I am using the audio library for my project. But I have a problem. Many people in the forums suggested that when using audio library A0-A14 will not be available to use so I am using A15,16,17. But the value I get from A15,A16,A17 maxout when I use the audio library.Without the audio library they dont max out. Actually when I reset teensy it seems to be floating but when I move the teensy pcb a bit it maxes out. This problem is not there when I am not using the audio library. What is wierd is only when using audio library when I move the board the analogRead gives maxed out value. Not when not using audio library.What shall I do?
