Page 1 of 8 1 2 3 ... LastLast
Results 1 to 25 of 184
Thread: Suggest next Teensy with Cortex M7
    I suggest next Teensy with a Cortex M7. Now I'm working with Atmel SAM S70, 300Mhz, 1Mb flash, and its really fantastic, cheaper than Kinetis MK66, practically half price. Also soon ST will release STM32H7, 400 Mhz, the top or Cortex Mx. Kinetis are the most expensive ARM microcontrollers, cheaper ST or Atmel.
    I think better do not work with Arduino. For S70, Atmel Studio. And for ST, SW4STM32 with Cubemx, is perfect.
    And finally I suggest add access to Debug with SWD.
    I would like to see CAN FD in the next Teensy.
    Dec 2016
    Montreal, Canada
    3,112
    if you drop arduino support, the userbase will drop too lol
    Dec 2014
    262
    There's a lot of work invested in the Teensyduino code base that is specific to Kinetis chips. There's also the "magic boot button" that lets us use the full chip, because the secondary chip takes care of bootloading. Thus, I think it would be quite hard for PJRC to switch to another product line, be it Microchip (owns Atmel now) or ST or whatever.
    Secondarily, I'm not sure what the quest for high performance is going for. At some point, just stick a Raspberry Pi Zero W on there; it has HDMI output with a GPU and networking and USB built-in, and it lets you write as much fancy code as you want, running at gigahertz speeds. And it's low cost, too. And if you want to go up from there, there's the Raspberry Pi 3, and all the me-too boards, and even the UP! boards.
    I think Teensy has a great niche in small boards, with "enough" power, "enough" I/O and robustness, and a high quality software stack. Yes, I'd love to see Teensyduino for Visual Studio Code, because I, too, don't like the Arduino IDE. But it looks like it actually wouldn't be hard to write a separate script package that would use the Teensyduino code chain for VS Code, or any other IDE you can run command line tools from. (Which is all of them.)
    Honestly, the most annoying thing about Teensy is that 3.6 isn't 5V tolerant. While the world is 3.3V (and even 2.5V down to 1.2V!) these days, there are tons of existing standards and peripherals that still use 5V. (I imagine the TTL people going from 12V to 5V felt much the same way ...)
    Dec 2016
    Montreal, Canada
    3,112
    Yeah, which is why I chose the T3.5 as an upgrade from my mega2560, because I had alot of 5V I2C devices and 5V expanders, not to mention, the sparkfun canbus shields are 5V devices for the SPI bus.
    At that point, T3.6 wasnt an option, but the flexibility of 5V tolerancy is always a plus
    That and, because of the multiple busses, we can use one bus for 5V devices, and another for 3.3V devices (SPI/I2C) which gives more flexibility
    I am currently using the T3.5 to drive a NEX4100 WDT line high in order to take Warp snapshots in the bsp as the unit is 3.3v. Uart6 is running to the TX/RX of the radio as well for adb console, and when done with the bsp i return the gpio back to an INPUT to deassert the radio which restores reboot functionality in the console.
    My Mega never had the resources to do all of this, but without T 3.5, this wouldnt be possible, at least with my setup
    20,674
    Ok, maybe it's time to drop a hint about future Teensy.... (hope everyone is sitting down)
    This chip is very likely to become the core of Teensy 4.0 sometime in 2018.
    http://www.nxp.com/products/microcon...:IMX-RT-SERIES
    Yes, you're reading that right, a 600 MHz Cortex-M7 is coming!
    Like all semiconductor marketing, some of it needs to be taken with a grain of salt. The "interfaces for" various wireless protocols appear to be only Serial, SPI, I2C which we already have. As far as I know, there won't be any actual wireless built into this new chip. Every semiconductor company is under extreme pressure to call anything "Internet Of Things", so be skeptical on that stuff.
    Their prediction of October this year should also be viewed with extreme skepticism. Historically they've been many months late on almost all other new chips, and even at "release" they've usually taken time before parts actually became available at even moderate volume (more than just a few samples). For comparison, it was just over 1 year from when the K66 was announced to when we were able to finally release Teensy 3.6. This new chip is a major step for NXP, so if anything I'd expect the delay to be even longer.
    We're going to call this one 4.0 because it's not directly compatible. For starters, the analog features will be less than we have now. It almost certainly will not be 5V tolerant. Pretty much no new chips are anymore, especially ones using process nodes capable of these speeds. It also doesn't have flash memory built in, so we'll be using a QSPI flash chip, like the Espressif ESP chips do.
    It does have some absolutely incredible features. The 512K of internal RAM can be used in Cortex-M7 fast TCM mode. If you compare with ST and Atmel, only a small amount can be fast TCM, and their's are only 300-400 MHz, not 600 MHz. NXP's new chip also has a 2G GPU, likely very similar to the fairly basic ones in their iMX6 chips (color space conversion, alpha blending, bitblit, bilinear scaling). We'll get two 480 Mbit/sec USB ports. There's no official word on the FPU yet, but odds are almost certain it'll have both single and double precision.
    Anything more I might know than what's on that web page of course would be under a NDA until the chip is fully released.
    Exciting as this is, please understand it's very likely a long way off. But at least we can see what the future is bringing.
    Germany NRW
    5,679
    Awesome. It will be great for audio or video processing, robotics and way more. 512KB RAM are not too much fo this type of usage, so it would be good if an interface for additional external memory (RAM) is available on the 4.0
    With it's speed and memorysize, "official" availability of an RTOS (with Arduino-compability) / simple multitasking would be on my wishlist.
    I don't really need wlan,ethernet or bluetooth. But I think, an additional little chip for wlan (or, even better, a usb-"driver" for existing wlan-sticks) can help to sell some more 4.0 (or 3.6???)...
    3,297
    Cool
    Cool.
    Yeah, but I have to imagine that the ESP32's and ESP8266's are weighing heavily on everybody's design. But I know that it takes a long time to go from specifications to silicon that works. Right now, at least 1/3 of my time at work is spent in meetings with the hardware folk to come up with specifications that software wants/needs for the next processor. And part of my time is spent hoping the next silicon for the newly announced processor to show up so we can start tuning the compiler.
    Well the marketing blurb does say optional single and double precision. Of course like all marketing blurbs it is subject to changes, and it depends on what the FPU costs whether it makes it into the final Teensy product(s). I know how much things can change, and over the years, I have times where I spent a year in one job and several months in this this job adding a feature that isn't in the final hardware.
    I would hope that some of the variants Teensy uses will have double precision, though for many things, single precision is enough. But if it does support double, hopefully we can eliminate using -fsingle-precision-constant. I know you were in between a rock and a hard place in turning that on, but it would be nice not to have to use it.
    It will be interesting to see if you go with a wildly different pin layout or numbering for Teensy 4.0 as opposed to 3.x. You've done an excellent job in maintaining the majority of pin compatibility between the LC, 3.0, 3.1, 3.2, 3.5, and 3.6. But I can imagine it is growing creaky to keep this compatibility.
    If possible, I would suggest having VUSB, AREF, and VBAT on the main rows of pins rather than inside and on the back. Reset and program also, but those are more special purpose, and they can live as interior pins. But if not, that is also fine.
    It would also be useful to incorporate an on/off mechanical switch to the Teensy (or at least a trace that can be cut, and 2 pins that are next to each other and a normal 0.1" switch can be inserted). Again, if you can't do it, that will be fine.
    Dec 2014
    262
    Ha! Densities are creeping down to 0.35mm. Which seems like total overkill. However, I'd love to see a Teensy with something like the Molex SlimStack breaking out all the signals on the bottom:
    http://www.molex.com/molex/products/...ECEPTACLES.xml
    It adds $3.50 to BOM though... but at least it's not $10 like the Samtecs :-)
    Also, the idea being that female connector on the Teensy and male on whatever breakout board we want to build, makes for less likelihood of shorting out the Teensy.
    Another thing that might be good would be 5V level translators for the "important" I/Os -- one I2C, one SPI, and one UART, perhaps?
    Germany NRW
    5,679
    Quote Originally Posted by jwatte View Post
    Nope, i don't think so. 5V is outdated technology from last century.
    But some small addon-boards with specialized level-translators might be useful for some users (not me).
    149
    If pin config changed, would hope that more consideration given for noise. Aref and analog ground need a little more protection from that evil digital stuff. 600MHz is an order of magnitude greater than what we typically use (22MHz or 44MHz for T3.2). Otherwise, logistics of another pin-out would be significant for some.
    But if that what PJRC's adoring fans want, so be it. Will be that cranky old geezer still using my stash of T3.1s and T3.2s while yelling at the rest of you to get off of my lawn (recently used last 2313).
    Member dauntless89's Avatar
    Jun 2017
    Cedar City, UT
    52
    Are you at liberty to elaborate on this point a little? Perhaps even just a comment on whether it's primarily less capabilities with the ADCs or PWM. Thanks.
    20,674
    Quote Originally Posted by dauntless89 View Post
    Nope, sorry, anything that's not on NXP's public website is covered by NDA. They will publish all the info (unlike certain Chinese chips...) but probably not until the chips are actually for regular sale.
    But just from looking at the "fact sheet", you can see there's no DAC and the ADC is only claimed to be 12 bits.
    139
    I think this makes sense given the noise problem & the target market, and would say that alongside the release of a Cortex M7 it would make sense for the community (or Paul, time permitting) to release a small reference board in the same form factor as the Teensy (perhaps piggybacking the DIO pins with DIO pins set to high impedance) with an ADC/DAC/Reference (2 channels of each with a multiplexer on the ADC to 8-16 pins) with decent software support.
    I'm excited to think about this being released in a few years but I am in the fortunate position that the Teensy 3.6 has just enough horsepower for my most demanding projects.
    Junior Member elfarolab's Avatar
    Dec 2015
    Italy
    13
    Hello all,
    I would like to add few thoughts to this interesting thread:
    not so many are aware of the application differences between a realtime hardware and a Linux OS board with a scheduler, my job is electronic engineer, independent contractor and almost all my new customers, they usually come with the request to implement every kind of products you can imagine with the Raspberry PI and Linux, even for robots, controllers, UAV, all applications typical of the realtime world. This attitude is largely influenced by hackers/makers community, which I support of course, but not beyond the scope of exploration, testing ideas and laboratory to earn knowledge, industrial products requires appropriate design.
    Even if exists a Linux kernel version with a pseudo realtime scheduler, its proper applications are still limited to video/medias processing, VOIP, audio processing, applications typical of a shared OS environment as desktop or industrial appliances. Deep learning or OpenCV are software applications for an high level OS for instance.
    Realtime MCUs are designed for other kind of applications where deterministic interruptions are crucial, GPIO events or timed functions needs to get executed at precise moments, examples are self balancing robots or UAV controllers such as the Pixhawk. Recently BleagleBone came out with a Blue version specific for robotics, the Linux OS is running on the ARM cortex-A8 core but all the realtime stuff get executed inside 2 integrated PRU 32-bit realtime microcontrollers specific for those kind of applications, there is no way to achieve the execution of realtime tasks inside an OS running on a Raspberry PI for instance.
    So different applications require different hardware architectures.
    The Teensy 4.0 aims to improve and expand the design possibilities in the realtime world, maybe with a realtime OS such as NUTTX or FREERTOS, there are many more..
    These days I am designing a device with RTK+PPK GPS capabilities based on Teensy 3.6, it needs to have a maximum acceptable latency in order of the ms, added with other heavy processing of the readings from sensors.
    The future Teensy 4.0 will be useful in my case, because one day I need to add an integrated crypto hardware accelerator in order to support encrypted datastream in realtime and at the same time, to integrate all the features of an UAV controller.
    I feel we are just at the beginning with these high performances realtime MCUs, there are plenty of real world applications for the next Teensy 4.0, applications that finally can be implemented with just a single MCU, so I am happy to hear about this new version.
    Best luck Paul!
    2,365
    So, I do not ask for more info on the chip (I can wait till October, or so)
    I've read
    https://blog.nxp.com/iot/i-mx-rt-ser...rocessors-mcus
    http://www.nxp.com/docs/en/fact-sheet/I.MXRT1050FS.pdf
    so I know the basic features, I'm interested in
    but at which level of your priority list is a T4.0 prototype. I assume you will make a similar beta testing device as you did with T3.6.
    Wow, this is fantastic, I had not read this message and coincidentally a few days ago I was reading about the i.MX RT1020 on the NXP website, to use it in some of my new developments, it also seems interesting the i.MX 233 although this It is older.
    If using an NXP RT in the new Teensy 4.0 would be great, I currently use Teensy 3.6 to test and debug my developments before making custom PCBs with MK66 LQFP and I find it very useful.
    It would be interesting if you can maintain some compatibility between Teensy 3.6 and Teensy 4.0, although I suppose it will be difficult because they look like very different microcontrollers, MK66 vs. i.MX RT.
    I'm following the NXP website on the RT1020, but not yet available, only the RT1050.
    Does anyone know the RT1050 is compatible with RT1020? I guess Teensy 4.0 will install RT1050, so a BGA. If there is software compatibility between RT1050 and RT1020, I will use Teensy 4.0 to develop and test software, and custom boards with RT1020 LQFP.
    Some news about when Teensy 4.0 will be available, price, libraries, compatibility, confirmed that you will use an i.MX RT1050 ...?
    regards
    Dec 2016
    Montreal, Canada
    3,112
    hey the NEX4100 I have, can I cross flash it with that code? LOL
    it contains an i.MX6
    pjrc, turning headunits to arduino systems
    4,196
    Competition for the Raspberry? Better start buying me some level shifters Looks like they are even playing on offering a Low-cost evaluation kit compatible with Arduino™ hardware shields.
    Dec 2014
    262
    Who is the intended customer for that Teensy? I have a hard time filling up the CPU of the 3.5, although I'm out of I/O (again!) Developing applications that use all that power is significant work.
    Also, if less analog, and 3V only, and external flash, and 600 MHz is important to me, I can get it today in a Raspberry Pi Zero W, cheaper than a Teensy. Then I can use all that power to run Python or something instead of C, and be back at 8 bit AVR speeds...
    Seriously, who needs that product? For CPU there's other faster options; MCUs are all about the available I/O. I'd rather have more, smarter, easier to use DMA and multiple quadrature counters and MOAR PINS and perhaps protected memory. (I understand Paul has to work with the chips available; this is as much a lament about the industry as input to next Teensy.)
    Senior Member duff's Avatar
    Las Vegas
    970
    I would love this and I'm sure paul and others would make sure it's very well supported. I like how the promotional material specifically say for guitar pedals, very cool. Also its low power for battery operation applications.
    2,365
    Well, doing some ultrasonic (fs>300kHz) multichannel floating point digital filtering, T3.6 becomes a little bit slow.
    and RPI eats a lot of power
    149
    Same here. Developing with a T3.5 for a calibration bench, and out of I/O, but much flash remaining. Will probably go with two or three T3.2s.
    External memory = noise. So would do serious analog on separate board. External memory, no signal conditioning, high clock rate, media controllers, security systems, etc - this is the stuff of an embedded OS. Schedulers ok, but no want OS. Is running an OS a PJRC design intention?
    Freaking amazing what you kids are stuffing into ICs these days.
  24. #24
    20,674
    Quote Originally Posted by BJB View Post
    No, certainly not anything like Linux is planned.
    However, the recent work on Arduino event programming and planned improvements in SD, USB Host, Ethernet and other libraries are meant to bring much more functionality similar to some of what you get from an OS.
    My current plan is to *not* require an RTOS, but to work towards APIs and reentrant design that can be more easily used with an RTOS.
  25. #25
    Dec 2016
    Montreal, Canada
    3,112
    i try not to use the teensy pins unless for 3.3v devices, I push the rest on the external 5V mcp23s17s spi bus @ 8mhz
