Hi All,
Currently testing a CD4051BE Mux with MIDI. I have set up 8 buttons connected directly to the MUX (0 - 7), with address A, B and C connected to the a Teensy(digital pins 2, 3, 4). Com 3 is connected to digital pin 5 on Teensy. All buttons are being pulled to ground with 220 ohm resistors and I am having the issue where when i press button 1, it prints out pin pin 13 (0) and pin 1 (4). So technically it is serial printing button 1 and 5 together, when i only press button 1. It does the same with buttons 2, 3 and 4 as follows
When I press:
Button 1 -(Prints Button 1 & 5)
Button 2 -(prints button 2 & 6)
Button 3 -(prints button 3 & 7)
Button 4 -(prints button 4 & 8)
The other 4 buttons don't send any signal nor print.
Please see the code.
Where am i going wrong. I've checked the wiring and everything is correct.
Any help would be great.
Thanks Guys
When I press:
//Multiplexer CD4051BE Address Pins
int addressA = 2; //Address Pin A (Pinout 11)
int addressB = 3; //Address Pin B (Pinout 10)
int addressC = 4; //Address Pin C (Pinout 9)
int b0 = 0; //button values
int b1 = 0; //button values
int b2 = 0; //button values
int b3 = 0; //button values
int b4 = 0; //button values
int b5 = 0; //button values
int b6 = 0; //button values
int b7 = 0; //button values
int b0_prev = 1; // previous button values
int b1_prev = 1; // previous button values
int b2_prev = 1; // previous button values
int b3_prev = 1; // previous button values
int b4_prev = 1; // previous button values
int b5_prev = 1; // previous button values
int b6_prev = 1; // previous button values
int b7_prev = 1; // previous button values
pinMode(1, OUTPUT);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(5, INPUT_PULLUP);
midiMuxButtons();
//MIDI BUTTON FUNCTION
void midiMuxButtons () {
//BUTTON 1//
digitalWrite(addressA, LOW);
digitalWrite(addressB, LOW);
digitalWrite(addressC, LOW);
delayMicroseconds(50); // allow a brief time for the signal to charge/discharge the input pin through the 4051's resistance
b0 = digitalRead(5); // Data Pin from Mux to Microcontroller
if (b0 == HIGH && b0_prev == LOW) {
// signal just went low
usbMIDI.sendNoteOn(0, 110, 1);
Serial.println("Button 1:");
if (b0 == LOW && b0_prev == HIGH) {
// signal just went high
usbMIDI.sendNoteOff(0, 110, 1);
b0_prev = b0;
//BUTTON 2//
digitalWrite(addressA, HIGH);
b1 = digitalRead(5); // Data Pin from Mux to Microcontroller
if (b1 == HIGH && b1_prev == LOW) {
usbMIDI.sendNoteOn(1, 110, 1);
Serial.println("Button 2:");
if (b1 == LOW && b1_prev == HIGH) {
usbMIDI.sendNoteOff(1, 110, 1);
b1_prev = b1;
//BUTTON 3//
digitalWrite(addressB, HIGH);
b2 = digitalRead(5); // Data Pin from Mux to Microcontroller
if (b2 == HIGH && b2_prev == LOW) {
usbMIDI.sendNoteOn(2, 110, 1);
Serial.println("Button 3:");
if (b2 == LOW && b2_prev == HIGH) {
usbMIDI.sendNoteOff(2, 110, 1);
b2_prev = b2;
//BUTTON 4//
b3 = digitalRead(5); // Data Pin from Mux to Microcontroller
if (b3 == HIGH && b3_prev == LOW) {
usbMIDI.sendNoteOn(3, 110, 1);
Serial.println("Button 4:");
if (b3 == LOW && b3_prev == HIGH) {
usbMIDI.sendNoteOff(3, 110, 1);
b3_prev = b3;
//BUTTON 5//
digitalWrite(addressC, HIGH);
b4 = digitalRead(5); // Data Pin from Mux to Microcontroller
if (b4 == HIGH && b4_prev == LOW) {
usbMIDI.sendNoteOn(4, 110, 1);
Serial.println("Button 5:");
if (b4 == LOW && b4_prev == HIGH) {
usbMIDI.sendNoteOff(4, 110, 1);
b4_prev = b4;
//BUTTON 6//
b5 = digitalRead(5); // Data Pin from Mux to Microcontroller
if (b5 == HIGH && b5_prev == LOW) {
usbMIDI.sendNoteOn(5, 110, 1);
Serial.println("Button 6:");
if (b5 == LOW && b5_prev == HIGH) {
usbMIDI.sendNoteOff(5, 110, 1);
b5_prev = b5;
//BUTTON 7//
b6 = digitalRead(5); // Data Pin from Mux to Microcontroller
if (b6 == HIGH && b6_prev == LOW) {
usbMIDI.sendNoteOn(6, 110, 1);
Serial.println("Button 7:");
if (b6 == LOW && b6_prev == HIGH) {
usbMIDI.sendNoteOff(6, 110, 1);
b6_prev = b6;
//BUTTON 8//
b7 = digitalRead(5); // Data Pin from Mux to Microcontroller
if (b7 == HIGH && b7_prev == LOW) {
usbMIDI.sendNoteOn(7, 110, 1);
Serial.println("Button 8:");
if (b7 == LOW && b7_prev == HIGH) {
usbMIDI.sendNoteOff(7, 110, 1);
b7_prev = b7;
while (usbMIDI.read()); // read and discard any incoming MIDI messages
delay(25);
Thanks Guys
