Results 1 to 5 of 5
Thread: Vector Font library for Teensy 3.6
    Attached is a vector based font library 'vFont' that I've been working on as part of another project, for a Teensy3.6. vFont features most things one would expect from a vector font library; such as configurable paths', brush types and size and string/glyph orientation. To keep performance up, vFont renders directly to a frame buffer, then written to display whenever (see demo).
    Here it is released separately as an easily expandable C API (C, none of this class rubbish here).
    Source: vfont_210617.zip
    Usage example, to draw the base green layer from the attached video:
    // set the initial state
    setFont(ctx, &gothiceng);
    setGlyphScale(ctx, 4.0f);
    setRenderFilter(ctx, RENDEROP_NONE);
    setBrush(ctx, BRUSH_DISK);
    setBrushStep(ctx, 5.0f);
    setBrushSize(ctx, 40.0f);
    setBrushColour(ctx, COLOUR_PAL_DARKGREEN);
    // now do the rendering
    drawString(ctx, "Gothic", x, y);
    Animated text:
    27,705
    That looks really awesome!
    11,466
    Looks cool - What display are you using? I see in the code referencing something like usbd480.
    I like the demo!
    Cheers.
    Kurte, The display name is USBD480 and is unconnected/separate from the font library. It's a Highspeed USB interfaced display, 16bpp with a resolution of 480x272 (from a PSP) with a touch panel on top, with an 8megabyte fully addressable framebuffer. Basically an MSP30 (if memory recalls) driving an FPGA with a 2046 touch controller wrapped round a composite USB interface. Source code for this is also included in the zip.
    Teensy36 has no problem driving this while also handling the full floating point vector [drawing] routines.
    May 2022
    Paris, France
    9
    Hi Michael
    This is an old post, I realise, but I just found it and decided to have a go at adapting your code for the Teensy 4.1 and my vstcm vector generator PCB which targets real vector monitors (https://github.com/english1234/vstcm). It works quite well! Here's a quick video (sorry for the awful quality, it looks great in reality): https://youtu.be/WIkLRix-tPs
    Regards
    Robin
