Hi all,
I'm working on a project where I want to use a WIZ820io Ethernet adapter and the Adafruit 2.4" TFT ILI9341 touch display on my Teensy 3.6
My first thought was to use the 8-bit wiring for the TFT (12 pins in total) and leave the the WIZ820io working solely on the SPI bus.
Unfortunately I don't get the TFT to work this way on the Teensy 3.6. On an Arduino Uno, the 8-bit wiring works as expected with the Adafruit libraries. On the Teensy, I get compilation errors.
So my first question, is there any way to use a TFT display with 8-bit wiring on a Teensy?
If not, I would have to use SPI for the display as well, right? Before I start to desolder everything (yes I know, I should have tried the everything on the breadboard first...), will TFT and Ethernet work well together on the same SPI bus? And do I only need to define CS and D/C for the TFT SPI connection to other teensy pins? It sounds kind of too simple...
Thanks,
Stefan
Thanks,
Stefan
