oddson
....This is how it is now...
Trying to debug my code and yours together is not going to work... especially if you are not making the changes I'm suggesting.
Here's what I was suggesting last (that the reset needs to be only when a PC is received which should also limit the print to once per PC and therefore the lagged SW1 and SW2 values are not required).
// include the ResponsiveAnalogRead library for analog smoothing
#include <Bounce.h> // Bounce library makes button change detection easy
// ******CONSTANT VALUES******** - customize code behaviour here!
// SET THESE SIX VALUES FOR JOYSTICK!
const int pitchPin = 0; // PIN numbers ** MUST CHANGE!
const int modPin = 1;
const int modPin2 = 1;
const int pitchMaxRaw = 1019; // Max reading with full bend up... as raw 10-bit value
const int modMaxRaw = 1019; // Max reading full mod down
// SET THESE VALUES FOR RIBBON
//const int ribbonPin = touch_pressed; // Max reading on right side... as raw 10-bit value
const int ribbonMaxRaw = 474; // Max reading on right side... as raw 10-bit value
int Button1 = 0; //This is the default "Button Off" and 1 is "Button On"
int Button2 = 0; //This is the default "Button Off" and 1 is "Button On"
int OldButton1 = 0; //Variable to store button1 old value
int OldButton2 = 0; //Variable to store button2 old value
const int scanMax = 9;
//const byte channel = 1;
byte SW1;
byte SW1D2;
[COLOR="#FF0000"]//byte SW1lag;[/COLOR]
byte SW2;
byte SW2D2;
[COLOR="#FF0000"]//byte SW2lag;[/COLOR]
byte d2;
const int channel = 1; // MIDI channel
const int MIDIdelay = 5; // will update MIDI only if this many milliseconds have passed
//******VARIABLES***********
// data variables and a lagged copy to compare before updating MIDI value
int pitch;
int mod;
int mod2;
int pitchRaw;
int modRaw;
int modRaw2;
int pitchLag;
int modLag;
int modLag2;
int ribbon;
int ribbonRaw;
int ribbonLag;
elapsedMillis pitchUpdate;
elapsedMillis modUpdate;
elapsedMillis modUpdate2;
elapsedMillis ribbonUpdate;
elapsedMillis scanStart;
elapsedMillis reportLast;
// ititialize the ReponsiveAnalogRead objects
ResponsiveAnalogRead readPitch = {pitchPin, true};
ResponsiveAnalogRead readMod = {modPin, true};
ResponsiveAnalogRead readMod2 = {modPin2, true};
#include <Adafruit_GFX.h> // Core graphics library
#define LCD_ROTATION 1 //should work in all rotations
#define USE_READID 0 //Adafruit and ILI9488 can't read ID
//#include <MCUFRIEND_kbv.h> // Hardware-specific library
//MCUFRIEND_kbv tft;
//#include <Adafruit_ILI9341.h> // Hardware-specific library
//Adafruit_ILI9341 tft(10, 9, 8);
//#include <HX8347D_kbv.h> // Hardware-specific library
//HX8347D_kbv tft;
#include <ILI9488.h> // Hardware-specific library
ILI9488 tft(10, 9, 8);
//#include <ILI9488_kbv.h> // Hardware-specific library
//ILI9488_kbv tft;
extern void Touch_initialise(int aspect, int wid, int ht);
extern bool Touch_getXY(void);
bool touch_pressed;
int pixel_x, pixel_y;
boolean SW1on = false;
boolean SW2on = false;
boolean ribbonCtrl = false;
// Color definitions
#define TFT_BLACK 0x0000 /* 0, 0, 0 */
#define TFT_NAVY 0x000F /* 0, 0, 128 */
#define TFT_DARKGREEN 0x03E0 /* 0, 128, 0 */
#define TFT_DARKCYAN 0x03EF /* 0, 128, 128 */
#define TFT_MAROON 0x7800 /* 128, 0, 0 */
#define TFT_PURPLE 0x780F /* 128, 0, 128 */
#define TFT_OLIVE 0x7BE0 /* 128, 128, 0 */
#define TFT_LIGHTGREY 0xC618 /* 192, 192, 192 */
#define TFT_DARKGREY 0x7BEF /* 128, 128, 128 */
#define TFT_BLUE 0x001F /* 0, 0, 255 */
#define TFT_GREEN 0x07E0 /* 0, 255, 0 */
#define TFT_CYAN 0x07FF /* 0, 255, 255 */
#define TFT_RED 0xF800 /* 255, 0, 0 */
#define TFT_RED2 0xF88D /* 254, 18, 106 */
#define TFT_MAGENTA 0xF81F /* 255, 0, 255 */
#define TFT_YELLOW 0xFFE0 /* 255, 255, 0 */
#define TFT_WHITE 0xFFFF /* 255, 255, 255 */
#define TFT_ORANGE 0xFD20 /* 255, 165, 0 */
#define TFT_ORANGE2 0xFB20 /* 254, 102, 1 */
#define TFT_GREENYELLOW 0xAFE5 /* 173, 255, 47 */
#define TFT_PINK 0xF81F
/******************* UI details */
#define SW1FRAME_X 90
#define SW1FRAME_Y 110
#define SW1FRAME_W 130
#define SW1FRAME_H 70
#define SW1BUTTON_X SW1FRAME_X
#define SW1BUTTON_Y SW1FRAME_Y
#define SW1BUTTON_W SW1FRAME_W
#define SW1BUTTON_H SW1FRAME_H
#define SW2FRAME_X 310
#define SW2FRAME_Y 110
#define SW2FRAME_W 130
#define SW2FRAME_H 70
#define SW2BUTTON_X SW2FRAME_X
#define SW2BUTTON_Y SW2FRAME_Y
#define SW2BUTTON_W SW2FRAME_W
#define SW2BUTTON_H SW2FRAME_H
#define RIBBONFRAME_X 10
#define RIBBONFRAME_Y 240
#define RIBBONFRAME_W 470
#define RIBBONFRAME_H 70
#define RIBBON_X RIBBONFRAME_X
#define RIBBON_Y RIBBONFRAME_Y
#define RIBBON_W RIBBONFRAME_W
#define RIBBON_H RIBBONFRAME_H
void sw1Btn()
tft.drawRect(SW1BUTTON_X, SW1BUTTON_Y, SW1BUTTON_W, SW1BUTTON_H, TFT_DARKGREY);
tft.fillRect(SW1BUTTON_X, SW1BUTTON_Y, SW1BUTTON_W, SW1BUTTON_H, TFT_RED);
tft.setCursor(160, 140);
tft.setTextColor(TFT_WHITE);
tft.setTextSize(2);
tft.println("SW1");
usbMIDI.sendControlChange(SW1, SW1D2, 1);
SW1on = false;
void sw2Btn()
tft.drawRect(SW2BUTTON_X, SW2BUTTON_Y, SW2BUTTON_W, SW2BUTTON_H, TFT_DARKGREY);
tft.fillRect(SW2BUTTON_X, SW2BUTTON_Y, SW2BUTTON_W, SW2BUTTON_H, TFT_RED);
tft.setCursor(340,140);
tft.setTextSize(2);
tft.println("SW2");
usbMIDI.sendControlChange(SW2, SW2D2, 1);
SW2on = false;
void rbCtrl()
tft.drawRect(RIBBON_X, RIBBON_Y, RIBBON_W, RIBBON_H, TFT_LIGHTGREY);
tft.fillRect(RIBBON_X, RIBBON_Y, RIBBON_W, RIBBON_H, TFT_LIGHTGREY);
tft.setCursor(10,240);
//remap to output data and send if changed and MIDIdelay has lapsed since last update for that parameter
ribbon = map(pixel_x, 11, 474, 0, 127);
//ribbon = max(ribbon, 0); // need this now that the bottom isn't zero
// ribbon = min(ribbon, 127); // cap to avoid overflow
// if (abs(ribbon - ribbonLag) > 0 && ribbonUpdate > MIDIdelay ) {
// ribbonLag = ribbon;
usbMIDI.sendControlChange(16, ribbon, channel);
// ribbonUpdate = 0;
ribbonCtrl = false;
void setup(void)
Serial.println(F("TFT LCD test"));
tft.begin();
int aspect = LCD_ROTATION; //PORTRAIT
tft.setRotation(aspect);
Touch_initialise(aspect, tft.width(), tft.height()); //.kbv external function
tft.fillScreen(TFT_BLACK);
// create 'SW1 Switch'
tft.setCursor(155, 140);
tft.setTextColor(TFT_BLACK);
tft.setTextSize(2);
tft.print("SW1");
// create 'SW2 Switch'
tft.setCursor(340, 140);
tft.setTextSize(2);
tft.print("SW2");
// create 'Ribbon Emulator field'
tft.drawRect(RIBBON_X, RIBBON_Y, RIBBON_W, RIBBON_H, TFT_DARKGREY);
unsigned long t=0;
void loop(void)
if (usbMIDI.read(channel)) { // limit reads to single channel
if (usbMIDI.getType() == usbMIDI.ProgramChange){
scanStart = 0;
SW1 = 0;
SW2 = 0;
}else if(usbMIDI.getType() == usbMIDI.ControlChange) {
if (scanStart <= scanMax) {
SW1 = SW2;
SW1D2 = SW2D2;
SW2 = usbMIDI.getData1();
SW2D2 = usbMIDI.getData2();
if (scanStart >= scanMax) {
if (SW1 == 0) { // if there was only 1 CC SW1 is blank and we will swap
SW1 = SW2;
SW2 = 0;
[COLOR="#FF0000"]// if ((SW1 != SW1lag) || (SW2 != SW2lag)) { // if there is a change...[/COLOR]
Serial.println(SW1);
Serial.println(SW2);
[COLOR="#FF0000"]// SW1lag = SW1;
// SW2lag = SW2;
// scanStart = 0;[/COLOR]
if (millis() - t > 10000) {
t += 10000;
Serial.println("(inactivity)");
int x = -1, y = -1; //regular pixel coordinates
touch_pressed = Touch_getXY(); //external function
#if 0
Serial.print("X="); Serial.print(pixel_x);
Serial.print(" Y="); Serial.print(pixel_y);
Serial.print(" Z="); Serial.print(touch_pressed);
Serial.println("");
if (touch_pressed) {
x = pixel_x; //copy global variable
y = pixel_y;
if((x > SW1BUTTON_X) && (x < (SW1BUTTON_X + SW1BUTTON_W))) {
if ((y > SW1BUTTON_Y) && (y <= (SW1BUTTON_Y + SW1BUTTON_H))) {
Serial.println("SW1 btn hit");
Serial.println(String("Message,") + ",channel " + channel + ",data = " + SW1 + " " + d2);
delay(100); // UI debouncing
sw1Btn();
if((x > SW2BUTTON_X) && (x < (SW2BUTTON_X + SW2BUTTON_W))) {
if ((y > SW2BUTTON_Y) && (y <= (SW2BUTTON_Y + SW2BUTTON_H))) {
Serial.println("SW2 btn hit");
Serial.println(String("Message,") + ",channel " + channel + ",data = " + SW2 + " " + d2);
sw2Btn();
if((x > RIBBON_X) && (x < (RIBBON_X + RIBBON_W))) {
if ((y > RIBBON_Y) && (y <= (RIBBON_Y + RIBBON_H))) {
Serial.println("Ribbon pressed");
Serial.println(pixel_x);
Serial.println(ribbon);
rbCtrl();
I will be returning to my code if this does not work for you as I cannot test your code without the hardware.
