I am trying to run 2 RFID-RC522s on a Teensy 3.2. Works really well with one reader, as soon as I add in the second reader, I get an error message*
I have clk, MISO, MISI, GND, and 3.3V all connected, and the reset and cs pins individually connected to each RFID. I noticed on an oscilloscope that the MISO line drops to 1V when the second RFID is connected. Do I need to hold the reset line low for the tags that I am not reading, I tried that but couldn't figure out how to do that.
*Error Message
Reader 0: Firmware Version: 0x0 = (unknown)
WARNING: Communication failure, is the MFRC522 properly connected?
Reader 1: Firmware Version: 0x0 = (unknown)
*Error Message
#include <MFRC522.h>
#define RST_1_PIN 0
#define RST_2_PIN 1
#define SS_1_PIN 4
#define SS_2_PIN 5
#define NR_OF_READERS 2
byte ssPins[] = {SS_1_PIN, SS_2_PIN};
byte rstPins[] = {RST_1_PIN, RST_2_PIN};
MFRC522 mfrc522[NR_OF_READERS]; // Create MFRC522 instance.
* Initialize.
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
for (uint8_t reader = 0; reader < NR_OF_READERS; reader++) {
mfrc522[reader].PCD_Init(ssPins[reader], rstPins[reader]); // Init each MFRC522 card
Serial.print(F("Reader "));
Serial.print(reader);
Serial.print(F(": "));
mfrc522[reader].PCD_DumpVersionToSerial();
* Main loop.
// Look for new cards
if (mfrc522[reader].PICC_IsNewCardPresent() && mfrc522[reader].PICC_ReadCardSerial()) {
// Show some details of the PICC (that is: the tag/card)
Serial.print(F(": Card UID:"));
dump_byte_array(mfrc522[reader].uid.uidByte, mfrc522[reader].uid.size);
Serial.print(F("PICC type: "));
MFRC522::PICC_Type piccType = mfrc522[reader].PICC_GetType(mfrc522[reader].uid.sak);
Serial.println(mfrc522[reader].PICC_GetTypeName(piccType));
// Halt PICC
mfrc522[reader].PICC_HaltA();
// Stop encryption on PCD
mfrc522[reader].PCD_StopCrypto1();
} //if (mfrc522[reader].PICC_IsNewC
} //for(uint8_t reader
* Helper routine to dump a byte array as hex values to Serial.
void dump_byte_array(byte *buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
Serial.print(buffer[i] < 0x10 ? " 0" : " ");
Serial.print(buffer[i], HEX);
