Total noob here. I stacked the wiz820io, sd adapter, teensy 3.2, Octows2811. I can run the BasicTest and similar programs from the octo library and the LEDs *do* work and blink from the octo. The wiz820io lights up and blinks, and I can ping the Teensy at the address I set.
However, I can't for the life of me get any of my visual apps using Artnet to make the LEDs light up after I flash over the Artnet sketch (I can ping it properly when it's running the Artnet sketch). In Resolume, I get no signal when using unicast or broadcast with the proper IP. Can't seem to get Madmapper to send, nor TouchDesigner (although I'm probably doing it wrong with TD). I tried directly connecting the ethernet from my laptop to the teensy and making sure the sketch and OSX network is 192.168.2.x to match Teensy (pingable). I tried plugging the teensy build into my home router, still nothing (and still pingable).
I must be doing something wrong, I'm not sure how to start ruling anything out though. Big thanks in advance for any replies.
