Being a noob as I am, it's probably not smart for me to get too close to the bleeding edge, but I have a strong desire to do a project that requires controlling an external device via USB commands. The device has an onboard Arduino Nano, and is intended to be connected to a PC or equivalent host, so I assume this means I'd need the Teensy to operate in host mode, my understanding of USB OTG is that it allows a device to be either master or slave, but that wouldn't be necessary in my application once the code is loaded, as in normal operation after the external device is connected, the Teensy would always be the master and the other device always the slave. The data consists of short commands of
I found this: https://forum.pjrc.com/threads/28173-Teensy-3-x-NATIVE-USB-HOST-PREVIEW-AVAILABLE?highlight=usb+otg but have not played with it yet. Is this the best option available? I'm a little unclear as to how could be connected to a PC for development as normal and also to the external device -- hub? My default choice of CPU is the Teensy 3.2 but I'd be open to using 3.5 or 3.6 if it helped to resolve this issue.
I'd appreciate any thoughts or suggestions as to feasibility of what I'd like to do, thanks.
Bob
Bob
