Hi, looking for wisdom on this issue. When I use the audio board with teensy 3.2 analog input A1 has twice the amount of noise. I though it was somehow the noise from the clocks generated by the teensy 3.2. However, just loading a simple code to read A1 without any Audio board configuration, In other words, the audio board is powered on but not configured still give the same amount of noise on A1.
This is happening if the teensy is stacked with the audio board too. (Pin 15 to audio board is cut)
I'm also reading A0,A2,A3,A6,A7 and they are not suffering from this problem.
