// include the ResponsiveAnalogRead library for analog smoothing
#include <ResponsiveAnalogRead.h>
#include <Bounce.h> // Bounce library makes button change detection easy
// ******CONSTANT VALUES******** - customize code behaviour here!
// SET THESE SIX VALUES FOR JOYSTICK!
const int pitchPin = 0; // PIN numbers ** MUST CHANGE!
const int modPin = 1;
const int modPin2 = 1;
const int pitchMaxRaw = 1019; // Max reading with full bend up... as raw 10-bit value
const int modMaxRaw = 1019; // Max reading full mod down
// SET THESE VALUES FOR RIBBON
//const int ribbonPin = touch_pressed; // Max reading on right side... as raw 10-bit value
const int ribbonMaxRaw = 474; // Max reading on right side... as raw 10-bit value
int Button1 = 0; //This is the default "Button Off" and 1 is "Button On"
int Button2 = 0; //This is the default "Button Off" and 1 is "Button On"
int OldButton1 = 0; //Variable to store button1 old value
int OldButton2 = 0; //Variable to store button2 old value
byte data1On[] = {0xf0, 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x01, 0xf7};
byte data1Off[] = {0xf0, 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf7};
byte data2On[] = {0xf0, 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0B, 0x00, 0x00, 0x00, 0x00, 0x01, 0xf7};
byte data2Off[] = {0xf0, 0x42, 0x30, 0x75, 0x41, 0x00, 0x00, 0x01, 0x00, 0x0B, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf7};
const int channel = 1; // MIDI channel
const int MIDIdelay = 5; // will update MIDI only if this many milliseconds have passed
//******VARIABLES***********
// data variables and a lagged copy to compare before updating MIDI value
int pitch;
int mod;
int mod2;
int pitchRaw;
int modRaw;
int modRaw2;
int pitchLag;
int modLag;
int modLag2;
int ribbon;
int ribbonRaw;
int ribbonLag;
int pcrec;
int pcold;
int pcnew;
int sw1recd1 = 0;
int sw1recd2 = 0;
int sw1oldd1 = 0;
int sw1oldd2 = 0;
int sw1newd1 = 0;
int sw1newd2 = 0;
int sw2recd1 = 0;
int sw2recd2 = 0;
int sw2oldd1 = 0;
int sw2oldd2 = 0;
int sw2newd1 = 0;
int sw2newd2 = 0;
elapsedMillis pitchUpdate;
elapsedMillis modUpdate;
elapsedMillis modUpdate2;
elapsedMillis ribbonUpdate;
// ititialize the ReponsiveAnalogRead objects
ResponsiveAnalogRead readPitch = {pitchPin, true};
ResponsiveAnalogRead readMod = {modPin, true};
ResponsiveAnalogRead readMod2 = {modPin2, true};
#include <Adafruit_GFX.h> // Core graphics library
#define LCD_ROTATION 1 //should work in all rotations
#define USE_READID 0 //Adafruit and ILI9488 can't read ID
//#include <MCUFRIEND_kbv.h> // Hardware-specific library
//MCUFRIEND_kbv tft;
//#include <Adafruit_ILI9341.h> // Hardware-specific library
//Adafruit_ILI9341 tft(10, 9, 8);
//#include <HX8347D_kbv.h> // Hardware-specific library
//HX8347D_kbv tft;
#include <ILI9488.h> // Hardware-specific library
ILI9488 tft(10, 9, 8);
//#include <ILI9488_kbv.h> // Hardware-specific library
//ILI9488_kbv tft;
extern void Touch_initialise(int aspect, int wid, int ht);
extern bool Touch_getXY(void);
bool touch_pressed;
int pixel_x, pixel_y;
boolean SW1on = false;
boolean SW2on = false;
boolean ribbonCtrl = false;
// Color definitions
#define TFT_BLACK 0x0000 /* 0, 0, 0 */
#define TFT_NAVY 0x000F /* 0, 0, 128 */
#define TFT_DARKGREEN 0x03E0 /* 0, 128, 0 */
#define TFT_DARKCYAN 0x03EF /* 0, 128, 128 */
#define TFT_MAROON 0x7800 /* 128, 0, 0 */
#define TFT_PURPLE 0x780F /* 128, 0, 128 */
#define TFT_OLIVE 0x7BE0 /* 128, 128, 0 */
#define TFT_LIGHTGREY 0xC618 /* 192, 192, 192 */
#define TFT_DARKGREY 0x7BEF /* 128, 128, 128 */
#define TFT_BLUE 0x001F /* 0, 0, 255 */
#define TFT_GREEN 0x07E0 /* 0, 255, 0 */
#define TFT_CYAN 0x07FF /* 0, 255, 255 */
#define TFT_RED 0xF800 /* 255, 0, 0 */
#define TFT_RED2 0xF88D /* 254, 18, 106 */
#define TFT_MAGENTA 0xF81F /* 255, 0, 255 */
#define TFT_YELLOW 0xFFE0 /* 255, 255, 0 */
#define TFT_WHITE 0xFFFF /* 255, 255, 255 */
#define TFT_ORANGE 0xFD20 /* 255, 165, 0 */
#define TFT_ORANGE2 0xFB20 /* 254, 102, 1 */
#define TFT_GREENYELLOW 0xAFE5 /* 173, 255, 47 */
#define TFT_PINK 0xF81F
/******************* UI details */
#define SW1FRAME_X 90
#define SW1FRAME_Y 110
#define SW1FRAME_W 130
#define SW1FRAME_H 70
#define SW1BUTTON_X SW1FRAME_X
#define SW1BUTTON_Y SW1FRAME_Y
#define SW1BUTTON_W SW1FRAME_W
#define SW1BUTTON_H SW1FRAME_H
#define SW2FRAME_X 310
#define SW2FRAME_Y 110
#define SW2FRAME_W 130
#define SW2FRAME_H 70
#define SW2BUTTON_X SW2FRAME_X
#define SW2BUTTON_Y SW2FRAME_Y
#define SW2BUTTON_W SW2FRAME_W
#define SW2BUTTON_H SW2FRAME_H
#define RIBBONFRAME_X 10
#define RIBBONFRAME_Y 240
#define RIBBONFRAME_W 470
#define RIBBONFRAME_H 70
#define RIBBON_X RIBBONFRAME_X
#define RIBBON_Y RIBBONFRAME_Y
#define RIBBON_W RIBBONFRAME_W
#define RIBBON_H RIBBONFRAME_H
void sw1Btn()
tft.drawRect(SW1BUTTON_X, SW1BUTTON_Y, SW1BUTTON_W, SW1BUTTON_H, TFT_DARKGREY);
tft.fillRect(SW1BUTTON_X, SW1BUTTON_Y, SW1BUTTON_W, SW1BUTTON_H, TFT_RED);
tft.setCursor(160, 140);
tft.setTextColor(TFT_WHITE);
tft.setTextSize(2);
tft.println("SW1");
SW1on = false;
void sw2Btn()
tft.drawRect(SW2BUTTON_X, SW2BUTTON_Y, SW2BUTTON_W, SW2BUTTON_H, TFT_DARKGREY);
tft.fillRect(SW2BUTTON_X, SW2BUTTON_Y, SW2BUTTON_W, SW2BUTTON_H, TFT_RED);
tft.setCursor(340,140);
tft.setTextSize(2);
tft.println("SW2");
SW2on = false;
void rbCtrl()
tft.drawRect(RIBBON_X, RIBBON_Y, RIBBON_W, RIBBON_H, TFT_LIGHTGREY);
tft.fillRect(RIBBON_X, RIBBON_Y, RIBBON_W, RIBBON_H, TFT_LIGHTGREY);
tft.setCursor(10,240);
//remap to output data and send if changed and MIDIdelay has lapsed since last update for that parameter
ribbon = map(pixel_x, 11, 474, 0, 127);
//ribbon = max(ribbon, 0); // need this now that the bottom isn't zero
// ribbon = min(ribbon, 127); // cap to avoid overflow
// if (abs(ribbon - ribbonLag) > 0 && ribbonUpdate > MIDIdelay ) {
// ribbonLag = ribbon;
usbMIDI.sendControlChange(16, ribbon, channel);
// ribbonUpdate = 0;
ribbonCtrl = false;
void setup(void)
Serial.println(F("TFT LCD test"));
tft.begin();
int aspect = LCD_ROTATION; //PORTRAIT
tft.setRotation(aspect);
Touch_initialise(aspect, tft.width(), tft.height()); //.kbv external function
tft.fillScreen(TFT_BLACK);
// create 'SW1 Switch'
tft.setCursor(155, 140);
tft.setTextColor(TFT_BLACK);
tft.setTextSize(2);
tft.print("SW1");
// create 'SW2 Switch'
tft.setCursor(340, 140);
tft.setTextSize(2);
tft.print("SW2");
// create 'Ribbon Emulator field'
tft.drawRect(RIBBON_X, RIBBON_Y, RIBBON_W, RIBBON_H, TFT_DARKGREY);
unsigned long t=0;
void loop(void)
int type, note, velocity, channel, d1, d2;
if (usbMIDI.read()) { // Is there a MIDI message incoming ?
byte type = usbMIDI.getType();
switch (type) {
case usbMIDI.NoteOn:
note = usbMIDI.getData1();
velocity = usbMIDI.getData2();
channel = usbMIDI.getChannel();
if (velocity > 0) {
Serial.println(String("Note On: ch=") + channel + ", note=" + note + ", velocity=" + velocity);
Serial.println(String("Note Off: ch=") + channel + ", note=" + note);
case usbMIDI.NoteOff:
Serial.println(String("Note Off: ch=") + channel + ", note=" + note + ", velocity=" + velocity);
default:
d1 = usbMIDI.getData1();
d2 = usbMIDI.getData2();
Serial.println(String("Message, type=") + type + ", data = " + d1 + " " + d2);
t = millis();
if (millis() - t > 10000) {
t += 10000;
Serial.println("(inactivity)");
//usbMIDI.read();
//if (usbMIDI.getType() == 0xB0) {//check for CC
//const byte korgdata1 = usbMIDI.getData1();
//const byte korgdata2 = usbMIDI.getData2();
// Serial.print(korgdata1);Serial.print(" "); Serial.println(korgdata2);
int x = -1, y = -1; //regular pixel coordinates
touch_pressed = Touch_getXY(); //external function
#if 0
Serial.print("X="); Serial.print(pixel_x);
Serial.print(" Y="); Serial.print(pixel_y);
Serial.print(" Z="); Serial.print(touch_pressed);
Serial.println("");
if (touch_pressed) {
x = pixel_x; //copy global variable
y = pixel_y;
if((x > SW1BUTTON_X) && (x < (SW1BUTTON_X + SW1BUTTON_W))) {
if ((y > SW1BUTTON_Y) && (y <= (SW1BUTTON_Y + SW1BUTTON_H))) {
Serial.println("SW1 btn hit");
delay(100); // UI debouncing
sw1Btn();
if((x > SW2BUTTON_X) && (x < (SW2BUTTON_X + SW2BUTTON_W))) {
if ((y > SW2BUTTON_Y) && (y <= (SW2BUTTON_Y + SW2BUTTON_H))) {
Serial.println("SW2 btn hit");
sw2Btn();
if((x > RIBBON_X) && (x < (RIBBON_X + RIBBON_W))) {
if ((y > RIBBON_Y) && (y <= (RIBBON_Y + RIBBON_H))) {
Serial.println("Ribbon pressed");
Serial.println(pixel_x);
Serial.println(ribbon);
rbCtrl();
Message, type=192, data = 7 0
Message, type=176, data = 65 0
int pcrec; // Program Change receive
int pcold; // Old Program Change value
int pcnew; // New Program Change value. Just in case i decide to have the Preset numbers on the screen
int sw1recd1 = 0; // SW1 Data1 received value
int sw1recd2 = 0; // SW1 Data2 received value
int sw1oldd1 = 0; // SW1 Data1 old value
int sw1oldd2 = 0; // SW1 Data2 old value
int sw1newd1 = 0; // SW1 Data1 new value ... daah
int sw1newd2 = 0; // SW1 Data2 new value ... daah
int sw2recd1 = 0; // SW2 Data1 received value
int sw2recd2 = 0; // SW2 Data2 received value
int sw2oldd1 = 0; // SW2 Data1 old value
int sw2oldd2 = 0; // SW2 Data2 old value
int sw2newd1 = 0; // SW2 Data1 new value
int sw2newd2 = 0; // SW2 Data2 new value
elapsedMillis scanStart; // add to the pre-setup code
void loop(){
usbMIDI.read();
if (scanStart < 8) {
SW1 = SW2;
SW2 = D1;
}else{
scanStart = 0;
if (!SW1) {
SW1 = SW2;
SW2 = 81; // or leave it as is or blank it or whatever you want
Message, type=176, data = 0 0
Message, type=176, data = 32 0
Message, type=192, data = 9 0
Message, type=176, data = 80 0
Message, type=176, data = 81 0
Message, ch, type=176,channel=1, data = 0 0
Message, ch, type=176,channel=1, data = 32 0
Message, type=192,channel1, data = 0 0
Message, ch, type=176,channel=1, data = 7 127
Message, ch, type=176,channel=1, data = 10 64
Message, ch, type=176,channel=1, data = 93 0
Message, ch, type=176,channel=1, data = 91 0
Message, ch, type=176,channel=2, data = 0 0
Message, ch, type=176,channel=2, data = 32 0
Message, type=192,channel2, data = 0 0
Message, ch, type=176,channel=2, data = 7 127
Message, ch, type=176,channel=2, data = 10 64
Message, ch, type=176,channel=2, data = 93 0
Message, ch, type=176,channel=2, data = 91 0
Message, ch, type=176,channel=3, data = 0 0
Message, ch, type=176,channel=3, data = 32 0
Message, type=192,channel3, data = 0 0
Message, ch, type=176,channel=3, data = 7 127
Message, ch, type=176,channel=3, data = 10 64
Message, ch, type=176,channel=3, data = 93 0
Message, ch, type=176,channel=3, data = 91 0
Message, ch, type=176,channel=4, data = 0 0
Message, ch, type=176,channel=4, data = 32 0
Message, type=192,channel4, data = 0 0
MessagMessage, ch, type=176,channel=13, data = 10 64
Message, ch, type=176,channel=13, data = 93 0
Message, ch, type=176,channel=13, data = 91 0
Message, ch, type=176,channel=14, data = 0 0
Message, ch, type=176,channel=14, data = 32 0
Message, type=192,channel14, data = 0 0
Message, ch, type=176,channel=14, data = 7 127
Message, ch, type=176,channel=14, data = 10 64
Message, ch, type=176,channel=14, data = 93 0
Message, ch, type=176,channel=14, data = 91 0
Message, ch, type=176,channel=15, data = 0 0
Message, ch, type=176,channel=15, data = 32 0
Message, type=192,channel15, data = 0 0
Message, ch, type=176,channel=15, data = 7 127
Message, ch, type=176,channel=15, data = 10 64
Message, ch, type=176,channel=15, data = 93 0
Message, ch, type=176,channel=15, data = 91 0
Message, ch, type=176,channel=16, data = 0 0
Message, ch, type=176,channel=16, data = 32 0
Message, type=192,channel16, data = 0 0
Message, ch, type=176,channel=16, data = 7 127
Message, ch, type=176,channel=16, data = 10 64
Message, ch, type=176,channel=16, data = 93 0
Message, ch, type=176,channel=16, data = 91 0
Message, ch, type=176,channel=1, data = 80 0
Message, ch, type=176,channel=1, data = 81 0
int SW1 = 0;
int SW2 = 0;
int d1 = 0;
int d2 = 0;
int ch;
int SW1D1 = 0;
int SW1D2 = 0;
int SW2D1 = 0;
int SW2D2 = 0;
int pitch;
int mod;
int mod2;
int pitchRaw;
int modRaw;
int modRaw2;
int pitchLag;
int modLag;
int modLag2;
int ribbon;
int ribbonRaw;
int ribbonLag;
//HX8347D_kbv tft;
//ILI9488_kbv tft;
bool touch_pressed;
void sw1Btn()
tft.setTextSize(2);
tft.println("SW1");
usbMIDI.sendControlChange(SW1, d2, 1);
SW1on = false;
void sw2Btn()
tft.setTextSize(2);
tft.println("SW2");
usbMIDI.sendControlChange(SW2, d2, 1);
SW2on = false;
void rbCtrl()
ribbonCtrl = false;
void setup(void)
tft.begin();
tft.setTextSize(2);
tft.print("SW1");
tft.setTextSize(2);
tft.print("SW2");
unsigned long t=0;
void loop(void)
switch (type) {
case usbMIDI.ControlChange:
Serial.println(String("Message, type=") + type + ",channel " + channel + ", data = " + d1 + " " + d2);
SW1 = SW2;
Serial.println (String("scanStart<8 SW1=SW2: SW1 ") + SW1 + ", SW2 " + SW2); // This print is only to control what is happening
SW2 = d1;
Serial.println (String("SW2=dl: " "SW2 ") + SW2 + ", D1 " + d1); // This print is only to control what is happening
}else{
scanStart = 0;
if (!SW1) {
SW1 = SW2;
Serial.println (String("scanStart = 0: SW1=SW2 " "=SW1 ") + SW1 + ", SW2 " + SW2); // This print is only to control what is happening
t = millis();
t += 10000;
#if 0
Serial.println("");
y = pixel_y;
Serial.println(String("Message,") + ",channel " + channel + ",data = " + SW1 + " " + d2);
sw1Btn();
Serial.println(String("Message,") + ",channel " + channel + ",data = " + SW2 + " " + d2);
sw2Btn();
rbCtrl();
(inactivity)
Message, type=176,channel 1, data = 80 0
scanStart = 0: SW1=SW2 =SW1 0, SW2 0
Message, type=176,channel 1, data = 81 0
scanStart<8 SW1=SW2: SW1 81, SW2 81
SW2=dl: SW2 81, D1 81
(inactivity)
void loop(){
usbMIDI.read();
if (getType=usbMIDI.programChnage) {
scanStart = 0;
SW1 = SW2;
SW2 = D1;
}else{
if (!SW1) {
SW1 = SW2;
SW2 = 0 ; // blank SW2 if there was only 1 CC
Hey oddson, no rush.
Maybe you're lacking a pint of beer to put that engine on track!
const int scanMax = 250;
const byte channel = 1;
byte SW1;
byte SW1lag;
byte SW2;
byte SW2lag;
elapsedMillis reportLast;
void loop(void)
if (usbMIDI.read(channel)) { // limit reads to single channel
if (usbMIDI.getType() == usbMIDI.ProgramChange){
scanStart = 0;
SW1 = SW2;
SW2 = 0;
}else if(usbMIDI.getType() == usbMIDI.ControlChange) {
if (scanStart <= scanMax) {
SW1 = SW2;
SW2 = usbMIDI.getData1();
if (scanStart >= scanMax) {
if (SW1 == 0) { // if there was only 1 CC SW1 is blank and we will swap
SW1 = SW2;
SW2 = 0;
if ((SW1 != SW1lag) || (SW2 != SW2lag)) { // if there is a change...
Serial.println(SW1);
Serial.println(SW2);
SW1lag = SW1;
SW2lag = SW2;
scanStart = 0;
SW1lag = SW1;
SW2lag = SW2;
scanStart = 0;
(inactivity)
80
81
SW1 btn hit
Message,,channel 1,data = 80 0
(inactivity)
SW2 btn hit
Message,,channel 1,data = 81 0
(inactivity)
(inactivity)
(inactivity)
(inactivity)
void loop(void)
scanStart = 0;
SW1 = SW2;
SW2 = 0;
SW1 = SW2;
SW1 = SW2;
SW2 = 0;
SW1lag = SW1;
SW2lag = SW2;
scanStart = 0;
yeah... I guess I'll have to debug it sober.
...as a hunch try changing SW1 = SW2; to SW1 = 0; in the PC part of the code (first instance).
I meant to post that as a correction last night but didn't... I thought it was harmless but that could be why it's not working as it might be messing up the flags as I thought they work but I can't quite think it through in my head right now.
(Something to do with blanking them by accident when SW2 gets copied to SW1 after the first message is processed.)
SW1 = SW2;
SW2 = 0;
[COLOR="#A9A9A9"] //if ((SW1 != SW1lag) || (SW2 != SW2lag)) { // if there is a change...[/COLOR]
SW1lag = SW1;
SW2lag = SW2;
[COLOR="#A9A9A9"] //}[/COLOR]
scanStart = 0;
It won't do anything if the same parameters are present but the SW1 and SW2 values will still be correct if/when they are pressed again if these variables are used in the MIDI message.
E.g.: usbMIDI.sendProgramChange(SW1, channel);
Remove the conditional and it should report every time.Code:if (scanStart >= scanMax) { if (SW1 == 0) { // if there was only 1 CC SW1 is blank and we will swap SW1 = SW2; SW2 = 0; } [COLOR=#A9A9A9] //if ((SW1 != SW1lag) || (SW2 != SW2lag)) { // if there is a change...[/COLOR] Serial.println(SW1); Serial.println(SW2); SW1lag = SW1; SW2lag = SW2; [COLOR=#A9A9A9] //}[/COLOR] scanStart = 0; }
0
0
0
0
0
0
0
0
0
(inactivity)
0
0
0
0
0
0
0
0
0
const int scanMax = 9;
//const byte channel = 1;
byte SW1;
byte SW1D2;
byte SW1lag;
byte SW2;
byte SW2D2;
byte SW2lag;
byte d2;
int pitch;
int mod;
int mod2;
int pitchRaw;
int modRaw;
int modRaw2;
int pitchLag;
int modLag;
int modLag2;
int ribbon;
int ribbonRaw;
int ribbonLag;
//HX8347D_kbv tft;
//ILI9488_kbv tft;
bool touch_pressed;
void sw1Btn()
tft.setTextSize(2);
tft.println("SW1");
usbMIDI.sendControlChange(SW1, SW1D2, 1);
SW1on = false;
void sw2Btn()
tft.setTextSize(2);
tft.println("SW2");
usbMIDI.sendControlChange(SW2, SW2D2, 1);
SW2on = false;
void rbCtrl()
ribbonCtrl = false;
void setup(void)
tft.begin();
tft.setTextSize(2);
tft.print("SW1");
tft.setTextSize(2);
tft.print("SW2");
unsigned long t=0;
void loop(void)
scanStart = 0;
SW1 = 0;
SW2 = 0;
SW1 = SW2;
SW1D2 = SW2D2;
SW2D2 = usbMIDI.getData2();
SW1 = SW2;
SW2 = 0;
SW1lag = SW1;
SW2lag = SW2;
scanStart = 0;
t += 10000;
#if 0
Serial.println("");
y = pixel_y;
sw1Btn();
sw2Btn();
rbCtrl();
