I am doing a simple sound reactive project. It was working perfectling for like 1 minute after I was done soldering everything in place, when suddenly the lights of the LED strip started getting less bright. I instantly turned everything off and the boost converter was really hot. Basicly I use a 3.7v Battery and boost that with a step-up converter to 5V to power up the LED strip and Teensy LC. When I tried to plug the Teensy in the computer it wouldn't connect and the teensy loader wouldn't recognize the device either. Here is the message that I got on the Arduino IDE:
"Teensy did not respond to a USB-based request to automatically reboot.
Please press the PROGRAM MODE BUTTON on your Teensy to upload your sketch."
So I can't power up the teensy from the USB port, but when I plug in the batttery, it lights up and detect the sound from the microphone because I see the built in LED lighting up when i make some sound, but the step up converter (rated for 2A) gets really hot. It felt like there was a short circuit somewhere. When I cheked the PCB, everything was fine. But when i checked the pins on the Teensy LC, the Vusb, Vin and Ground were shorted. Is there a way to fix it ?
