Can't List All Directories on SD Card
lerxstrulz
I have 5 directories on my SD card, but for some reason it only finds 4. They are all 8 characters or less. I can access it directly through the code (ex SD.open("/thedir")) but it won't show up in a list. Here is my code:
const int SETTING_ENTRY_MAX = 50;
const int MAX_FILE_COUNT = 99;
int listDirectories(const char *path, char directories[][SETTING_ENTRY_MAX])
   int index = 0;
   File dir = SD.open(path);
   dir.rewindDirectory();
   while(true && index < MAX_FILE_COUNT) {
     File entry = dir.openNextFile();
     if (! entry) {
       // no more files
     if (entry.isDirectory()) {
      // This is hear to print out what it finds
      Serial.print("DIR: ");
      Serial.println(entry.name());
      // Ignore directories that have "~" in the name
       char *ret = strstr(entry.name(), "~");
       if (ret == NULL) {
         strcpy(directories[index], entry.name());
         index++;
     entry.close();
   return index;
char paths[MAX_FILE_COUNT][SETTING_ENTRY_MAX];
char buffer[1024];
// return a list of directories on the card
int count = listDirectories("/", paths);
So if I have 5 directories:
  dir1
  dir2
  dir3
  dir4
  dir5
The list returned is:
  dir1
  dir2
  dir3
  dir4
I've tried increasing the control loop max by 1 and I've changed the directory names and even reformatted the card. All no luck. Any help is appreciated! Thank you!
