Page 1 of 2 1 2 LastLast
Results 1 to 25 of 30
Thread: Teensyduino 1.37 Beta #4
    Administrator Paul's Avatar
    Oct 2012
    332
    Here is a fourth beta test for Teensyduino 1.37.
    Changes since Teensyduino 1.37-beta3
    Fix SPI SCK (pin 13) drive strength (KurtE)
    Increase USB Serial.begin() wait for serial monitor
    Fix Audio SD WAV play status with LTO optimization
    Teensy Loader window movable by clicking in center area
    Support "Clear output" button in Arduino 1.8.3 serial monitor
    Senior Member+
    3,207
    Ran the updates through the same sketches as before including the USB host shield and everything works fine. board_qc tests seem to work a lot faster as well, maybe the change to spi has something to do with it. Also tried out the "Clear Output" button and that is working as well.
    19,927
    Thanks for testing.
    Unless anyone finds anything soon, or I turn up anything unexpected with more testing, I'm planning to release 1.37 Monday or Tuesday.
    Dec 2016
    Montreal, Canada
    3,002
    teensythreads is not listed under library examples, it works pretty well
    Senior Member+
    3,207
    I would agree with adding teensythreads as well if that is on the table. Was looking for something like that for quite a while.
    19,927
    teensythreads....
    Remind me of this in a week or so, after 1.38-beta1.
    Nothing new is going into 1.37 at this point, only bug fixes. Even fixes, at this late stage, need to be for something quite important.
    1.38-beta1 is already planned to be identical to 1.37, but with the language dialect changed to C++14. Nothing new will be considered for 1.38-beta1, because the idea is to have a beta to test that lets us compare against the prior release for the important switch from C++11 to C++14.
    Let's talk of adding stuff after a little testing on 1.38-beta1. Yeah, I know waiting can be painful, but it's critically important to get to a stable release next week, and to make the first step of such a major change without complicating it by adding any features.
    8,348
    Re: Beta 3 thread:
    I don't understand how you've getting "COM8" without "(Teensy)".
    Here's what I see when I test on Windows 10 ver 1703.
    Paul - I just compiled under the IDE - rather than Stino in SublimeText and it came up normally - still using Beta 3 install.
    The Stino build options were set MIDI - My Bad.
    So I went back and tried the HelloSerialMonitor example again.
    First, I tried it on a mac, and that worked just fine.
    Then I went back to my linux machine and tried all the usb type settings, here are the results: (yes means Serial Monitor is working)
    serial: yes
    keyboard: no
    keyboard+touchscreen: no
    keyboard+mouse+touchscreen: no
    keyboard+mouse+joystick: yes
    serial+keyboard+mouse+joystick: yes
    midi: yes
    serial+midi: yes
    serial+midi+audio: yes
    audio: no
    mtp disk (experimental): no
    raw HID: yes
    flight sim controls: yes
    flight sim controls+joystick: no
    all of the above: yes
    Unsurprisingly, all the CDC serial options work just fine. The other results are kind of weird, but I tried it forwards and backwards and got the same results.
    So, then I decided to try an older teensyduino, and I still get the same result....
    So, good news: This Beta didn't break anything in USB
    Bad news: It's was already broken.... (At least on Ubuntu 16.04.2 LTS, with kernel 4.4.0-78-generic)
    Does anybody else have an Ubuntu 16-something machine they can try it on? Maybe it's just my machine somehow?
    (All that's needed to do to reproduce this results is: 1) open examples->Teensy->Tutorial3->HelloSerialMonitor, select one of the options that doesn't work in the list above, compile and upload, open serial monitor and see if says "hello world" once per second or not.)
    For me personally, a workaround would be to replace "MTS disk" with "MTS disk + Serial" I suppose, but it seems like there might be bigger problems here.
    Senior Member+
    3,207
    Quote Originally Posted by hubbe View Post
    I tested all the "no" responses on a Windows 10 with Beta4 and in all cases I did get a hello world response:
    keyboard: yes
    keyboard+touchscreen: yes
    keyboard+mouse+touchscreen: yes
    audio: yes
    mtp disk (experimental): yes
    flight sim controls+joystick: yes
    What I did notice is that the first time I opened the SerMon it would indicate that the connection was closed. If I closed the monitor and then reopened it, it would start printing out "Hello World". This open-close process would have to be repeated if I closed the monitor after Hello world was printing.
    19,927
    Any chance there's an old instance of teensy_gateway still running on your Linux machine? It's supposed to terminate when you quit Arduino. But if you somehow got an old version (from before these newer options were added) of that still running on your machine, it would explain why some work and others don't. That's really the only explanation I can imagine.
    19,927
    keyboard: yes
    audio: yes
    I just retested all of these on Linux 64 bit. They all work.
    Dec 2016
    Montreal, Canada
    3,002
    mjs513, sometimes i just click on the serial monitor button even if its already open, it comes back to life whenever i plug power in the teensy if it was already open, clicking the IDE button refreshes(reopens) the com connection even if the window was still open and said offline
    I don't think so, I checked and it says the teensy_gateway was started yesterday.
    I'm going to reboot my machine later to see if there something else that's stuck somehow.
    I also took my T3.6 to work to do some testing there, and it's acting strange too.
    First of all, programming doesn't seem to work unless I run as root. (Probably some udev rule I need to tweak.) It's confusing though because there's no error message, programming just doesn't happen.
    It wasn't until I tried the command-line tool that I realized that there might be a permission problem. (I got this message: Unable to claim interface, check USB permission.)
    Anyways, when I run as root, I get the opposite behavior from home: All the emulated serial options work, but the CDC serial options do not.
    My work machine is a slightly tweaked ubuntu 14.04 running a 4.4.0 kernel.
    Senior Member+
    3,207
    @tonton81. Thanks for that tidbit. Never realized that. Learn something new everyday.
    19,927
    Any chance you're working with an old copy of the udev rule file? It was updated a few versions ago when I put in the first (non-working) MTP stuff.
    The installer doesn't do anything with the udev rules. Most of that is due to the issues with getting temporary root permissions, and the general assumption that most Linux users are experts. Maybe it should at least try looking at the file and notice if it's missing or not the same as the latest?
    I don't seem to have an udev rule file at all. (Neither at home nor at work.)
    Installing the udev file makes things works a lot better at work. CDC works, and I don't need to run as root anymore.
    I hope it makes everything work at home too, will find out later...
    So I had a much older version of the udev rules installed at home.
    Unfortunately updating the rules didn't seem to help.
    However, running as root does for some reason. I don't understand how this can be a permission problem since some configuration works, but seems to be what it is anyways.
    I tried adding myself to the plugdev group, but that didn't seem to be sufficient. I *really* wish that it would give me some sort of error message, that would make it much easier to know what is going on.
    So this might not be the greatest solution to the permission problems, but I added this to my udev rules to make the relevant /dev/hidraw* file accessible:
    SUBSYSTEM=="hidraw", DEVPATH=="*/usb*:16C0:04[789ABCD]?.*", MODE:="0666"
    Using ATTRS{idVendor} or ATTRS{idProduct} doesn't seem to work on hidraw devices. At least not on my machine.
    May 2017
    5
    Hi all ,
    I was working with a Teensyduino 1.27 with arduino 1.6.9 before and everything worked fine with it.
    Now i reinstalled everything fresh with arduino 1.6.9 but with the latest Teensy 1.37 version and it is showing me
    Fatal error: No EEPROM.h file not found .
    Basically i was using the library version EEPROM i.e <EEPROM.h> it didn't pose a problem before but now it does.
    Is there any way i can the previous version of Teensduino especially if it is 1.27.?
    Regards,
    Abhi
    19,927
    EEPROM works when I try here with the latest.
    Edit: also tried with Arduino 1.6.9. Works fine. I tried on Linux 64 bit with Teensy 3.6 selected. Which system & board are you using?
    May 2017
    5
    Thank you for your fast reply Paul.
    I am using Teensy 3.2 with 48MHz Serial Optimize : Faster
    Yes i have tried the library examples and it works too. I am doing the same include and it says fatal error file not found
    Its the problem in my source code .
    I am attaching a screenshot so you can see.
    At line number 6 when i include <EEPROM.h>
    I copy pasted library files in my source code and changed to "EEPROM.h" then it compiles fine.
    Just wondering what changed which will cause this error now in version 1.37.
    i compiled the same source code with teensy 1.29 and works fine.
    Thanks. Regards,
    Abhi
    4,548
    Maybe the compiler and/or - preprocessor.
    But I noticed on my current machine the file name is: eeprom.h and not EEPROM.h. So you might try changing the case of the file name in your sketch and see if that
    makes a difference
    19,927
    Quote Originally Posted by abhi View Post
    I'm wondering the same thing. But from only this screenshot, I can not tell.
    My guess is you can't share this project code, right?
    Could you at least turn on verbose info while compiling in File > Preferences. Then recompile for the same error, and click the Copy Error Messages button to get the complete list of all the error text. When you post it here, put it in code tags (click "Go Advanced" if using quick reply, to get the full editor with code tags) so it's easier to read your message.
  24. #24
    May 2017
    5
    Yes i cannot share the whole code.
    Note: I tested with the eeprom.h too but it is giving the same error.
    Here is the error message below.
    "C:\Users\Abhishek\AppData\Local\Temp\build6b0b3b7 7b0d882d4e71564aa465c95c2.tmp\sketch\ubx_uart.cpp" -o "nul"
    "D:\arduino-1.6.9\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++11 -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=137 -DARDUINO=10609 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-ID:\arduino-1.6.9\hardware\teensy\avr\cores\teensy3" "C:\Users\Abhishek\AppData\Local\Temp\build6b0b3b7 7b0d882d4e71564aa465c95c2.tmp\sketch\menuSystem.in o.cpp" -o "C:\Users\Abhishek\AppData\Local\Temp\build6b0b3b7 7b0d882d4e71564aa465c95c2.tmp\preproc\ctags_target _for_gcc_minus_e.cpp"
    In file included from C:\Users\Abhishek\AppData\Local\Temp\build6b0b3b77 b0d882d4e71564aa465c95c2.tmp\sketch\Logging.h:17:0 ,
    from C:\Users\Abhishek\AppData\Local\Temp\build6b0b3b77 b0d882d4e71564aa465c95c2.tmp\sketch\TaskScheduler. h:15,
    from C:\Users\Abhishek\Desktop\Awearable Apparel\PlaySafe\TomMenuSystem\menuSystem\menuSyst em.ino:9:
    C:\Users\Abhishek\AppData\Local\Temp\build6b0b3b77 b0d882d4e71564aa465c95c2.tmp\sketch\EepromTeensy.h :13:20: fatal error: EEPROM.h: No such file or directory
    compilation terminated.
    Error compiling for board Teensy 3.2 / 3.1.
  25. #25
    4,548
    Actually from here it still looks like the file EepromTeensy.h is still looking for EEPROM.h... Again not sure if it will fix it, but I do known under Linux the case must match the actual file.
