Page 1 of 6 1 2 3 ... LastLast
Results 1 to 25 of 140
Thread: Send 1 Sysex message depending on momentary switch State
    May 2017
    102
    Hi guys.
    I am just starting on this Teensy/Arduino thing.
    I have a sketch to send usbmidi joystick for my Korg M3 module. It works for the joystick part. If i only needed that I would have my small midi controller ready, but I also need to send Sysex with 2 push buttons and that is where I am not having success with it.
    The Sysex messages I need to send are dependent on the High (off) or Low (on) state of the momentary switches I have in Digital pins 0 and 1. These on/off states must be controlled by changing sequencialy everytime the buttons are pressed.
    For Pin 0 the messages are:
    in ON state:
    0xF0, 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF7
    in OFF state:
    0xF0, 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF7
    For Pin 1 the messages are:
    in ON state:
    0xF0, 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0B, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF7
    in OFF state:
    0xF0, 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0B, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF7
    I thing there should be Bouce and fallingEdge ou RaisingEdge involved, but for now it is giving me a good fight to succeed.
    This is my sketch with only usbmidi joystick
    // include the ResponsiveAnalogRead library for analog smoothing
    #include <ResponsiveAnalogRead.h>
    // ******CONSTANT VALUES******** - customize code behaviour here!
    // SET THESE FOUR VALUES!
    const int pitchPin = 0; // PIN numbers ** MUST CHANGE!
    const int modPin = 1;
    const int pitchMaxRaw = 1019; // Max reading with full bend up... as raw 10-bit value
    const int modMaxRaw = 1019; // Max reading full mod down
    const int channel = 1; // MIDI channel
    const int MIDIdelay = 5; // will update MIDI only if this many milliseconds have passed
    //******VARIABLES***********
    // data variables and a lagged copy to compare before updating MIDI value
    int pitch;
    int mod;
    int pitchRaw;
    int modRaw;
    int pitchLag;
    int modLag;
    elapsedMillis pitchUpdate;
    elapsedMillis modUpdate;
    // ititialize the ReponsiveAnalogRead objects
    ResponsiveAnalogRead readPitch = {pitchPin,true};
    ResponsiveAnalogRead readMod = {modPin,true};
    getAnalogData();
    while (usbMIDI.read()) {
    //************ANALOG SECTION**************
    void getAnalogData(){
    readPitch.update();
    if(readPitch.hasChanged()) {
    pitchRaw = readPitch.getValue();
    // remap to output data and send if changed and MIDIdelay has lapsed since last update for that parameter
    pitch = map(pitchRaw,4,1019,0,16383);
    pitch = max(pitch,0); // need this now that the bottom isn't zero
    pitch = min(pitch,16383); // cap to avoid overflow
    if (abs(pitch - pitchLag)>0 && pitchUpdate > MIDIdelay ){
    pitchLag = pitch;
    usbMIDI.sendPitchBend( pitch, channel);
    pitchUpdate = 0;
    readMod.update();
    if(readMod.hasChanged()) {
    modRaw = readMod.getValue();
    mod = map(modRaw,4,1019,0,127); // N.B. - map does not limit values
    mod = max(mod,0); // minimum could overflow is modRaw is greater than calabrated
    //mod = min(mod,127);
    if (mod != modLag && modUpdate > MIDIdelay ){ // resolution reduction should be enough wi
    modLag = mod;
    usbMIDI.sendControlChange(1, mod, channel); // CC = 1 is mod wheel in standard MIDI
    modUpdate = 0;
    Can you please guide me on this?
    Oh: I'm using Teensy ++2 and should be receiving a 3.6 this week.
    Thank you
    Apr 2013
    1,874
    Bounce would probably be the easiest way to do it. Have a variable that tracks what step you are at that gets incremented each falling edge and a boolean 'haveSentSysex' that tracks if you have sent the updated counter value yet (keeping buttons asynch from your coms code).
    Would suggest doing some playing just with bounce and the onboard LED to get an idea of how it goes together to make something that toggles (say make LED cycle between three different blink rates), rather than trying to graft it into your existing code straight up.
    May 2017
    102
    Quote Originally Posted by GremlinWrangler View Post
    Thanks GremlinWrangler!
    My problem is writing the code for it. Anyway i will try.
    Once again, thank you.
    Best regards from Portugal,
    Joao
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,090
    Sending short midi messages is itself quite simple (reading data a little less so).
    usbMIDI.sendSysEx(dataLength, data); // SEND
    (I believe the length is exclusive of the status and end bytes... so 14 bytes for yours by my count)
    Reading the current state of pin (HIGH/LOW) is simple enough too... then you build conditional statements to fire the correct message under the current conditions.
    I'm not entirely clear on the desired output.
    Is there any interaction between the two states in their output?
    It sounds like you want note-on/note-off type behavior but with sysex...
    If so you would replace those midi messages with yours starting with Paul's 'transmit' example:
    #include <Bounce.h>  // Bounce library makes button change detection easy
    Bounce button1 = Bounce(1, 5);  // 5 = 5 ms debounce time
    Bounce button2 = Bounce(2, 5);  // which is appropriate for good quality mechanical pushbuttons
      pinMode(1, INPUT_PULLUP);
      pinMode(2, INPUT_PULLUP);
      button1.update();
      button2.update();
      // Note On messages when each button is pressed
      if (button1.fallingEdge()) {
        usbMIDI.sendSysEx(14, data1On)
      if (button2.fallingEdge()) {
        usbMIDI.sendSysEx(14, data2On)
      // Note Off messages when each button is released
      if (button1.risingEdge()) {
        usbMIDI.sendSysEx(14, data1Off)
      if (button2.risingEdge()) {
        usbMIDI.sendSysEx(14, data2Off)
      // MIDI Controllers should discard incoming MIDI messages.
    This won't compile because it is missing declarations for four arrays of data:
    data1On
    data1Off
    data2On
    data2Off
    But once you figure that out it shouldn't be too hard to get what you're looking for.
    May 2017
    102
    Hi oddson.
    The Korg M3M synthesizer module doesn't have the keyboard as the full Korg M3 has, althought everything is equal in both versions.
    It happens that the keyboard (which is detachable from the module) has a joystick, a ribbon and 2 buttons.
    It's those 2 buttons that I am trying to make work in my Teensy controller (together with the joystick, but that is already sorted). Those buttons can have their CC# changed from program to program (or combi or... ) and the only way to activate or deactivate them is with Sysex.
    When I enter a new program (individual sounds in Korg M3's language), or a Combi (multiple programs) it as a predefined state for the buttons, and it is that state that I want to change, as i would do with the original keyboard.
    I don't know if you would call that note on/note off in Arduino language. A note on gets off when released, it doesn't seem it is what the M3 needs for the buttons.
    I will work on your advise and tell you something latter.
    Thank you.
    Feb 2013
    1,090
    I meant only that the behaviour I thought you were trying to achieve is similar to note on/off in that one button does not affect the other and you are not trying to replicate latching behaviour (storing on/off state based and toggling with fallingEdge).
    If so, the logic of Paul's usbMIDI transmit example is readily altered into something that sends SysEx instead of note messages.
    I do not understand what you are doing with the 'module' ... I was merely reading that you wish to send four sysex messages based HIGH/LOW of two pins (and it seems that the behaviour of the two buttons in independent).
    I believe my approach is sound and you should be able to merge it into the Joystick code fairly easily.
    FYI -- I believe you need to omit the start (0xF0) and stop (0xF7) bytes as usbSendSysEx expects only the data you're sending (just as you don't count them in the length parameter).
    May 2017
    102
    I tried with this code, but althought it compiles without errors, the buttons are not sending Sysex. I believe it is something like a erronious choice on the declarations type, but...
    const int modMaxRaw = 1019; // Max reading full mod down??? read note from DOEPFER on 2nd pot reversed
    int pitch;
    int mod;
    int pitchRaw;
    int modRaw;
    int pitchLag;
    int modLag;
    button1.update();
    button2.update();
    const byte data1On[] = {0xF0, 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF7 };
    const byte data1Off[] = {0xF0, 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF7 };
    const byte data2On[] = {0xF0, 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0B, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF7 };
    const byte data2Off[] = {0xF0, 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0B, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF7 };
    usbMIDI.sendSysEx(14, data1On);
    usbMIDI.sendSysEx(14, data2On);
    usbMIDI.sendSysEx(14, data1Off);
    usbMIDI.sendSysEx(14, data2Off);
    getAnalogData();
    readPitch.update();
    pitchLag = pitch;
    pitchUpdate = 0;
    readMod.update();
    modLag = mod;
    modUpdate = 0;
    Feb 2013
    1,090
    You have the start and stop bytes in there... you need to strip them out....
    const byte data1On[] = { 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x01};
     const byte data1Off[] = { 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x00};
     const byte data2On[] = { 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0B, 0x00, 0x00, 0x00, 0x00, 0x01};
     const byte data2Off[] = { 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0B, 0x00, 0x00, 0x00, 0x00, 0x00};
    I've been coding VBA all morning so I can't remember how arrays work in C at the moment so I can't tell what else may be wrong... but you definitely don't send the SysEx start and end bytes the called routine in Paul's library does that for you.
    May 2017
    102
    I am trying to make the button send one Sysex message when i press that button and another one when i press it again. The button shouldn't do anything when i release it. The same for the second button, of course a different pair of Sysex messages.
    Feb 2013
    1,090
    Ah... that's what I meant by latching...
    You need a variable for each button to keep track of the current state so it knows which message to send when it get's the 'change' message from the fallingEdge....
    you need two Boolean variables; button1State and button2State for example
    They will initialize to false.
    Then test them along with the fallingEdge (you can ignore rising edge as that's just the button recovering after release... with latched behaviour you don't do anything with it).
    If the Boolean is false send the first message and then set it to true for next time.
    If it's already true send the other message and set the Boolean back to false....
    	if button1State then {
                button1State = FALSE;
                button1State = TRUE;
    This gives the latching behaviour where the output depends on the previous output...
    This is what I was trying to get clear in my first post...
    btw - can you use the advance features and put posted code inside code tags? Much easier to read than quotes as it retains the mono-spacing and indenting of code.
    May 2017
    102
    Quote Originally Posted by oddson View Post
    Like Gremlinwrangler said too.
    I will study that and post when i have something.
    Feb 2013
    1,090
    K... sounds like you're getting close. There's a code fragment I was adding to my last post when you replied.
    May 2017
    102
    I just read you suggestion and tried to implement it. I must be missing something (like braces) once that the compiler is returning:
    Arduino: 1.8.2 (Windows 10), TD: 1.36, Placa:"Teensy++ 2.0, MIDI, 16 MHz, German Swiss"
    MidiJoystick2combotoes: In function 'void loop()':
    MidiJoystick2combotoes:55: error: expected '(' before 'button1State'
    MidiJoystick2combotoes:58: error: expected '}' before 'else'
    MidiJoystick2combotoes:60: error: expected ';' before 'button1State'
    MidiJoystick2combotoes:48: warning: unused variable 'data1Off'
       const byte data1Off[] = {0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x00};
    MidiJoystick2combotoes:49: warning: unused variable 'data2On'
       const byte data2On[] = {0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0B, 0x00, 0x00, 0x00, 0x00, 0x01};
    MidiJoystick2combotoes:50: warning: unused variable 'data2Off'
       const byte data2Off[] = {0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0B, 0x00, 0x00, 0x00, 0x00, 0x00};
    C:\Users\Joao\Documents\Arduino\MidiJoystick2combotoes\MidiJoystick2combotoes.ino: At global scope:
    MidiJoystick2combotoes:63: error: expected unqualified-id before 'if'
    bool button1State = false;
    bool button2State = false;
    int pitch;
    int mod;
    int pitchRaw;
    int modRaw;
    int pitchLag;
    int modLag;
    ResponsiveAnalogRead readPitch = {pitchPin, true};
    ResponsiveAnalogRead readMod = {modPin, true};
      button1.update();
      button2.update();
      const byte data1On[] = {0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x01};
      // Button on or off messages when each button is pressed
        if button2State then {
          button2State = FALSE;
          button2State = TRUE;
      getAnalogData();
    void getAnalogData() {
      readPitch.update();
      if (readPitch.hasChanged()) {
        pitch = map(pitchRaw, 4, 1019, 0, 16383);
        pitch = max(pitch, 0); // need this now that the bottom isn't zero
        pitch = min(pitch, 16383); // cap to avoid overflow
        if (abs(pitch - pitchLag) > 0 && pitchUpdate > MIDIdelay ) {
          pitchLag = pitch;
          pitchUpdate = 0;
      readMod.update();
      if (readMod.hasChanged()) {
        mod = map(modRaw, 4, 1019, 0, 127); // N.B. - map does not limit values
        mod = max(mod, 0); // minimum could overflow is modRaw is greater than calabrated
        if (mod != modLag && modUpdate > MIDIdelay ) { // resolution reduction should be enough wi
          modLag = mod;
          modUpdate = 0;
    Feb 2013
    1,090
    I was missing semi colon in my fragment on a line end or two....
    You should move the const declarations out of the main loop too
    May 2017
    102
    Moved the const declaration out of the main loop and put de semi-colon where i noticed it was missing, but it is still not enough.
    I don't know if braces (or brackets) is missing in the one of the if clause.
    I could try, but i'm affraid it changes the logic.
    MidiJoystick2combotoes:60: error: 'TRUE' was not declared in this scope
    // SET THESE SIX VALUES!
    int pitch;
    int mod;
    int pitchRaw;
    int modRaw;
    int pitchLag;
    int modLag;
      button1.update();
      button2.update();
      getAnalogData();
      readPitch.update();
          pitchLag = pitch;
          pitchUpdate = 0;
      readMod.update();
          modLag = mod;
          modUpdate = 0;
    Feb 2013
    1,090
    sorry ... C conditional tests need to be in parenthesis ... http://www.cprogramming.com/tutorial/c/lesson2.html
    I'm not a C programmer and was just roughing in the code yesterday (I usually warn that I've not compiled the code so errors are likely but thought it was implied)... I assumed you have some idea about how it works since you've altered my previous code to get what you need.
    I can have a look later but it's the kind of thing you're going to run into a lot with your own code so you might as well learn it now.
    The compiler error messages tell you what's wrong... if it doesn't make sense then check the net for hints.
    I think the other errors are just fall-out from not setting up the conditional test correctly.
    EDIT
    oh.. and this.
    means the Booleans were not declared correctly either...
    I think they're meant to be lowercase.... I did warn I was coding in VBA all day
    May 2017
    102
    Yes, oddson. I know I will have to read, google, try and ... herm, ask, heheheh. I'm prepared for that.
    No, I'm not a programmer, just a curious musician (and clerk and bodybuilder), that knows a veeeeery tinny bit on some of the basics of programming.
    I'll keep my fight.
    Thank You for the kind help you are giving me.
    May 2017
    102
    Compiled with no errors.
    Semi happy, Sysex doesn't work
    int pitch;
    int mod;
    int pitchRaw;
    int modRaw;
    int pitchLag;
    int modLag;
      button1.update();
      button2.update();
        if (button1State ==false) {
          button1State = true;
        if (button2State ==false) {
          button2State = true;
      getAnalogData();
      readPitch.update();
          pitchLag = pitch;
          pitchUpdate = 0;
      readMod.update();
          modLag = mod;
          modUpdate = 0;
    Feb 2013
    1,090
    Hmmm... looks like it should be sending something... you said it was working before but with the wrong behaviour (not latching) correct?
    EDIT:
    Do you have a proper MIDI monitor in software?
    You could try inserting 'Serial.print(data1On);" where the booleans are reset and see if the array contains the correct data and weather the code is even firing as expected.
    I'm not sure if you can serial print an array of bytes in one go like that. (I'm again not at a computer with Arduinio IDE)... but you could ask for the byte you're interested in: 'Serial.print(data1On[8]);"
    Note: C arrays are zero indexed so the ninth element's index will be '8'.
    Sorry.. without the IDE it's kinda hard to debug. Anyone else?
    May 2017
    102
    Already sending SYSEX, but only the dataxOff when pressing for both buttons.
    I had to change the size of the SYSEX array to 16 and put the start/stop parts.
    byte data1On[] = {0xf0, 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x01, 0xf7};
    byte data1Off[] = {0xf0, 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf7};
    byte data2On[] = {0xf0, 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0B, 0x00, 0x00, 0x00, 0x00, 0x01, 0xf7};
    byte data2Off[] = {0xf0, 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0B, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf7};
    int pitch;
    int mod;
    int pitchRaw;
    int modRaw;
    int pitchLag;
    int modLag;
      Serial.begin(31250);
      button1.update();
      button2.update();
        usbMIDI.sendSysEx(16, data1Off);
          usbMIDI.sendSysEx(16, data1On);
          Serial.print(data1On[7]);
        usbMIDI.sendSysEx(16, data2Off);
          usbMIDI.sendSysEx(16, data2On);
      getAnalogData();
      readPitch.update();
          pitchLag = pitch;
          pitchUpdate = 0;
      readMod.update();
          modLag = mod;
          modUpdate = 0;
    Almost, I know, hehehehe
    May 2017
    102
    I'm affraid i'm not succeeding on doing this thing till now.
    May 2017
    102
    It works now.
    The only thing that is bugging me is that when i press the other button for the first time, it will send the last sysex that the first button sent. Pushing it again will send the right sysex and alter the sysex sent according to what I want it to do, as it should.
    It does this for both Button1 and Button2, whether I push button1 or button2 first, it will always send the last sysex that was sent by the other button.
    For instance, i connect the teensy to usb and press Button1. It will send, as it should:
    If I push the same button again, it will send, as it should:
    If i then push Button2, it will send, wrongly:
    Pushing it again will send, as is should:
    Pushing it again will send, as it should:
    ... and so on...
    The code i'm using at the moment is: (Some comments are wrong, once that i changed the "if(digitalRead(x) == LOW)" form "if(digitalRead(x) == HIGH)", because it was continuously doing the usbMIDI.sendSysEx without even pushing the buttons)
    int Button1 = 0; //This is the default "Button Off" and 1 is "Button On"
    int Button2 = 0; //This is the default "Button Off" and 1 is "Button On"
    int OldButton1 = 0; //I'll explain later
    int OldButton2 = 0; //I'll explain later
     pinMode(1, INPUT_PULLUP); //Pin 1 is an Input
     pinMode(2, INPUT_PULLUP); //Pin 2 is an Input
     if(digitalRead(1) == LOW) { //If Pin 1 is low (At 5 Volts)
       Button1 = 1 - Button1; //If Button1 is set as 0 then Button = 1 - 0 (=1) and if Button1 is 1 then Button=1 - 1 (=0)
     if(Button1 == 1 && OldButton1 == 0) { //If Button1 is 1 and OldButton1 is 0 (This means basically means "If the button1 was just pressed"
         //Put what you want to happen when "SW1" is on here
        usbMIDI.sendSysEx(16, data1On); //Send SysEX for SW1 On
     if(Button1 == 0 && OldButton1 == 1) {
       //Put what you want to happen when "SW1" is off here
       usbMIDI.sendSysEx(16, data1Off);//Send SysEX for SW1 Off
     OldButton1 = Button1; //The data is now old
     if(digitalRead(2) == LOW) { //If Pin 2 is high (At 5 Volts)
       Button2 = 1 - Button2; //If Button2 is set as 0 then Button = 1 - 0 (=1) and if Button2 is 1 then Button=1 - 1 (=0)
     if(Button2 == 1 && OldButton2 == 0) { //If Button2 is 1 and OldButton2 is 0 (This means basically means "If the button1 was just pressed"
        usbMIDI.sendSysEx(16, data2On); //Send SysEX for SW2 On
     if(Button2 == 0 && OldButton2 == 1) {
       usbMIDI.sendSysEx(16, data2Off);//Send SysEX for SW2 Off
     OldButton2 = Button2; //The data is now old
    The code I'm trying is from https://forum.arduino.cc/index.php?topic=58284.0 adapted to my case.
    May 2017
    102
    The complete code, which is working is:
    int OldButton1 = 0; //Variable to store button1 old value
    int OldButton2 = 0; //Variable to store button2 old value
    int pitch;
    int mod;
    int pitchRaw;
    int modRaw;
    int pitchLag;
    int modLag;
        usbMIDI.sendSysEx(16, data1On); //Delay for half a second
       usbMIDI.sendSysEx(16, data1Off);//Send SysEX to Channel1
        usbMIDI.sendSysEx(16, data2On); //Delay for half a second
       usbMIDI.sendSysEx(16, data2Off);//Send SysEX to Channel1
      getAnalogData();
      readPitch.update();
        pitch = map(pitchRaw, 3, 999, 0, 16383);
          pitchLag = pitch;
          pitchUpdate = 0;
      readMod.update();
        mod = map(modRaw, 3, 999, 0, 127); // N.B. - map does not limit values
          modLag = mod;
          modUpdate = 0;
    I'm now trying to figure out how to put CC#1 for joystick up (positive values, or >= 64, if working with the standard 0-127 range) and CC#2 for joystick down (negative values or <=63).
    May 2017
    102
    No one has a clue on this one?
    May 2017
    102
    I can already make the joystick send different CC# as Joystick Y position goes Center-Up or Center-Down. My only problem is that CC#2 (which is the one I am using for the Center-Up fragment is also cending for on the Center-Down.
    CC#1 Is correctly sending on Center-Down, only.
    The code is:
    const int modPin2 = 1;
    int pitch;
    int mod;
    int mod2;
    int pitchRaw;
    int modRaw;
    int modRaw2;
    int pitchLag;
    int modLag;
    int modLag2;
    elapsedMillis modUpdate2;
    ResponsiveAnalogRead readMod2 = {modPin2, true};
      getAnalogData();
      readPitch.update();
        pitch = map(pitchRaw, 3, 1019, 0, 16383);
          pitchLag = pitch;
          pitchUpdate = 0;
      readMod.update();
        mod = map(modRaw, 510, 1019, 64, 127); // N.B. - map does not limit values
        mod = max(mod, 64); // minimum could overflow is modRaw is greater than calabrated
        //mod = min(mod,64);
          modLag = mod;
          modUpdate = 0;
      readMod2.update();
      if (readMod2.hasChanged()) {
        modRaw2 = readMod2.getValue();
        mod2 = map(modRaw2, 3, 508, 0, 63); // N.B. - map does not limit values
        mod2 = max(mod2, 0); // minimum could overflow is modRaw2 is greater than calibrated
        //mod = min(mod,0);
        if (mod2 != modLag2 && modUpdate2 > MIDIdelay ) { // resolution reduction should be enough wi
          modLag2 = mod2;
          usbMIDI.sendControlChange(2, mod2, channel); // CC = 2 is Breath Control in standard MIDI -In this case it is
          modUpdate2 = 0;
    I know it is a detail I'm missing, but for now I haven't succeeded on discovering my bug.
