226,0.3331916,0.3349584,0.336723,0.3384854,0.3402454,0.3420029,0.3437579,0.3455102,0.3472597,0.3490062,0.3507496,0.3524896,0.3542261,0.3559587,0.3576872,0.3594112,0.3611304,0.3628443,0.3645525,0.3662544,0.3679494,0.3696367,0.3713155,0.372985,0.3746441,0.3762917,0.3779266,0.3795475,0.3811529,0.3827412,0.3843105,0.3858593,0.3873857,0.3888874,0.3903627,0.3918097,0.3932265,0.3946113,0.3959624,0.3972785,0.3985582,0.3998005,0.4010047,0.4021703,0.4032969,0.4043847,0.4054341,0.4064457,0.4074199,0.4083579,0.4092607,0.4101292,0.4109648,0.4117688,0.4125422,0.4132865,0.414003,0.414693,0.4153577,0.4159985,0.4166163,0.4172125,0.417788,0.4183438,0.4188811,0.4194005,0.4199031,0.4203897,0.4208611,0.4213181,0.4217613,0.4221914,0.4226091,0.4230148,0.4234092,0.4237928,0.4241661,0.4245294,0.4248834,0.4252283,0.4255646,0.4258927,0.4262128,0.4265254,0.4268307,0.4271291,0.4274206,0.4277058,0.4279848,0.4282578,0.4285251,0.4287868,0.4290433,0.4292946,0.429541,0.4297826,0.4300196,0.4302521,0.4304804,0.4307044,0.4309245,0.4311407,0.4313531,0.4315619,0.4317671,0.431969,0.4321674,0.4323627,0.4325549,0.432744,0.4329301,0.4331135,0.433294,0.4334718,0.433647,0.4338197,0.4339898,0.4341576,0.4343229,0.434486,0.4346468,0.4348055,0.434962,0.4351165,0.4352689,0.4354194,0.4355679,0.4357146,0.4358594,0.4360025,0.4361438,0.4362833,0.4364212,0.4365575,0.4366922,0.4368253,0.4369569,0.437087,0.4372156,0.4373428,0.4374686,0.437593,0.4377161,0.4378378,0.4379583,0.4380775,0.4381955,0.4383122,0.4384277,0.4385422,0.4386554,0.4387675,0.4388785,0.4389884,0.4390973,0.4392051,0.4393119,0.4394177,0.4395225,0.4396263,0.4397292,0.4398311,0.4399322,0.4400323,0.4401315,0.4402299,0.4403273,0.440424,0.4405198,0.4406148,0.440709,0.4408024,0.4408951,0.4409869,0.441078,0.4411684,0.441258,0.4413469,0.4414352,0.4415227,0.4416095,0.4416956,0.4417811,0.441866,0.4419501,0.4420336,0.4421166,0.4421989,0.4422805,0.4423616,0.4424421,0.442522,0.4426014,0.4426801,0.4427583,0.442836,0.4429131,0.4429896,0.4430656,0.4431411,0.4432161,0.4432906,0.4433646,0.4434381,0.4435111,0.4435835,0.4436556,0.4437271,0.4437982,0.4438688,0.443939,0.4440088,0.4440781,0.4441469,0.4442153,0.4442833,0.4443509,0.444418,0.4444847,0.4445511,0.444617,0.4446825,0.4447477,0.4448124,0.4448768,0.4449407,0.4450044,0.4450676,0.4451305,0.445193,0.4452551,0.4453169,0.4453784,0.4454395,0.4455002,0.4455606,0.4456207,0.4456805,0.4457399,0.445799,0.4458578,0.4459162,0.4459743,0.4460322,0.4460897,0.4461469,0.4462039,0.4462605,0.4463168,0.4463728,0.4464285,0.446484,0.4465392,0.4465941,0.4466487,0.446703,0.446757,0.4468108,0.4468643,0.4469176,0.4469706,0.4470233,0.4470758,0.447128,0.44718,0.4472317,0.4472832,0.4473344,0.4473854,0.4474361,0.4474866,0.4475369,0.4475869,0.4476367,0.4476863,0.4477356,0.4477847,0.4478336,0.4478823,0.4479307,0.4479789,0.4480269,0.4480747,0.4481223,0.4481697,0.4482169,0.4482638,0.4483106,0.4483571,0.4484034,0.4484496,0.4484955,0.4485413,0.4485868,0.4486322,0.4486774,0.4487223,0.4487671,0.4488117,0.4488561,0.4489004,0.4489444,0.4489883,0.449032,0.4490755,0.4491188,0.449162,0.449205,0.4492477,0.4492904,0.4493329,0.4493752,0.4494173,0.4494593,0.4495011,0.4495427,0.4495842,0.4496255,0.4496666,0.4497076,0.4497485};
    const float wave_shape_tube_kt88 [513] = {0.2682458,0.2704184,0.2725929,0.2747693,0.2769477,0.279128,0.2813103,0.2834946,0.2856808,0.2878689,0.2900591,0.2922512,0.2944454,0.2966415,0.2988396,0.3010398,0.3032419,0.305446,0.3076522,0.3098604,0.3120706,0.3142828,0.3164971,0.3187135,0.3209319,0.3231523,0.3253749,0.3275995,0.3298261,0.3320549,0.3342857,0.3365187,0.3387537,0.3409909,0.3432302,0.3454716,0.3477151,0.3499608,0.3522086,0.3544585,0.3567106,0.3589649,0.3612214,0.36348,0.3657408,0.3680038,0.370269,0.3725365,0.3748061,0.3770779,0.379352,0.3816283,0.3839069,0.3861877,0.3884707,0.3907561,0.3930437,0.3953336,0.3976258,0.3999203,0.4022171,0.4045163,0.4068177,0.4091215,0.4114276,0.4137362,0.416047,0.4183603,0.4206759,0.4229939,0.4253143,0.4276371,0.4299623,0.43229,0.4346201,0.4369526,0.4392876,0.4416251,0.4439651,0.4463075,0.4486525,0.4509999,0.4533499,0.4557024,0.4580575,0.460415,0.4627752,0.465138,0.4675033,0.4698713,0.4722418,0.4746149,0.4769907,0.4793692,0.4817503,0.484134,0.4865205,0.4889096,0.4913015,0.4936961,0.4960934,0.4984935,0.5008963,0.5033019,0.5057102,0.5081214,0.5105354,0.5129523,0.5153719,0.5177944,0.5202199,0.5226482,0.5250793,0.5275134,0.5299504,0.5323904,0.5348334,0.5372792,0.5397282,0.5421801,0.5446351,0.547093,0.5495541,0.5520182,0.5544854,0.5569558,0.5594292,0.5619058,0.5643856,0.5668685,0.5693547,0.571844,0.5743366,0.5768325,0.5793316,0.581834,0.5843397,0.5868488,0.5893612,0.591877,0.5943962,0.5969188,0.5994447,0.6019742,0.6045072,0.6070436,0.6095836,0.6121271,0.6146741,0.6172248,0.619779,0.6223369,0.6248984,0.6274636,0.6300325,0.6326051,0.6351815,0.6377616,0.6403455,0.6429332,0.6455249,0.6481203,0.6507196,0.6533229,0.6559301,0.6585413,0.6611564,0.6637756,0.6663988,0.6690261,0.6716574,0.6742929,0.6769325,0.6795763,0.6822243,0.6848766,0.6875331,0.6901938,0.6928588,0.6955282,0.6982019,0.70088,0.7035625,0.7062494,0.7089407,0.7116366,0.7143369,0.7170418,0.7197511,0.722465,0.7251835,0.7279066,0.7306343,0.7333667,0.7361037,0.7388453,0.7415916,0.7443426,0.7470983,0.7498586,0.7526237,0.7553934,0.7581679,0.7609469,0.7637308,0.7665192,0.7693123,0.77211,0.7749123,0.7777192,0.7805305,0.7833464,0.7861665,0.7889912,0.79182,0.794653,0.7974901,0.8003312,0.8031762,0.8060248,0.8088771,0.8117326,0.8145915,0.8174533,0.8203179,0.8231849,0.8260542,0.8289253,0.8317978,0.8346715,0.8375458,0.8404201,0.8432938,0.8461663,0.8490366,0.8519037,0.8547661,0.8576221,0.8604693,0.8633045,0.866123,0.8689183,0.8716813,0.8743991,0.877054,0.8796237,0.8820801,0.8843948,0.8865418,0.8885034,0.890273,0.8918551,0.893263,0.8945144,0.8956289,0.896625,0.8975194,0.8983264,0.8990589,0.8997273,0.9003403,0.9009053,0.9014281,0.9019141,0.9023674,0.9027918,0.9031904,0.9035658,0.9039204,0.9042561,0.9045748,0.9048779,0.9051668,0.9054427,0.9057066,0.9059595,0.9062021,0.9064353,0.9066595,0.9068757,0.907084,0.9072853,0.9074799,0.9076681,0.9078504,0.9080271,0.9081985,0.908365,0.9085267,0.908684,0.908837,0.9089859,0.9091311,0.9092726,0.9094106,0.9095452,0.9096768,0.9098053,0.9099309,0.9100537,0.9101738,0.9102914,0.9104065,0.9105194,0.9106299,0.9107382,0.9108444,0.9109486,0.9110509,0.9111513,0.9112498,0.9113466,0.9114417,0.9115352,0.9116271,0.9117174,0.9118063,0.9118937,0.9119797,0.9120644,0.9121478,0.9122298,0.9123107,0.9123904,0.9124688,0.9125462,0.9126224,0.9126976,0.9127716,0.9128447,0.9129168,0.912988,0.9130582,0.9131274,0.9131958,0.9132633,0.91333,0.9133958,0.9134609,0.913525,0.9135885,0.9136512,0.9137132,0.9137744,0.9138349,0.9138948,0.913954,0.9140124,0.9140703,0.9141275,0.9141841,0.9142401,0.9142955,0.9143503,0.9144046,0.9144583,0.9145114,0.914564,0.9146161,0.9146677,0.9147187,0.9147692,0.9148193,0.9148689,0.914918,0.9149666,0.9150149,0.9150626,0.9151099,0.9151568,0.9152033,0.9152493,0.915295,0.9153402,0.9153851,0.9154295,0.9154736,0.9155173,0.9155607,0.9156036,0.9156463,0.9156885,0.9157304,0.915772,0.9158132,0.9158542,0.9158947,0.915935,0.915975,0.9160146,0.916054,0.916093,0.9161317,0.9161702,0.9162083,0.9162462,0.9162838,0.9163211,0.9163582,0.9163949,0.9164314,0.9164677,0.9165037,0.9165394,0.916575,0.9166102,0.9166452,0.91668,0.9167145,0.9167488,0.9167829,0.9168167,0.9168503,0.9168836,0.9169168,0.9169497,0.9169825,0.917015,0.9170474,0.9170794,0.9171114,0.9171431,0.9171746,0.9172059,0.917237,0.917268,0.9172987,0.9173293,0.9173596,0.9173898,0.9174198,0.9174497,0.9174793,0.9175087,0.917538,0.9175672,0.9175962,0.917625,0.9176536,0.9176821,0.9177104,0.9177385,0.9177665,0.9177943,0.917822,0.9178495,0.9178769,0.9179041,0.9179313,0.9179582,0.917985,0.9180116,0.9180381,0.9180645,0.9180907,0.9181168,0.9181427,0.9181685,0.9181942,0.9182198,0.9182452,0.9182705,0.9182957,0.9183207,0.9183456,0.9183704,0.9183951,0.9184196,0.918444,0.9184684,0.9184926,0.9185166,0.9185405,0.9185644,0.9185881,0.9186117,0.9186352,0.9186586,0.9186819,0.918705,0.9187281,0.918751,0.9187739,0.9187966,0.9188192,0.9188418,0.9188642,0.9188865,0.9189088,0.9189309,0.9189529,0.9189748,0.9189967,0.9190184,0.91904,0.9190616,0.9190831,0.9191044,0.9191257,0.9191468,0.9191679,0.9191889,0.9192098,0.9192306,0.9192514,0.919272,0.9192926,0.919313,0.9193334,0.9193537,0.9193739,0.9193941,0.9194141};
    const float wave_shape_tube_12ax7_1025 [1025]  = {-0.9998356,-0.9998321,-0.9998285,-0.9998249,-0.9998211,-0.9998172,-0.9998131,-0.999809,-0.9998046,-0.9998002,-0.9997956,-0.9997908,-0.9997859,-0.9997808,-0.9997756,-0.9997702,-0.9997646,-0.9997588,-0.9997528,-0.9997466,-0.9997402,-0.9997337,-0.9997269,-0.9997199,-0.9997126,-0.9997051,-0.9996973,-0.9996893,-0.9996811,-0.9996725,-0.9996637,-0.9996545,-0.9996451,-0.9996354,-0.9996254,-0.999615,-0.9996043,-0.9995932,-0.9995818,-0.99957,-0.9995577,-0.9995452,-0.9995321,-0.9995187,-0.9995048,-0.9994904,-0.9994756,-0.9994603,-0.9994445,-0.9994282,-0.9994113,-0.9993939,-0.9993759,-0.9993573,-0.9993382,-0.9993184,-0.9992979,-0.9992768,-0.999255,-0.9992325,-0.9992092,-0.9991852,-0.9991604,-0.9991348,-0.9991084,-0.999081,-0.9990528,-0.9990237,-0.9989937,-0.9989626,-0.9989306,-0.9988975,-0.9988633,-0.9988281,-0.9987917,-0.9987541,-0.9987153,-0.9986753,-0.998634,-0.9985913,-0.9985473,-0.9985018,-0.9984549,-0.9984065,-0.9983565,-0.998305,-0.9982517,-0.9981968,-0.9981401,-0.9980816,-0.9980212,-0.997959,-0.9978947,-0.9978284,-0.9977599,-0.9976894,-0.9976166,-0.9975415,-0.997464,-0.9973841,-0.9973016,-0.9972166,-0.997129,-0.9970385,-0.9969453,-0.9968491,-0.9967499,-0.9966477,-0.9965422,-0.9964335,-0.9963214,-0.9962059,-0.9960868,-0.995964,-0.9958375,-0.995707,-0.9955727,-0.9954342,-0.9952915,-0.9951445,-0.994993,-0.9948369,-0.9946762,-0.9945106,-0.9943401,-0.9941645,-0.9939836,-0.9937974,-0.9936056,-0.9934081,-0.9932048,-0.9929955,-0.9927801,-0.9925584,-0.9923303,-0.9920956,-0.9918541,-0.9916056,-0.99135,-0.9910871,-0.9908168,-0.9905387,-0.9902529,-0.9899589,-0.9896568,-0.9893463,-0.9890271,-0.9886991,-0.988362,-0.9880158,-0.98766,-0.9872945,-0.9869192,-0.9865337,-0.986138,-0.9857317,-0.9853147,-0.9848867,-0.9844475,-0.9839969,-0.9835346,-0.9830605,-0.9825742,-0.9820755,-0.9815643,-0.9810402,-0.980503,-0.9799525,-0.9793884,-0.9788105,-0.9782187,-0.9776124,-0.9769915,-0.9763558,-0.9757051,-0.9750391,-0.9743575,-0.9736603,-0.9729471,-0.9722176,-0.9714716,-0.9707089,-0.9699293,-0.9691325,-0.9683182,-0.9674864,-0.9666366,-0.9657687,-0.9648825,-0.9639778,-0.9630542,-0.9621117,-0.9611499,-0.9601685,-0.9591675,-0.9581466,-0.9571057,-0.9560446,-0.954963,-0.9538608,-0.9527378,-0.9515938,-0.9504287,-0.9492422,-0.9480343,-0.9468047,-0.9455533,-0.9442799,-0.9429844,-0.9416666,-0.9403264,-0.9389637,-0.9375783,-0.9361702,-0.9347389,-0.9332845,-0.9318069,-0.9303061,-0.928782,-0.9272345,-0.9256635,-0.9240688,-0.9224505,-0.9208084,-0.9191425,-0.9174528,-0.9157391,-0.9140013,-0.9122396,-0.9104538,-0.9086438,-0.9068097,-0.9049515,-0.903069,-0.9011623,-0.8992313,-0.8972758,-0.895296,-0.8932921,-0.8912638,-0.8892113,-0.8871346,-0.8850336,-0.8829085,-0.8807591,-0.8785856,-0.876388,-0.8741663,-0.8719205,-0.8696507,-0.867357,-0.8650392,-0.8626977,-0.8603323,-0.8579431,-0.8555301,-0.8530936,-0.8506331,-0.8481492,-0.8456417,-0.8431109,-0.8405568,-0.8379794,-0.8353788,-0.8327552,-0.8301086,-0.827439,-0.8247465,-0.8220314,-0.8192935,-0.8165331,-0.8137501,-0.8109448,-0.8081172,-0.8052673,-0.8023953,-0.7995013,-0.7965854,-0.7936474,-0.7906877,-0.7877063,-0.7847034,-0.781679,-0.7786333,-0.7755664,-0.7724784,-0.7693694,-0.7662394,-0.7630886,-0.7599171,-0.7567251,-0.7535125,-0.7502796,-0.7470264,-0.743753,-0.7404595,-0.7371461,-0.7338128,-0.7304597,-0.727087,-0.7236946,-0.7202827,-0.7168516,-0.7134012,-0.7099317,-0.7064433,-0.7029359,-0.6994097,-0.6958649,-0.6923015,-0.6887197,-0.6851195,-0.681501,-0.6778644,-0.6742097,-0.6705371,-0.6668467,-0.6631386,-0.6594127,-0.6556695,-0.6519088,-0.6481305,-0.644335,-0.6405225,-0.6366929,-0.6328464,-0.6289831,-0.6251031,-0.6212065,-0.6172934,-0.6133639,-0.6094181,-0.6054561,-0.6014779,-0.5974838,-0.5934737,-0.5894479,-0.5854063,-0.5813491,-0.5772763,-0.5731882,-0.5690847,-0.5649658,-0.5608317,-0.5566826,-0.5525185,-0.5483397,-0.5441459,-0.5399376,-0.5357146,-0.5314772,-0.5272254,-0.5229592,-0.5186789,-0.5143844,-0.510076,-0.5057536,-0.5014173,-0.4970673,-0.4927037,-0.4883265,-0.4839357,-0.4795317,-0.4751142,-0.4706835,-0.4662397,-0.4617828,-0.457313,-0.4528304,-0.4483351,-0.4438271,-0.4393066,-0.4347736,-0.4302283,-0.4256707,-0.4211009,-0.4165191,-0.4119253,-0.4073196,-0.4027022,-0.3980731,-0.3934324,-0.3887803,-0.3841168,-0.3794421,-0.3747562,-0.3700592,-0.3653513,-0.3606327,-0.3559033,-0.3511635,-0.3464133,-0.3416527,-0.3368821,-0.3321014,-0.3273109,-0.3225107,-0.317701,-0.3128818,-0.3080534,-0.303216,-0.2983698,-0.2935148,-0.2886515,-0.2837798,-0.2789001,-0.2740125,-0.2691173,-0.2642147,-0.2593051,-0.2543888,-0.249466,-0.244537,-0.2396021,-0.2346618,-0.2297163,-0.2247661,-0.2198115,-0.2148531,-0.2098912,-0.2049264,-0.1999592,-0.19499,-0.1900196,-0.1850484,-0.1800772,-0.1751067,-0.1701375,-0.1651704,-0.1602063,-0.155246,-0.1502904,-0.1453405,-0.1403972,-0.1354616,-0.1305348,-0.1256179,-0.1207122,-0.1158189,-0.1109393,-0.1060748,-0.1012267,-0.09639668,-0.09158609,-0.08679653,-0.0820296,-0.07728693,-0.0725702,-0.06788112,-0.06322179,-0.0585936,-0.05399832,-0.04943768,-0.04491345,-0.04042734,-0.03598107,-0.03157631,-0.02721469,-0.02289781,-0.01862717,-0.01440425,-0.01023041,-0.006106971,-0.002035128,0.001984002,0.005949407,0.009860178,0.01371552,0.01751473,0.02125725,0.02494214,0.02856926,0.03213862,0.03565009,0.03910363,0.04249933,0.04583734,0.04911792,0.05234143,0.05550827,0.05861896,0.06167405,0.06467417,0.06762,0.07051229,0.07335179,0.07613934,0.07887577,0.08156197,0.08419883,0.08678727,0.08932804,0.0918219,0.0942702,0.09667389,0.09903392,0.1013512,0.1036268,0.1058616,0.1080565,0.1102124,0.1123303,0.114411,0.1164554,0.1184645,0.120439,0.1223798,0.1242877,0.1261635,0.128008,0.129822,0.1316062,0.1333613,0.1350877,0.1367865,0.1384583,0.1401037,0.1417236,0.1433183,0.1448886,0.1464351,0.1479583,0.1494588,0.1509371,0.1523937,0.1538292,0.1552441,0.1566388,0.1580138,0.1593695,0.1607065,0.1620251,0.1633258,0.164609,0.1658749,0.1671239,0.1683566,0.1695733,0.1707743,0.1719601,0.1731308,0.1742869,0.1754286,0.1765563,0.1776702,0.1787707,0.1798581,0.1809325,0.1819943,0.1830437,0.184081,0.1851064,0.1861202,0.1871225,0.1881137,0.1890939,0.1900632,0.191022,0.1919705,0.1929088,0.1938372,0.1947558,0.1956649,0.1965645,0.1974549,0.1983363,0.1992088,0.2000726,0.2009277,0.2017745,0.202613,0.2034434,0.2042658,0.2050803,0.2058871,0.2066864,0.2074782,0.2082626,0.2090398,0.2098099,0.2105731,0.2113294,0.212079,0.2128219,0.2135584,0.2142884,0.2150122,0.2157297,0.2164411,0.2171465,0.2178459,0.2185396,0.2192274,0.2199097,0.2205863,0.2212575,0.2219233,0.2225837,0.2232389,0.2238888,0.2245337,0.2251736,0.2258085,0.2264386,0.2270638,0.2276843,0.2283001,0.2289114,0.229518,0.2301202,0.230718,0.2313115,0.2319006,0.2324855,0.2330662,0.2336428,0.2342153,0.2347838,0.2353484,0.235909,0.2364657,0.2370186,0.2375677,0.2381131,0.2386549,0.239193,0.2397276,0.2402586,0.2407861,0.2413102,0.2418309,0.2423482,0.2428622,0.243373,0.2438805,0.2443847,0.2448859,0.2453838,0.2458788,0.2463706,0.2468594,0.2473452,0.2478281,0.248308,0.2487851,0.2492593,0.2497307,0.2501993,0.2506652,0.2511283,0.2515888,0.2520466,0.2525018,0.2529543,0.2534043,0.2538517,0.2542966,0.254739,0.2551789,0.2556164,0.2560515,0.2564842,0.2569145,0.2573424,0.2577681,0.2581914,0.2586125,0.2590313,0.2594479,0.2598623,0.2602745,0.2606846,0.2610925,0.2614983,0.2619021,0.2623037,0.2627033,0.2631009,0.2634964,0.26389,0.2642815,0.2646712,0.2650589,0.2654446,0.2658285,0.2662105,0.2665906,0.2669688,0.2673452,0.2677199,0.2680927,0.2684637,0.268833,0.2692005,0.2695663,0.2699304,0.2702928,0.2706535,0.2710125,0.2713699,0.2717256,0.2720797,0.2724322,0.2727831,0.2731324,0.2734801,0.2738263,0.2741709,0.274514,0.2748556,0.2751956,0.2755342,0.2758713,0.2762069,0.2765411,0.2768738,0.2772051,0.277535,0.2778635,0.2781906,0.2785163,0.2788406,0.2791636,0.2794852,0.2798055,0.2801244,0.280442,0.2807584,0.2810734,0.2813871,0.2816995,0.2820107,0.2823206,0.2826293,0.2829368,0.2832429,0.2835479,0.2838517,0.2841543,0.2844557,0.2847559,0.285055,0.2853528,0.2856495,0.2859451,0.2862396,0.2865329,0.2868251,0.2871161,0.2874061,0.2876949,0.2879827,0.2882694,0.288555,0.2888395,0.289123,0.2894055,0.2896869,0.2899672,0.2902466,0.2905249,0.2908022,0.2910785,0.2913538,0.2916281,0.2919015,0.2921738,0.2924452,0.2927156,0.2929851,0.2932535,0.2935211,0.2937877,0.2940534,0.2943181,0.2945819,0.2948449,0.2951069,0.295368,0.2956282,0.2958875,0.296146,0.2964036,0.2966602,0.2969161,0.297171,0.2974252,0.2976784,0.2979308,0.2981824,0.2984332,0.2986831,0.2989322,0.2991804,0.2994279,0.2996746,0.2999204,0.3001655,0.3004098,0.3006532,0.3008959,0.3011379,0.301379,0.3016194,0.301859,0.3020979,0.302336,0.3025734,0.30281,0.3030459,0.303281,0.3035154,0.3037491,0.3039821,0.3042143,0.3044459,0.3046767,0.3049068,0.3051362,0.3053649,0.305593,0.3058203,0.306047,0.306273,0.3064983,0.3067229,0.3069468,0.3071702,0.3073928,0.3076148,0.3078361,0.3080568,0.3082768,0.3084962,0.308715,0.3089331,0.3091505,0.3093674,0.3095836,0.3097993,0.3100142,0.3102286,0.3104424,0.3106556,0.3108681,0.3110801,0.3112915,0.3115022,0.3117124,0.311922,0.312131,0.3123395,0.3125473,0.3127546,0.3129613,0.3131674,0.313373,0.313578,0.3137825,0.3139863,0.3141897,0.3143924,0.3145947,0.3147964,0.3149976,0.3151982,0.3153982,0.3155978,0.3157968,0.3159953,0.3161933,0.3163907,0.3165876,0.3167841,0.3169799,0.3171753,0.3173702,0.3175645,0.3177584,0.3179517,0.3181446,0.318337,0.3185288,0.3187202,0.3189111,0.3191015,0.3192914,0.3194808,0.3196698,0.3198583,0.3200463,0.3202338,0.3204209,0.3206075,0.3207936,0.3209793,0.3211645,0.3213492,0.3215335,0.3217173,0.3219007,0.3220836,0.3222661,0.3224481,0.3226297,0.3228109,0.3229916,0.3231719,0.3233517,0.3235312,0.3237101,0.3238887,0.3240668,0.3242445,0.3244218,0.3245986,0.324775,0.3249511,0.3251267,0.3253019,0.3254766,0.325651,0.3258249,0.3259985,0.3261716,0.3263444,0.3265167,0.3266887,0.3268602,0.3270314,0.3272021,0.3273725,0.3275425,0.3277121,0.3278813,0.3280501,0.3282186,0.3283866,0.3285543,0.3287216,0.3288885,0.3290551,0.3292213,0.3293871,0.3295525,0.3297176,0.3298823,0.3300466,0.3302106,0.3303742,0.3305375,0.3307004,0.3308629,0.3310251,0.3311869,0.3313484,0.3315095,0.3316703,0.3318307,0.3319908,0.3321506,0.33231,0.332469,0.3326277,0.3327861,0.3329442,0.3331018,0.3332592,0.3334162,0.3335729,0.3337293,0.3338853,0.3340411,0.3341964,0.3343515,0.3345062,0.3346606,0.3348147,0.3349685,0.335122,0.3352751,0.3354279,0.3355804,0.3357326,0.3358845,0.3360361,0.3361873,0.3363383,0.3364889,0.3366392,0.3367893,0.336939,0.3370884,0.3372375,0.3373863,0.3375349,0.3376831,0.337831,0.3379787,0.338126,0.338273,0.3384198,0.3385662,0.3387124,0.3388583,0.3390039,0.3391492,0.3392942,0.339439,0.3395834,0.3397276,0.3398715,0.3400151,0.3401584,0.3403015,0.3404443,0.3405868,0.340729,0.340871,0.3410127,0.3411541,0.3412952,0.3414361,0.3415767,0.341717};
  7. #32
    Oct 2019
    16
    @ houtson
    Thank you very much!
  8. #33
    Senior Member ETMoody3's Avatar
    Mar 2014
    New Ulm, Mn
    151
    @ houston, @ jcugnoni
    I just tried out the above posted arrays with the waveshaper and audio shield and like them very much. Thank you.
    Fwiw I got a non-halting error message about the const, once changed to simply float there were no compiler warnings.
    Musically useful.
  9. #34
    Aug 2015
    Scotland
    142
    @etmoody3 - thanks for the feedback
    on the error:
    - I'm using const to place the arrays in flash rather than ram. If you have a few of these large arrays of floats they quickly use up ram that you can use for other things.
    - The waveshaper object expects a float * as argument, when you create the object casting it will make the error go away e.g. waveshape1.shape((float *)wave_shape_tube_12at7, 513);
    I've got a few more waveshaper arrays that might be useful, I'll get them together and post them in a separate post rather than cluttering up this post, cheers, Paul
  10. #35
    Mar 2014
    New Ulm, Mn
    151
    @ houston
    I'm using a teensy 4 , the impact on ram was no problem.
  11. #36
    Sep 2019
    Sevilla, Spain
    28
    Hi, may I ask, how do you guys control the distortion amount? with a mixer or amp before the waveshaper to change the input gain maybe?
    would like to add distortion effect to a project, but I would like to have more control than just changing the saturation type.
    on the error:
    could be using PROGMEM another solution for that?
