bendedavis
I'm working on a project using a MK20DX256VLH7. I'm using a LD1117S33 3.3V regulator. This 16MHz crystal with 22pF caps to ground http://www.mouser.com/Search/Produc...tualkey64490000virtualkey449-LFXTAL015055REEL. I am unable to get the board to detect over USB. I've created projects based on the LC before with no issues. The main difference I see between the LC and 3.2 is that the bootloader connects to pin 4 of the USB connector. I'm using a Type B USB connector which doesn't have this pin so I tried connecting it directly to ground which didn't change anything. Another possible issue could be my VBAT pin. Is it ok to connect this directly to 3.3v? I've attached most of my schematic. I'm using a 9 pin header to connect to a programmer board which breaks out the USB and bootloader pins.
