Teensy Loader problems
Here's a possible fix. Please give this a try and let me know if it works on your Windows 10 system?
Extract this to Arduino's hardware/tools folder, replacing the existing teensy_post_compile.exe.
Windows 10 Home
Windows 10 Creators Update
Version 1703
OS Build 15063.296
Arduino 1.8.2
Teensyduino 1.36
Teensy 3.6
Works, thank you.
Hi Paul
I have not installed the latest Win10 Pro update and cannot get the loader to run without having to push the reset button. I have upgraded Teensyduino to the latest version (1.36) on Arduino 1.69. I have the problem with the new version of teensy_post_compile.exe you posted as well as teensy_loader.cli.exe (latest). If I push the button in either case it loads and reboots as it should.
It was working fine with VS2015/Visual Micro (i.e. no button push required) but I don't know if it is working now since my setup was trashed with the upgrades and I need to repair it before I can get back to where i was to test.
Hope a fix for this is forthcoming as i need to do "automated" programming in a production environment. Thanks
Al
I re-scanned toolchains, etc. and got my setup running again. I can now report that after a build, teensy.exe starts, programs, and reboots without a button push.
The teensy_post_compile.exe and teensy_loader.cli.exe methods work but require a button push.
I am trying to shell out from a C# application to program using either teensy-post_compile.exe or teensy_loader.cli.exe (both latest versions) and neither will work without a push of the button. I tried the same in a command window with the same results. I am running Win 10 Home and have all but the latest "Creator's Update" installed.
Do I need the Win 10 update to make it work or is something else wrong?
BTW, everything works fine when I compile and program from VS2015/Visual Micro.
Thanks a lot Paul, I try it in a min.
Btw I just discovered that on Firefox 53.0.3 (32 bit) / Win10 cannot see any attachment in this thread, ouch. Had to use Microsoft Edge
Any ideas on how I can fix my problem?
Hi
looks like I have to deal with the problem described in post #1.
Windows 10 pro 64-bit
Teensy Loader 1.40 and Teensyduino probably 1.40 (where can I find version info ?)
TeensyLoader needs reset button. Serial via USB does not work. Tested with Blink with some serial.print's etc.No output on serial monitor.
I tested the same sketch on a Linux machine. Worked as expected.
I am at a loss and need help.
P.S. problem solved - https://forum.pjrc.com/threads/47503-Win10-USB-Serial-yellow-triangle?p=158582&viewfull=1#post158582 helped
When I run teensy_loader_cli.exe --mcumk20dx256 blink.ino.hex
I get:
Unable to open device
However, If I press the button, it finds the loader and programs.
How to get rid of the need to press button? I am using Windows 7 Professional and can program reliably with the GUI tool (without button press).
I get:
Is the prior sketch compiled with USB active? If not the loader exe can't get the Teensy into bootloader mode without the button.
Buttonless programming
I compiled the code with Arduino 1.8.4 (Teensyduino 1.29) IDE. I do development with USB emulating COM4 for loading the code and UART access. I ran the CLI program in a console window without IDE (no difference with IDE open too) running.
Another observation: The Teensy Loader 1.39 that pops up automatically when I run Upload from IDE always has the Operation->Program and Reboot options grayed out. This is with the Auto (Automatic Mode) button On and Off. But I can always Upload code without pressing the white button on Teensy 3.2
The IDE is doing something right that the command line program is missing. I tried after rebooting my laptop to wipe away any accumulated sins too.
