Results 1 to 4 of 4
Thread: Xplane move aircraft
    Apr 2017
    7
    Hi guys,
    Is there any functionality within the teensy plugin to utilise the xplm move aircraft?
    http://www.xsquawkbox.net/xpsdk/medi...MovingThePlane
    i'd like a button that moves the aircraft from say Heathrow to Edinburgh.
    Best regards
    Adam
    20,308
    The Xplane support lets you write to any datarefs. You could try writing to 4 float variables for these datarefs:
    sim/flightmodel/position/latitude
    sim/flightmodel/position/longitude
    sim/flightmodel/position/elevation
    sim/flightmodel/position/y_agl
    To make a button do this, I highly recommend using the Bounce library. Look at File > Examples > Teensy > USB_FlightSim > NavFrequency for an example that uses Bounce to read buttons.
    Hopefully this should be as simple as just writing numbers to those 4 variables when button.fallingEdge() is true. You'll need to know the coordinates for Edinburgh.
    Apr 2017
    7
    Paul.
    Thanks for taking the time to respond, I understood the lat and lon dataref to be read only certainly nothing appears to happen when I try writing to them
    20,308
    Oh, yeah, looks like those are read only. Maybe try asking on Xplane forums if the algorithm or source code for XPLMWorldToLocal is available?
    http://www.xsquawkbox.net/xpsdk/medi...LMWorldToLocal
