Results 1 to 11 of 11
Thread: Teensy and Stepper Control
    Jun 2017
    5
    Hi a piece of software called Dragonframe interfaces with Arduino Uno and Mega to control 4 or 8 stepper motors respectively using either Big easy drivers or Pololu drivers will the DFmoco sketch run on a Teensy 3.6 as is or would it need some modification? I believe the Sketch uses digitalWrite() calls and communicates via serial.
    Here is a link to the Sketch on Github
    I found this conversation between Paul and someone but it ends with no conclusion I would also be looking for the Teensy to be treated as a Mega.
    Also how would the pins from the Arduino Mega/Uno correlate to the Teensy pins? On the Mega they are listed as 4,5-6,7-8,9-10,11 and 28,29-30,31-32,33-34,35 for step and direction Gnd and also if using the Pololu drivers they have to be connect to 3.3v as well. Sorry new to this.
    Thanks in advance ;-)
    Apr 2013
    1,763
    The Teensy 3.2 pins are aligned with the Uno, the T3.6 keeps that and adds more on the end. Neither Uno nor Teensy has much commonality with a Mega.
    If it's using digitalWrite and serial, as long as your hardware works on 3.3V (T3.6 doesn't like 5V coming in from say a serial port but does look like that's already covered) you should be good.
    Before spending money, suggest getting Teensyduino downloaded and installed and seeing of the code compiles. Doesn't say that'll work properly but will tell you if there is AVR assembler buried somewhere that will be a nightmare to fix.
    You may fine timing related functions need tweaking, depending on if the original code uses millis() or straight delay loops to control how often it steps. Also, do you actually need the T3.6? With four steppers at least would have thought a T3.2 or even an LC might be good enough.
    Jun 2017
    5
    Hi thanks for you help, I picked the 3.6 purely because it was the better faster model for ongoing longevity.
    I took you advice and tried to compile and got an error
    #error Cannot identify board
    my understanding it is because of the previous lines of code
    // detect board type
    #if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
      #define BOARD ARDUINOMEGA
    #elif defined(__AVR_ATmega328P__) || defined(__AVR_ATmega328__)  || defined(__AVR_ATmega168__)
    #elif defined(__PIC32MX__)
      #define BOARD CHIPKITMAX32
    #elif defined(BOARD_maple) || defined(BOARD_maple_RET6)
      #define BOARD MAPLE
    #else
    ideally I would like to add the teensy 3.6 for now to that list and point it to the Mega pinout but am a little unsure as to how to go about it...
    Whole Sketch Below..
    #define DFMOCO_VERSION 1
    #define DFMOCO_VERSION_STRING "1.2.7"
      DFMoco version 1.2.7
      Multi-axis motion control.
      For use with the Arc motion control system in Dragonframe 3.
      Generates step and direction signals, which can be sent to stepper motor drivers.
      Control up to four axes with an Uno or Duemilanove board.
      Control up to eight axes with a Mega or Mega 2560, chipKit MAX32 or LeafLabs Maple.
      Version History
      Version 1.2.7 Direction setup time.
      Version 1.2.6 Add PINOUT_VERSION option to use older pinout.
      Version 1.2.5 Fix jogging with low pulse rate.
      Version 1.2.4 Fix pin assignments
      Version 1.2.3 New Position command
      Version 1.2.2 Jog and Inch commands
      Version 1.2.1 Moved step/direction pins for motions 5-8.
                    Detects board type automatically.
      Version 1.2.0 Basic go-motion capabilities
      Version 1.1.2 Smooth transitions when changing direction
      Version 1.1.1 Save/restore motor position
      Version 1.1.0 Major rework
      Version 1.0.2 Moved pulses into interrupt handler
      Version 1.0.1 Added delay for pulse widths
      Version 1.0.0 Initial public release.
      Getting Started:
       1. Install IDE (Integrated Development Environment)
          - For Arduino, go to http://arduino.cc and download "Arduino 0023" for your OS.
          - For chipKIT, go to https://github.com/chipKIT32/chipKIT32-MAX/downloads and download "mpide-0023" for your OS.
          - For Maple, go to http://leaflabs.com/docs/maple-ide-install.html#os-x and download the Maple IDE for your OS.
       2. Run the IDE you installed.
       3. Open this file in the IDE.
       4. Go to the Tools menu of the IDE and choose the Board type you are using.
       5. Verify/Compile the sketch. (Command-R on Mac, Control-R on Windows.)
       6. After this finishes, Upload the code to the board. (Command-U on Mac, Control-U on Windows.)
      Pin configuration:
      channel 1
            PIN   4   step
            PIN   5   direction
      channel 2
            PIN   6   step
            PIN   7   direction
      channel 3
            PIN   8   step
            PIN   9   direction
      channel 4
            PIN  10   step
            PIN  11   direction
      channel 5
            PIN  28   step
            PIN  29   direction
      channel 6
            PIN  30   step
            PIN  31   direction
      channel 7
            PIN  32   step
            PIN  33   direction
      channel 8
            PIN  34   step
            PIN  35   direction
    // supported boards
    #define ARDUINO      1
    #define ARDUINOMEGA  2
    #define MAPLE        3
    #define CHIPKITMAX32 4
    // change this to 1 if you want original pinout for channels 5-8
    #define PINOUT_VERSION 2
      This is PINOUT_VERSION 1
      channel 5
            PIN  22   step
            PIN  23   direction
      channel 6
            PIN  24   step
            PIN  25   direction
      channel 7
            PIN  26   step
            PIN  27   direction
      channel 8
            PIN  28   step
            PIN  29   direction
      #define BOARD MAPLE
    #else
    // USER: if you want a kill switch, uncomment out the next line by removing the // characters
    //#define KILL_SWITCH_INTERRUPT 0
    #if BOARD == MAPLE
      #ifndef uint16_t
        #define uint16_t uint16
        #define int32_t  int32
      #define SERIAL_DEVICE SerialUSB
      #define PIN_ON(port, pin) { gpio_write_bit(port, pin, HIGH); }
      #define PIN_OFF(port, pin) { gpio_write_bit(port, pin, LOW); }
    #elif BOARD == CHIPKITMAX32
      #include <plib.h>
      #define PIN_ON(port, pin)  { digitalWrite(port, HIGH); }
      #define PIN_OFF(port, pin) { digitalWrite(port, LOW); }
    #else
      #define PIN_ON(port, pin)  { port |= pin; }
      #define PIN_OFF(port, pin) { port &= ~pin; }
    // Arduino Uno/Duemilanove  -> 4 MOTORS MAX
    // Arduino Mega 2560 / Mega -> 8 MOTORS MAX
    #if BOARD == ARDUINO
    #define MOTOR_COUNT 4
    #else
    #define MOTOR_COUNT 8
    #define TIME_CHUNK 50
    #define SEND_POSITION_COUNT 20000
    // update velocities 20 x second
    #define VELOCITY_UPDATE_RATE (50000 / TIME_CHUNK)
    #define VELOCITY_INC(maxrate) (max(1.0f, maxrate / 70.0f))
    // setup step and direction pins
    #if BOARD == CHIPKITMAX32
      #define MOTOR0_STEP_PORT 4
      #define MOTOR0_STEP_PIN  0
      #define MOTOR1_STEP_PORT 6
      #define MOTOR1_STEP_PIN  0
      #define MOTOR2_STEP_PORT 8
      #define MOTOR2_STEP_PIN  0
      #define MOTOR3_STEP_PORT 10
      #define MOTOR3_STEP_PIN  0
      #if ( PINOUT_VERSION == 2 )
        #define MOTOR4_STEP_PORT 28
        #define MOTOR4_STEP_PIN  0
        #define MOTOR5_STEP_PORT 30
        #define MOTOR5_STEP_PIN  0
        #define MOTOR6_STEP_PORT 32
        #define MOTOR6_STEP_PIN  0
        #define MOTOR7_STEP_PORT 34
        #define MOTOR7_STEP_PIN  0
      #elif ( PINOUT_VERSION == 1 )
        #define MOTOR4_STEP_PORT 22
        #define MOTOR5_STEP_PORT 24
        #define MOTOR6_STEP_PORT 26
        #define MOTOR7_STEP_PORT 28
    #elif BOARD == MAPLE
      #define MOTOR0_STEP_PORT GPIOB
      #define MOTOR0_STEP_PIN  5
      #define MOTOR1_STEP_PORT GPIOA
      #define MOTOR1_STEP_PIN  8
      #define MOTOR2_STEP_PORT GPIOA
      #define MOTOR2_STEP_PIN  10
      #define MOTOR3_STEP_PORT GPIOA
      #define MOTOR3_STEP_PIN  4
        #define MOTOR4_STEP_PORT GPIOB
        #define MOTOR4_STEP_PIN  1
        #define MOTOR5_STEP_PORT GPIOB
        #define MOTOR5_STEP_PIN  11
        #define MOTOR6_STEP_PORT GPIOB
        #define MOTOR6_STEP_PIN  13
        #define MOTOR7_STEP_PORT GPIOB
        #define MOTOR7_STEP_PIN  15
        #define MOTOR4_STEP_PORT GPIOC
        #define MOTOR4_STEP_PIN  14
        #define MOTOR5_STEP_PORT GPIOC
        #define MOTOR5_STEP_PIN  15
        #define MOTOR6_STEP_PORT GPIOC
        #define MOTOR6_STEP_PIN  6
        #define MOTOR7_STEP_PORT GPIOC
        #define MOTOR7_STEP_PIN  7
    #elif defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
      #define MOTOR0_STEP_PORT PORTG
      #define MOTOR0_STEP_PIN  B00100000
      #define MOTOR1_STEP_PORT PORTH
      #define MOTOR1_STEP_PIN  B00001000
      #define MOTOR2_STEP_PORT PORTH
      #define MOTOR2_STEP_PIN  B00100000
      #define MOTOR3_STEP_PORT PORTB
      #define MOTOR3_STEP_PIN  B00010000
        #define MOTOR4_STEP_PORT PORTA
        #define MOTOR4_STEP_PIN  B01000000
        #define MOTOR5_STEP_PORT PORTC
        #define MOTOR5_STEP_PIN  B10000000
        #define MOTOR6_STEP_PORT PORTC
        #define MOTOR6_STEP_PIN  B00100000
        #define MOTOR7_STEP_PORT PORTC
        #define MOTOR7_STEP_PIN  B00001000
        #define MOTOR4_STEP_PIN  B00000001
        #define MOTOR5_STEP_PORT PORTA
        #define MOTOR5_STEP_PIN  B00000100
        #define MOTOR6_STEP_PORT PORTA
        #define MOTOR6_STEP_PIN  B00010000
        #define MOTOR7_STEP_PORT PORTA
        #define MOTOR7_STEP_PIN  B01000000
    #else
      #define MOTOR0_STEP_PORT PORTD
      #define MOTOR0_STEP_PIN  B00010000
      #define MOTOR1_STEP_PORT PORTD
      #define MOTOR1_STEP_PIN  B01000000
      #define MOTOR2_STEP_PORT PORTB
      #define MOTOR2_STEP_PIN  B00000001
      #define MOTOR3_STEP_PIN  B00000100
     * Serial output specialization
    #if defined(UBRRH)
    #define TX_UCSRA UCSRA
    #define TX_UDRE  UDRE
    #define TX_UDR   UDR
    #else
    #define TX_UCSRA UCSR0A
    #define TX_UDRE  UDRE0
    #define TX_UDR   UDR0
    char txBuf[32];
    char *txBufPtr;
    #define TX_MSG_BUF_SIZE 16
    #define MSG_STATE_START 0
    #define MSG_STATE_CMD   1
    #define MSG_STATE_DATA  2
    #define MSG_STATE_ERR   3
    #define MSG_STATE_DONE  100
     * Command codes from user
    #define USER_CMD_ARGS 40
    #define CMD_NONE       0
    #define CMD_HI         10
    #define CMD_MS         30
    #define CMD_NP         31
    #define CMD_MM         40 // move motor
    #define CMD_PR         41 // pulse rate
    #define CMD_SM         42 // stop motor
    #define CMD_MP         43 // motor position
    #define CMD_ZM         44 // zero motor
    #define CMD_SA         50 // stop all (hard)
    #define CMD_BF         60 // blur frame
    #define CMD_GO         61 // go!
    #define CMD_JM         70 // jog motor
    #define CMD_IM         71 // inch motor
    #define MSG_HI 01
    #define MSG_MM 02
    #define MSG_MP 03
    #define MSG_MS 04
    #define MSG_PR 05
    #define MSG_SM 06
    #define MSG_SA 07
    #define MSG_BF 10
    #define MSG_GO 11
    #define MSG_JM 12
    #define MSG_IM 13
    struct UserCmd
      byte command;
      byte argCount;
      int32_t args[USER_CMD_ARGS];
     * Message state machine variables.
    byte lastUserData;
    int  msgState;
    int  msgNumberSign;
    UserCmd userCmd;
    struct txMsg
      byte msg;
      byte motor;
    struct TxMsgBuffer
      txMsg buffer[TX_MSG_BUF_SIZE];
      byte head;
      byte tail;
    TxMsgBuffer txMsgBuffer;
     Motor data.
    uint16_t           motorAccumulator0;
    uint16_t           motorAccumulator1;
    uint16_t           motorAccumulator2;
    uint16_t           motorAccumulator3;
    #if MOTOR_COUNT > 4
    uint16_t           motorAccumulator4;
    uint16_t           motorAccumulator5;
    uint16_t           motorAccumulator6;
    uint16_t           motorAccumulator7;
    uint16_t*          motorAccumulator[MOTOR_COUNT] =
      &motorAccumulator0, &motorAccumulator1, &motorAccumulator2, &motorAccumulator3,
    #if MOTOR_COUNT > 4
      &motorAccumulator4, &motorAccumulator5, &motorAccumulator6, &motorAccumulator7
    uint16_t           motorMoveSteps0;
    uint16_t           motorMoveSteps1;
    uint16_t           motorMoveSteps2;
    uint16_t           motorMoveSteps3;
    #if MOTOR_COUNT > 4
    uint16_t           motorMoveSteps4;
    uint16_t           motorMoveSteps5;
    uint16_t           motorMoveSteps6;
    uint16_t           motorMoveSteps7;
    uint16_t*          motorMoveSteps[MOTOR_COUNT] =
      &motorMoveSteps0, &motorMoveSteps1, &motorMoveSteps2, &motorMoveSteps3,
    #if MOTOR_COUNT > 4
      &motorMoveSteps4, &motorMoveSteps5, &motorMoveSteps6, &motorMoveSteps7
    uint16_t           motorMoveSpeed0;
    uint16_t           motorMoveSpeed1;
    uint16_t           motorMoveSpeed2;
    uint16_t           motorMoveSpeed3;
    #if MOTOR_COUNT > 4
    uint16_t           motorMoveSpeed4;
    uint16_t           motorMoveSpeed5;
    uint16_t           motorMoveSpeed6;
    uint16_t           motorMoveSpeed7;
    uint16_t         * motorMoveSpeed[MOTOR_COUNT] =
      &motorMoveSpeed0, &motorMoveSpeed1, &motorMoveSpeed2, &motorMoveSpeed3,
    #if MOTOR_COUNT > 4
      &motorMoveSpeed4, &motorMoveSpeed5, &motorMoveSpeed6, &motorMoveSpeed7
    volatile boolean nextMoveLoaded;
    unsigned int   velocityUpdateCounter;
    byte           sendPositionCounter;
    boolean        hardStopRequested;
    byte sendPosition = 0;
    byte motorMoving = 0;
    byte toggleStep = 0;
    #define P2P_MOVE_COUNT 7
    struct Motor
      byte   stepPin;
      byte   dirPin;
      // pre-computed move
      float   moveTime[P2P_MOVE_COUNT];
      int32_t movePosition[P2P_MOVE_COUNT];
      float   moveVelocity[P2P_MOVE_COUNT];
      float   moveAcceleration[P2P_MOVE_COUNT];
      float   gomoMoveTime[P2P_MOVE_COUNT];
      int32_t gomoMovePosition[P2P_MOVE_COUNT];
      float   gomoMoveVelocity[P2P_MOVE_COUNT];
      float   gomoMoveAcceleration[P2P_MOVE_COUNT];
      int       currentMove;
      float     currentMoveTime;
      volatile  boolean   dir;
      int32_t   position;
      int32_t   destination;
      float     maxVelocity;
      float     maxAcceleration;
      uint16_t  nextMotorMoveSteps;
      float     nextMotorMoveSpeed;
    boolean goMoReady;
    int     goMoDelayTime;
    Motor motors[MOTOR_COUNT];
    #ifdef KILL_SWITCH_INTERRUPT
    void killSwitch()
      hardStopRequested = true;
    #if (BOARD == MAPLE)
      HardwareTimer timer(2);
     * setup() gets called once, at the start of the program.
      goMoReady = false;
      lastUserData = 0;
      msgState = MSG_STATE_START;
      velocityUpdateCounter = 0;
      sendPositionCounter = 10;
      nextMoveLoaded = false;
      hardStopRequested = false;
      for (int i = 0; i < 32; i++)
        txBuf[i] = 0;
      txBufPtr = txBuf;
      attachInterrupt(KILL_SWITCH_INTERRUPT, killSwitch, CHANGE);
      // initialize motor structures
      for (int i = 0; i < MOTOR_COUNT; i++)
        // setup motor pins - you can customize/modify these after loop
        // default sets step/dir pairs together, with first four motors at 4/5, 6/7, 8/9, 10/11
        // then, for the Mega boards, it jumps to 28/29, 30/31, 32/33, 34/35
          motors[i].stepPin = (i * 2) + ( (i < 4) ? 4 : 20 );
          motors[i].stepPin = (i * 2) + ( (i < 4) ? 4 : 14 );
        motors[i].dirPin = motors[i].stepPin + 1;
        motors[i].dir = true; // forward
        motors[i].position = 0L;
        motors[i].destination = 0L;
        motors[i].nextMotorMoveSteps = 0;
        motors[i].nextMotorMoveSpeed = 0;
        setPulsesPerSecond(i, 5000);
      // set output pins
        pinMode(motors[i].stepPin, OUTPUT);
        pinMode(motors[i].dirPin, OUTPUT);
        // disable PWM
        switch (motors[i].stepPin)
          #if defined(TCCR3A) && defined(COM3B1)
          case 4:
            TCCR3A &= ~COM3B1;
          #if defined(TCCR4A) && defined(COM4A1)
          case 6:
            TCCR4A &= ~COM4A1;
          #if defined(TCCR4A) && defined(COM4C1)
          case 8:
            TCCR4A &= ~COM4C1;
          #if defined(TCCR2A) && defined(COM2A1)
          case 10:
            TCCR2A &= ~COM2A1;
    #else
          #if defined(TCCR1A) && defined(COM1B1)
          case 10:
            TCCR1A &= ~COM1B1;
      // set initial direction
        digitalWrite( motors[i].dirPin, motors[i].dir ? HIGH : LOW );
      // setup serial connection
      #if (BOARD == ARDUINO) || (BOARD == ARDUINOMEGA) || (BOARD == CHIPKITMAX32)
      Serial.begin(57600);
      sendMessage(MSG_HI, 0);
      // SET UP interrupt timer
      #if (BOARD == CHIPKITMAX32)
        ConfigIntTimer1(T1_INT_ON | T1_INT_PRIOR_1);
        OpenTimer1(T1_ON | T1_PS_1_1, F_CPU / (2 * 1000000L / TIME_CHUNK));
      #elif (BOARD == ARDUINO) || (BOARD == ARDUINOMEGA)
        TCCR1A = 0;
        TCCR1B = _BV(WGM13);
        ICR1 = (F_CPU / 4000000) * TIME_CHUNK; // goes twice as often as time chunk, but every other event turns off pins
        TCCR1B &= ~(_BV(CS10) | _BV(CS11) | _BV(CS12));
        TIMSK1 = _BV(TOIE1);
        TCCR1B |= _BV(CS10);
      #elif (BOARD == MAPLE)
        timer.pause();
        timer.setPeriod(TIME_CHUNK / 2); // in microseconds
        // Set up an interrupt on channel 1
        timer.setChannel1Mode(TIMER_OUTPUT_COMPARE);
        timer.setCompare(TIMER_CH1, 1);  // Interrupt 1 count after each update
        timer.attachCompare1Interrupt(mapleTimerHandler);
        // Refresh the timer's count, prescale, and overflow
        timer.refresh();
        // Start the timer counting
        timer.resume();
    extern "C"
    void __ISR(_TIMER_1_VECTOR,ipl3) playSample(void)
      mT1ClearIntFlag();
    void mapleTimerHandler(void)
    #else
    ISR(TIMER1_OVF_vect)
      toggleStep = !toggleStep;
      if (toggleStep)
        // MOTOR 1
        if (motorMoveSteps0)
          uint16_t a = motorAccumulator0;
          motorAccumulator0 += motorMoveSpeed0;
          if (motorAccumulator0 < a)
            motorMoveSteps0--;
            PIN_ON(MOTOR0_STEP_PORT, MOTOR0_STEP_PIN);
        // MOTOR 2
        if (motorMoveSteps1)
          uint16_t a = motorAccumulator1;
          motorAccumulator1 += motorMoveSpeed1;
          if (motorAccumulator1 < a)
            motorMoveSteps1--;
            PIN_ON(MOTOR1_STEP_PORT, MOTOR1_STEP_PIN);
        // MOTOR 3
        if (motorMoveSteps2)
          uint16_t a = motorAccumulator2;
          motorAccumulator2 += motorMoveSpeed2;
          if (motorAccumulator2 < a)
            motorMoveSteps2--;
            PIN_ON(MOTOR2_STEP_PORT, MOTOR2_STEP_PIN);
        // MOTOR 4
        if (motorMoveSteps3)
          uint16_t a = motorAccumulator3;
          motorAccumulator3 += motorMoveSpeed3;
          if (motorAccumulator3 < a)
            motorMoveSteps3--;
            PIN_ON(MOTOR3_STEP_PORT, MOTOR3_STEP_PIN);
    #if MOTOR_COUNT > 4
        // MOTOR 5
        if (motorMoveSteps4)
          uint16_t a = motorAccumulator4;
          motorAccumulator4 += motorMoveSpeed4;
          if (motorAccumulator4 < a)
            motorMoveSteps4--;
            PIN_ON(MOTOR4_STEP_PORT, MOTOR4_STEP_PIN);
        // MOTOR 6
        if (motorMoveSteps5)
          uint16_t a = motorAccumulator5;
          motorAccumulator5 += motorMoveSpeed5;
          if (motorAccumulator5 < a)
            motorMoveSteps5--;
            PIN_ON(MOTOR5_STEP_PORT, MOTOR5_STEP_PIN);
        // MOTOR 7
        if (motorMoveSteps6)
          uint16_t a = motorAccumulator6;
          motorAccumulator6 += motorMoveSpeed6;
          if (motorAccumulator6 < a)
            motorMoveSteps6--;
            PIN_ON(MOTOR6_STEP_PORT, MOTOR6_STEP_PIN);
        // MOTOR 8
        if (motorMoveSteps7)
          uint16_t a = motorAccumulator7;
          motorAccumulator7 += motorMoveSpeed7;
          if (motorAccumulator7 < a)
            motorMoveSteps7--;
            PIN_ON(MOTOR7_STEP_PORT, MOTOR7_STEP_PIN);
        velocityUpdateCounter++;
        if (velocityUpdateCounter == VELOCITY_UPDATE_RATE)
          if (sendPositionCounter)
            sendPositionCounter--;
            if (*motorMoveSpeed[i] && !motors[i].nextMotorMoveSpeed)
              bitSet(sendPosition, i);
            *motorMoveSteps[i] = motors[i].nextMotorMoveSteps;
            *motorMoveSpeed[i] = motors[i].nextMotorMoveSpeed;
            digitalWrite(motors[i].dirPin, motors[i].dir);
            *motorAccumulator[i] = 65535;
          nextMoveLoaded = false; // ready for new move
        PIN_OFF(MOTOR0_STEP_PORT, MOTOR0_STEP_PIN);
        PIN_OFF(MOTOR1_STEP_PORT, MOTOR1_STEP_PIN);
        PIN_OFF(MOTOR2_STEP_PORT, MOTOR2_STEP_PIN);
        PIN_OFF(MOTOR3_STEP_PORT, MOTOR3_STEP_PIN);
        #if MOTOR_COUNT > 4
          PIN_OFF(MOTOR4_STEP_PORT, MOTOR4_STEP_PIN);
          PIN_OFF(MOTOR5_STEP_PORT, MOTOR5_STEP_PIN);
          PIN_OFF(MOTOR6_STEP_PORT, MOTOR6_STEP_PIN);
          PIN_OFF(MOTOR7_STEP_PORT, MOTOR7_STEP_PIN);
    } // extern "C"
     * For stepper-motor timing, every clock cycle counts.
    #if (BOARD == ARDUINO || BOARD == ARDUINOMEGA)
      int32_t *ramValues = (int32_t *)malloc(sizeof(int32_t) * MOTOR_COUNT);
      int32_t *ramNotValues = (int32_t *)malloc(sizeof(int32_t) * MOTOR_COUNT);
    #else
      int32_t ramValues[MOTOR_COUNT];
      int32_t ramNotValues[MOTOR_COUNT];
      while (true)
        if (!nextMoveLoaded)
          updateMotorVelocities();
        processSerialCommand();
        // check if we have serial output
        if (*txBufPtr)
          if ((TX_UCSRA) & (1 << TX_UDRE))
            TX_UDR = *txBufPtr++;
            // we are done with this msg, get the next one
            if (!*txBufPtr)
              nextMessage();
        if (!sendPositionCounter)
          sendPositionCounter = 20;
          byte i;
          for (i = 0; i < MOTOR_COUNT; i++)
            if (bitRead(motorMoving, i) || bitRead(sendPosition, i))
              sendMessage(MSG_MP, i);
    //          ramValues[i] = motors[i].position;
    //          ramNotValues[i] = ~motors[i].position;
          sendPosition = 0;
     * Update velocities.
    void updateMotorVelocities()
      // process hard stop interrupt request
      if (hardStopRequested)
        hardStopRequested = 0;
        hardStop();
      for (int m = 0; m < MOTOR_COUNT; m++)
        Motor *motor = &motors[m];
        motor->nextMotorMoveSteps = 0;
        motor->nextMotorMoveSpeed = 0;
        if (bitRead(motorMoving, m))
          int seg = motor->currentMove;
          if (motor->moveTime[seg] == 0)
            bitClear(motorMoving, m);
            float originalMoveTime = motor->currentMoveTime;
            int originalMove = motor->currentMove;
            motor->currentMoveTime += 0.05f;
            if (motor->currentMoveTime >= motor->moveTime[seg])
              motor->currentMoveTime -= motor->moveTime[seg];
              motor->currentMove++;
              seg++;
            float t = motor->currentMoveTime;
            int32_t xn = (int32_t)(motor->movePosition[seg] + motor->moveVelocity[seg] * t + motor->moveAcceleration[seg] * t * t); // accel was already multiplied * 0.5
            int32_t dx = abs(xn - motor->position);
            if (!dx) // don't change direction flag unless we are actually stepping in new direction
              continue;
            boolean forward = xn > motor->position;
            if (forward != motor->dir) // direction setup time 1/20th second should be plenty
              // revert everything except for dir flag
              motor->currentMoveTime = originalMoveTime;
              motor->currentMove = originalMove;
              motor->nextMotorMoveSpeed = max(1, min(65535, dx * 65.6f));
              motor->nextMotorMoveSteps = dx;
              motor->position = xn;
            motor->dir = forward;
      nextMoveLoaded = true;
     * Set up the axis for pulses per second (approximate)
    void setPulsesPerSecond(int motorIndex, uint16_t pulsesPerSecond)
      if (pulsesPerSecond > 20000)
        pulsesPerSecond = 20000;
      if (pulsesPerSecond < 100)
        pulsesPerSecond = 100;
      uint16_t itersPerSecond = 1000000L / TIME_CHUNK;
      motors[motorIndex].maxVelocity = pulsesPerSecond;
      motors[motorIndex].maxAcceleration = pulsesPerSecond * 0.5f;
    void setupMotorMove(int motorIndex, int32_t destination)
      motors[motorIndex].destination = destination;
      if ( destination != motors[motorIndex].position )
        calculatePointToPoint(motorIndex, destination);
        bitSet(motorMoving, motorIndex);
    void hardStop()
      // set the destination to the current location, so they won't move any more
        stopMotor(i);
    void stopMotor(int motorIndex)
      int32_t delta = (motors[motorIndex].destination - motors[motorIndex].position);
      if (!delta)
        return;
      Motor *motor = &motors[motorIndex];
      int i;
      for (i = 0; i < P2P_MOVE_COUNT; i++)
        motor->moveTime[i] = 0;
        motor->moveVelocity[i] = 0;
        motor->movePosition[i] = 0;
      float v = 20 * motors[motorIndex].nextMotorMoveSpeed / (float)65.536;
      float maxA = motor->maxAcceleration;
      float maxV = motor->maxVelocity;
      if (v > maxV)
        v = maxV;
      if (!motor->dir)
        v = -v;
      float t = fabs(v / maxA);
      motor->moveTime[0] = t;
      motor->movePosition[0] = motor->position;
      motor->moveVelocity[0] = v;
      motor->moveAcceleration[0] = (v > 0) ? -maxA : maxA;
      motor->moveTime[1] = 0;
      motor->movePosition[1] = (int32_t)(motor->movePosition[0] + motor->moveVelocity[0] * t + 0.5f * motor->moveAcceleration[0] * t * t);
      motor->moveVelocity[1] = 0;
      motor->moveAcceleration[1] = 0;
      motor->moveAcceleration[0] *= 0.5f;
      motor->destination = motor->movePosition[1];
      motor->currentMoveTime = 0;
      motor->currentMove = 0;
    boolean isValidMotor(int motorIndex)
      return (motorIndex >=0 && motorIndex < MOTOR_COUNT);
    void processGoPosition(int motorIndex, int32_t pos)
      if (motors[motorIndex].position != pos)
        setupMotorMove(motorIndex, pos);
        sendMessage(MSG_MM, motorIndex);
        sendMessage(MSG_MP, motorIndex);
    Command format
    ASCII
    [command two bytes]
    Version
    "hi"
    -> "hi 1"
    zero motor
    "zm 1"
    -> "z 1"
    move motor
    "mm 1 +1111111111
    motor position?
    mp 1
    MOTOR STATUS
    "ms"
    -> "ms [busy motor count]"
    SET PULSE PER SECOND
    pr 1 200
    STOP MOTOR
    sm 1
    STOP ALL
    sa
     * int processUserMessage(char data)
     * Read user data (from virtual com port), processing one byte at a time.
     * Implemented with a state machine to reduce memory overhead.
     * Returns command code for completed command.
    byte processUserMessage(char data)
      byte cmd = CMD_NONE;
      switch (msgState)
      case MSG_STATE_START:
        if (data != '\r' && data != '\n')
          msgState = MSG_STATE_CMD;
          msgNumberSign = 1;
          userCmd.command = CMD_NONE;
          userCmd.argCount = 0;
          userCmd.args[0] = 0;
      case MSG_STATE_CMD:
        if (lastUserData == 'h' && data == 'i')
          userCmd.command = CMD_HI;
          msgState = MSG_STATE_DONE;
        else if (lastUserData == 'm' && data == 's')
          userCmd.command = CMD_MS;
        else if (lastUserData == 's' && data == 'a')
          userCmd.command = CMD_SA;
        else if (lastUserData == 'm' && data == 'm')
          userCmd.command = CMD_MM;
          msgState = MSG_STATE_DATA;
        else if (lastUserData == 'n' && data == 'p')
          userCmd.command = CMD_NP;
        else if (lastUserData == 'm' && data == 'p')
          userCmd.command = CMD_MP;
        else if (lastUserData == 'z' && data == 'm')
          userCmd.command = CMD_ZM;
        else if (lastUserData == 's' && data == 'm')
          userCmd.command = CMD_SM;
        else if (lastUserData == 'p' && data == 'r')
          userCmd.command = CMD_PR;
        else if (lastUserData == 'b' && data == 'f')
          userCmd.command = CMD_BF;
        else if (lastUserData == 'g' && data == 'o')
          userCmd.command = CMD_GO;
        else if (lastUserData == 'j' && data == 'm') // jm [motor] [%speed]
          userCmd.command = CMD_JM;
        else if (lastUserData == 'i' && data == 'm') // im [motor] [%speed]
          userCmd.command = CMD_IM;
          // error msg? unknown command?
      case MSG_STATE_DATA:
        if (((data >= '0' && data <= '9') || data == '-') && lastUserData == ' ')
          userCmd.argCount++;
          if (userCmd.argCount >= USER_CMD_ARGS)
            SERIAL_DEVICE.print("error: too many args\r\n");
            msgState = MSG_STATE_ERR;
            userCmd.args[userCmd.argCount - 1] = 0;
            if (data == '-')
              msgNumberSign = -1;
              msgNumberSign = 1;
              userCmd.args[userCmd.argCount - 1] = (data - '0');
        else if (data >= '0' && data <= '9')
          userCmd.args[userCmd.argCount - 1] = userCmd.args[userCmd.argCount - 1] * 10 + (data - '0');
        else if (data == ' ' || data == '\r')
          if (lastUserData  >= '0' && lastUserData <= '9')
            if (userCmd.argCount > 0)
              userCmd.args[userCmd.argCount - 1] *= msgNumberSign;
          if (data == '\r')
      case MSG_STATE_ERR:
      case MSG_STATE_DONE:
        // wait for newline, then reset
        if (data == '\n' && lastUserData == '\r')
          cmd = userCmd.command;
          lastUserData = 0;
      default: // unknown state -> revert to begin
        lastUserData = 0;
      lastUserData = data;
      return cmd;
    void processSerialCommand()
      byte avail = SERIAL_DEVICE.available();
      byte motor;
      int m;
      for (int i = 0; i < avail; i++)
        int cmd = processUserMessage(SERIAL_DEVICE.read());
        if (cmd != CMD_NONE)
          boolean parseError = false;
          motor = userCmd.args[0] - 1;
          switch (cmd)
            case CMD_HI:
            case CMD_ZM:
              parseError = (userCmd.argCount != 1 || !isValidMotor(motor));
              if (!parseError)
                motors[motor].position = 0;
                setupMotorMove(motor, 0);
                processGoPosition(motor, 0);
                bitSet(sendPosition, motor);
            case CMD_MM:
              parseError = (userCmd.argCount != 2 || !isValidMotor(motor));
              if (!parseError)
                processGoPosition(motor, (int32_t)userCmd.args[1]);
            case CMD_NP:
              if (!parseError)
                motors[motor].position = userCmd.args[1];
                sendMessage(MSG_MP, motor);
            case CMD_MP:
              if (!parseError)
            case CMD_MS:
              parseError = (userCmd.argCount != 0);
              if (!parseError)
                sendMessage(MSG_MS, 0);
            case CMD_SM:
              if (!parseError)
                stopMotor(motor);
                sendMessage(MSG_SM, motor);
            case CMD_SA:
              if (!parseError)
                hardStop();
                sendMessage(MSG_SA, 0);
            case CMD_PR:
              if (!parseError)
                setPulsesPerSecond(motor, (uint16_t)userCmd.args[1]);
                sendMessage(MSG_PR, motor);
            case CMD_BF:
              parseError = motorMoving || userCmd.argCount < 5 || ((userCmd.argCount - 2) % 4) != 0;
              if (!parseError)
                goMoDelayTime = 500;
                int motorCount = (userCmd.argCount - 2) / 4;
                for (m = 0; m < MOTOR_COUNT; m++)
                  motors[m].gomoMoveTime[0] = 0.0f;
                for (m = 0; m < motorCount; m++)
                  int offset = 2 + m * 4;
                  motor = userCmd.args[offset] - 1;
                  if (!isValidMotor(motor))
                    parseError = true;
                  setupBlur(motor, userCmd.args[0], userCmd.args[1], userCmd.args[offset + 1], userCmd.args[offset + 2], userCmd.args[offset + 3]);
                goMoReady = true;
                sendMessage(MSG_BF, 0);
            case CMD_GO:
              parseError = motorMoving || (userCmd.argCount > 0) || !goMoReady;
              if (!parseError)
                   if (motors[m].gomoMoveTime[0] != 0)
                     int j;
                     for (j = 0; j < P2P_MOVE_COUNT; j++)
                         motors[m].moveTime[j] = motors[m].gomoMoveTime[j];
                         motors[m].movePosition[j] = motors[m].gomoMovePosition[j];
                         motors[m].moveVelocity[j] = motors[m].gomoMoveVelocity[j];
                         motors[m].moveAcceleration[j] = motors[m].gomoMoveAcceleration[j];
                     motors[m].destination = motors[m].gomoMovePosition[4]; // TODO change this!
                     motors[m].currentMove = 0;
                     bitSet(motorMoving, m);
                noInterrupts();
                velocityUpdateCounter = VELOCITY_UPDATE_RATE - 1;
                interrupts();
            case CMD_JM:
              if (!parseError)
                int32_t destination = 0;
                if (jogMotor(motor, userCmd.args[1], &destination))
                  if (!bitRead(motorMoving, motor) || destination != motors[motor].destination)
                    setupMotorMove(motor, destination);
                sendMessage(MSG_JM, motor);
            case CMD_IM:
              if (!parseError)
                inchMotor(motor, userCmd.args[1]);
                sendMessage(MSG_IM, motor);
            default:
              parseError = true;
          if (parseError)
            SERIAL_DEVICE.print("parse error\r\n");
     * Serial transmission.
    void sendMessage(byte msg, byte motorIndex)
      int i = (unsigned int)(txMsgBuffer.head + 1) % TX_MSG_BUF_SIZE;
      if (i != txMsgBuffer.tail)
        txMsgBuffer.buffer[txMsgBuffer.head].msg = msg;
        txMsgBuffer.buffer[txMsgBuffer.head].motor = motorIndex;
        txMsgBuffer.head = i;
        if (!*txBufPtr)
          nextMessage();
    #else
      int i;
      switch (msg)
        case MSG_HI:
          SERIAL_DEVICE.print("hi ");
          SERIAL_DEVICE.print(DFMOCO_VERSION);
          SERIAL_DEVICE.print(" ");
          SERIAL_DEVICE.print(MOTOR_COUNT);
          SERIAL_DEVICE.print(DFMOCO_VERSION_STRING);
          SERIAL_DEVICE.print("\r\n");
        case MSG_MM:
          SERIAL_DEVICE.print("mm ");
          SERIAL_DEVICE.print(motorIndex + 1);
          SERIAL_DEVICE.print(motors[motorIndex].destination);
        case MSG_MP:
          SERIAL_DEVICE.print("mp ");
          SERIAL_DEVICE.print(motors[motorIndex].position);
        case MSG_MS:
          SERIAL_DEVICE.print("ms ");
            SERIAL_DEVICE.print(bitRead(motorMoving, i) ? '1' : '0');
        case MSG_PR:
          SERIAL_DEVICE.print("pr ");
          SERIAL_DEVICE.print((uint16_t)motors[motorIndex].maxVelocity);
        case MSG_SM:
          SERIAL_DEVICE.print("sm ");
        case MSG_SA:
          SERIAL_DEVICE.print("sa\r\n");
        case MSG_BF:
          SERIAL_DEVICE.print("bf ");
          SERIAL_DEVICE.print(goMoDelayTime);
        case MSG_JM:
          SERIAL_DEVICE.print("jm ");
        case MSG_IM:
          SERIAL_DEVICE.print("im ");
    void nextMessage()
      char *bufPtr;
      int i;
      if ((TX_MSG_BUF_SIZE + txMsgBuffer.head - txMsgBuffer.tail) % TX_MSG_BUF_SIZE)
        byte msg = txMsgBuffer.buffer[txMsgBuffer.tail].msg;
        byte motorIndex = txMsgBuffer.buffer[txMsgBuffer.tail].motor;
        txMsgBuffer.tail = (unsigned int)(txMsgBuffer.tail + 1) % TX_MSG_BUF_SIZE;
        switch (msg)
          case MSG_HI:
            sprintf(txBuf, "hi %d %d %s\r\n", DFMOCO_VERSION, MOTOR_COUNT, DFMOCO_VERSION_STRING);
          case MSG_MM:
            sprintf(txBuf, "mm %d %ld\r\n", motorIndex + 1, motors[motorIndex].destination);
          case MSG_MP:
            sprintf(txBuf, "mp %d %ld\r\n", motorIndex + 1, motors[motorIndex].position);
          case MSG_MS:
            sprintf(txBuf, "ms ");
            bufPtr = txBuf + 3;
              *bufPtr++ = bitRead(motorMoving, i) ? '1' : '0';
            *bufPtr++ = '\r';
            *bufPtr++ = '\n';
            *bufPtr = 0;
          case MSG_PR:
            sprintf(txBuf, "pr %d %u\r\n", motorIndex + 1, (uint16_t)motors[motorIndex].maxVelocity);
          case MSG_SM:
            sprintf(txBuf, "sm %d\r\n", motorIndex + 1);
          case MSG_SA:
            sprintf(txBuf, "sa\r\n");
          case MSG_BF:
            sprintf(txBuf, "bf %d\r\n", goMoDelayTime);
          case MSG_JM:
            sprintf(txBuf, "jm %d\r\n", motorIndex + 1);
          case MSG_IM:
            sprintf(txBuf, "im %d\r\n", motorIndex + 1);
        txBufPtr = txBuf;
    boolean jogMotor(int motorIndex, int32_t target, int32_t * destination)
      // ideally send motor to distance where decel happens after 2 seconds
      float vi = (motor->dir ? 1 : -1) * 20 * motor->nextMotorMoveSpeed / 65.536f;
      int dir = (target > motor->position) ? 1 : -1;
      // if switching direction, just stop
      if (motor->nextMotorMoveSpeed && motor->dir * dir < 0)
        stopMotor(motorIndex);
        return false;
      if (target == motor->position)
        return false;
      float maxVelocity = motor->maxVelocity;
      float maxAcceleration = motor->maxAcceleration;
      // given current velocity vi
      // compute distance so that decel starts after 0.5 seconds
      // time to accel
      // time at maxvelocity
      // time to decel
      float accelTime = 0, atMaxVelocityTime = 0;
      if (fabs(vi) < maxVelocity)
        accelTime = (maxVelocity - fabs(vi)) / maxAcceleration;
        if (accelTime < 0.5f)
          atMaxVelocityTime = 0.5f - accelTime;
          accelTime = 0.5f;
        atMaxVelocityTime = 0.5f;
      float maxVelocityReached = fabs(vi) + maxAcceleration * accelTime;
      int32_t delta = fabs(vi) * accelTime + (0.5f * maxAcceleration * accelTime * accelTime);
      delta += atMaxVelocityTime * maxVelocityReached;
      delta += 0.5f * (maxVelocityReached * maxVelocityReached) / maxAcceleration; // = 0.5 * a * t^2 -> t = (v/a)
      int32_t dest = motor->position + dir * delta;
      // now clamp to target
      if ( (dir == 1 && dest > target) || (dir == -1 && dest < target) )
        dest = target;
      *destination = dest;
      return true;
    void inchMotor(int motorIndex, int32_t target)
      int dir = (target > motor->destination) ? 1 : -1;
      if (motor->nextMotorMoveSpeed)// && motor->dir * dir < 0)
        return;
      int32_t dest = motor->destination + dir * 2;
        dest = target;
      //setupMotorMove(motorIndex, dest);
      int i, moveCount;
      moveCount = 0;
        motor->moveAcceleration[i] = 0;
      motor->moveTime[0] = 0.01f;
      motor->movePosition[1] = motor->position + dir * 2;
      motor->destination = dest;
      if ( dest != motor->position )
    void calculatePointToPoint(int motorIndex, int32_t destination)
      int i, moveCount;
      moveCount = 0;
      float tmax = motor->maxVelocity / motor->maxAcceleration;
      float dmax = motor->maxVelocity * tmax;
      float dist = abs(destination - motor->position);
      int dir = destination > motor->position ? 1 : -1;
      if (motor->nextMotorMoveSpeed > 5) // we need to account for existing velocity
        float ti = fabs(vi / motor->maxAcceleration);
        float di = 0.5f * motor->maxAcceleration * ti * ti;
        if (vi * dir < 0) // switching directions
          motor->moveTime[moveCount] = ti;
          motor->moveAcceleration[moveCount] = dir * motor->maxAcceleration;
          motor->moveVelocity[moveCount] = vi;
          moveCount++;
          dist += di;
        else if (dist < di) // must decelerate and switch directions
          motor->moveAcceleration[moveCount] = -dir * motor->maxAcceleration;
          moveCount++;
          dist = (di - dist);
          dir = -dir;
        else // further on in same direction
          dist += di;
          motor->movePosition[0] -= dir * di;
          motor->currentMoveTime = ti;
      float t = tmax;
      if (dist <= dmax)
        t = sqrt(dist / motor->maxAcceleration);
      motor->moveTime[moveCount] = t;
      if (dist > dmax)
        moveCount++;
        dist -= dmax;
        float tconst = dist / motor->maxVelocity;
        motor->moveTime[moveCount] = tconst;
        motor->moveAcceleration[moveCount] = 0;
      moveCount++;
      motor->moveAcceleration[moveCount] = dir * -motor->maxAcceleration;
      for (i = 1; i <= moveCount; i++)
        float t = motor->moveTime[i - 1];
        motor->movePosition[i] = (int32_t)(motor->movePosition[i - 1] + motor->moveVelocity[i - 1] * t + 0.5f * motor->moveAcceleration[i - 1] * t * t);
        motor->moveVelocity[i] = motor->moveVelocity[i - 1] + motor->moveAcceleration[i - 1] * t;
      motor->movePosition[moveCount + 1] = destination;
      for (i = 0; i <= moveCount; i++)
        motor->moveAcceleration[i] *= 0.5f; // pre-multiply here for later position calculation
      return;
    void setupBlur(int motorIndex, int exposure, int blur, int32_t p0, int32_t p1, int32_t p2)
      int i;
      float b = blur / 1000.0f;
      float expTime = exposure / 1000.0f;
      p0 = p1 + b * (p0 - p1);
      p2 = p1 + b * (p2 - p1);
      float speedFactor = ( (1000.0f / exposure) );
        motor->gomoMoveTime[i] = 0;
        motor->gomoMoveVelocity[i] = 0;
        motor->gomoMoveAcceleration[i] = 0;
      motor->gomoMovePosition[1] = p0;
      motor->gomoMoveTime[1] = expTime * 0.5f;
      motor->gomoMoveVelocity[1] = (float)(p1 - p0) / (expTime * 0.5f);
      motor->gomoMovePosition[2] = p1;
      motor->gomoMoveTime[2] = expTime * 0.5f;
      motor->gomoMoveVelocity[2] = (float)(p2 - p1) / (expTime * 0.5f);
      // v = a*t -> a = v / t
      float accelTime = 1.0f;
      float a = motor->gomoMoveVelocity[1] / accelTime;
      float dp = 0.5f * a * accelTime * accelTime;
      float sp = p0 - dp; // starting position
      motor->gomoMovePosition[0] = sp;
      motor->gomoMoveTime[0] = accelTime;
      motor->gomoMoveAcceleration[0] = 0.5f * a; // pre-multiplied
      a = motor->gomoMoveVelocity[2] / accelTime;
      float fp = p2 + dp;
      motor->gomoMovePosition[3] = p2;
      motor->gomoMoveTime[3] = accelTime;
      motor->gomoMoveVelocity[3] = motor->gomoMoveVelocity[2];
      motor->gomoMoveAcceleration[3] = -0.5f * a; // pre-multiplied
      motor->gomoMovePosition[4] = fp;
      setupMotorMove(motorIndex, sp);
    Apr 2013
    1,763
    Right answer is to add a teensy statment to that if statmentb;acl
    #else
    // #error Cannot identify board
    Which will mean all the complex code trying to define the mixed bag of boards will fall through to Uno for anything it doesn't find (such as a teensy), which will probably work, though there is some stuff in there defining variable sizes base on CPU which may fall apart doing 8 bit math on a 32 bit CPU.
    Apr 2013
    1,763
    This code is a mess of hardware specific hacks, Teensyduino supports a fair number of macros to get arduino uno code to work when it tries to bit twiddle specific registers but this section
    TCCR1A = 0;
    is going to be tying to do clever stuff setting up timer interrupts that targets 8 bit AVR hardware so this will probably be a problem. Not impossible to hack up your own code using intervel timer or similar since it's basically just setting a high rate interupt to bit bash the motor drive pins but this code was never designed to be easily ported to new hardware, and the nested ifs mean it's harder than normal to just swap out the AVR regs for for Teensy ones. Looking at it a fairly simple graft of the Chipkit and Uno config blocks will get really close to working code but will not be a fun job to do at all.
    Jun 2017
    5
    Thanks appreciate any help in the right direction......
    Feb 2017
    7
    Any update on this topic (Dragonframe for Teensy 3.6)? I really would like to run it on my stepper control unit
    Junior Member winux's Avatar
    Nov 2017
    3
    There is a new version of the sketch that is bundled with version 4 of dragonframe.
    It supports the arduino 101 based on intel curie chip. it is also a 32 bit cpu like the teensy.
    I'am not sure if this will be of any help. but it would be really nice to get the teensy 3.6 support for dragonframe.
    #define DFMOCO_VERSION_STRING "1.3.0"
      DFMoco version 1.3.0
      For use with the Arc motion control system in Dragonframe 4.
      Control up to four axes with an Uno, Duemilanove or 101 board.
      Control up to eight axes with a Mega or Mega 2560.
      Version History
      Version 1.3.0 Arduino 101 support. Remove non-Arduino support (chipKit, Maple).
      Getting Started:
       1. Install IDE (Integrated Development Environment):
          Go to https://www.arduino.cc/en/Main/Software and download the Arduino Software for your OS.
      Pin configuration:
      channel 1
            PIN   4   step
            PIN   5   direction
      channel 2
            PIN   6   step
            PIN   7   direction
      channel 3
            PIN   8   step
            PIN   9   direction
      channel 4
            PIN  10   step
            PIN  11   direction
      channel 5
            PIN  28   step
            PIN  29   direction
      channel 6
            PIN  30   step
            PIN  31   direction
      channel 7
            PIN  32   step
            PIN  33   direction
      channel 8
            PIN  34   step
            PIN  35   direction
      channel 5
            PIN  22   step
            PIN  23   direction
      channel 6
            PIN  24   step
            PIN  25   direction
      channel 7
            PIN  26   step
            PIN  27   direction
      channel 8
            PIN  28   step
            PIN  29   direction
      #define BOARD_MEGA 1
      #define BOARD_UNO 1
    #elif defined(ARDUINO_ARCH_ARC32) // Intel Curie/101
      #define BOARD_101 1
      #include "CurieTimerOne.h"
    #else
    #if defined(BOARD_101)
      #define PIN_ON(port, pin)  { digitalWrite(pin, 1); }
      #define PIN_OFF(port, pin) { digitalWrite(pin, 0); }
    #else
    #if defined(BOARD_UNO) || defined(BOARD_101)
    #else
    #define VELOCITY_CONVERSION_FACTOR 0.30517578125f /* 20 / 65.536f */
      #define MOTOR0_STEP_PORT 0
      #define MOTOR0_STEP_PIN  4
      #define MOTOR1_STEP_PORT 0
      #define MOTOR1_STEP_PIN  6
      #define MOTOR2_STEP_PORT 0
      #define MOTOR2_STEP_PIN  8
      #define MOTOR3_STEP_PORT 0
      #define MOTOR3_STEP_PIN  10
    #elif defined(BOARD_UNO)
    #if defined(UBRRH)
    #define TX_UDR   UDR
    #else
    #define TX_UDR   UDR0
    char txBuf[32];
    char *txBufPtr;
    #define CMD_NONE       0
    #define CMD_HI         10
    #define CMD_MS         30
    #define CMD_NP         31
    #define MSG_HI 01
    #define MSG_MM 02
    #define MSG_MP 03
    #define MSG_MS 04
    #define MSG_PR 05
    #define MSG_SM 06
    #define MSG_SA 07
    #define MSG_BF 10
    #define MSG_GO 11
    #define MSG_JM 12
    #define MSG_IM 13
    struct UserCmd
      byte command;
      byte argCount;
    byte lastUserData;
    int  msgState;
    int  msgNumberSign;
    UserCmd userCmd;
    struct txMsg
      byte msg;
      byte motor;
    struct TxMsgBuffer
      byte head;
      byte tail;
     Motor data.
    #if MOTOR_COUNT > 4
    #if MOTOR_COUNT > 4
    #if MOTOR_COUNT > 4
    #if MOTOR_COUNT > 4
    #if MOTOR_COUNT > 4
    #if MOTOR_COUNT > 4
    struct Motor
      byte   stepPin;
      byte   dirPin;
      int       currentMove;
      int32_t   position;
      float     maxVelocity;
    boolean goMoReady;
    int     goMoDelayTime;
    void killSwitch()
      goMoReady = false;
      lastUserData = 0;
        txBuf[i] = 0;
      txBufPtr = txBuf;
      // set output pins
        // disable PWM
          case 4:
            TCCR3A &= ~COM3B1;
          case 6:
            TCCR4A &= ~COM4A1;
          case 8:
            TCCR4A &= ~COM4C1;
          case 10:
            TCCR2A &= ~COM2A1;
    #else
          case 10:
            TCCR1A &= ~COM1B1;
      #if defined(BOARD_UNO) || defined(BOARD_MEGA)
        TCCR1A = 0;
      #elif defined(BOARD_101)
        CurieTimerOne.start(25, &updateStepDirection);
    void updateStepDirection(void)
    #else
      if (toggleStep)
        // MOTOR 1
            motorMoveSteps0--;
        // MOTOR 2
            motorMoveSteps1--;
        // MOTOR 3
            motorMoveSteps2--;
        // MOTOR 4
            motorMoveSteps3--;
    #if MOTOR_COUNT > 4
        // MOTOR 5
            motorMoveSteps4--;
        // MOTOR 6
            motorMoveSteps5--;
        // MOTOR 7
            motorMoveSteps6--;
        // MOTOR 8
            motorMoveSteps7--;
        #if MOTOR_COUNT > 4
        if (ramValues[i] == ~ramNotValues[i])
          motors[i].position = motors[i].destination = ramValues[i];
      while (true)
        if (*txBufPtr)
            if (!*txBufPtr)
              nextMessage();
          byte i;
          sendPosition = 0;
        hardStop();
              seg++;
              continue;
    void hardStop()
        stopMotor(i);
      if (!delta)
        return;
      int i;
      float v = VELOCITY_CONVERSION_FACTOR * motors[motorIndex].nextMotorMoveSpeed;
      if (v > maxV)
        v = maxV;
      if (!motor->dir)
        v = -v;
    Command format
    ASCII
    [command two bytes]
    Version
    "hi"
    -> "hi 1"
    zero motor
    "zm 1"
    -> "z 1"
    move motor
    "mm 1 +1111111111
    motor position?
    mp 1
    MOTOR STATUS
    "ms"
    pr 1 200
    STOP MOTOR
    sm 1
    STOP ALL
    sa
      switch (msgState)
          msgNumberSign = 1;
      case MSG_STATE_CMD:
        else if (lastUserData == 'j' && data == 'm') // jm [motor] [destination position]
        else if (lastUserData == 'i' && data == 'm') // im [motor] [destination position]
          userCmd.argCount++;
            if (data == '-')
              msgNumberSign = -1;
              msgNumberSign = 1;
          if (data == '\r')
      case MSG_STATE_ERR:
          lastUserData = 0;
        lastUserData = 0;
      return cmd;
      byte motor;
      int m;
          switch (cmd)
            case CMD_HI:
            case CMD_ZM:
              if (!parseError)
            case CMD_MM:
              if (!parseError)
            case CMD_NP:
              if (!parseError)
            case CMD_MP:
              if (!parseError)
            case CMD_MS:
              if (!parseError)
            case CMD_SM:
              if (!parseError)
                stopMotor(motor);
            case CMD_SA:
              if (!parseError)
                hardStop();
            case CMD_PR:
              if (!parseError)
            case CMD_BF:
              if (!parseError)
                goMoDelayTime = 1000;
                    parseError = true;
                goMoReady = true;
            case CMD_GO:
              if (!parseError)
                     int j;
                noInterrupts();
                interrupts();
                sendMessage(MSG_GO, 0);
            case CMD_JM:
              if (!parseError)
            case CMD_IM:
              if (!parseError)
            default:
              parseError = true;
          if (parseError)
        if (!*txBufPtr)
          nextMessage();
    #else
      int i;
      switch (msg)
        case MSG_HI:
        case MSG_MM:
        case MSG_MP:
        case MSG_MS:
        case MSG_PR:
        case MSG_SM:
        case MSG_SA:
        case MSG_BF:
        case MSG_GO:
          SERIAL_DEVICE.print("go\r\n");
        case MSG_JM:
        case MSG_IM:
    void nextMessage()
      char *bufPtr;
      int i;
        switch (msg)
          case MSG_HI:
          case MSG_MM:
          case MSG_MP:
          case MSG_MS:
            bufPtr = txBuf + 3;
            *bufPtr++ = '\r';
            *bufPtr++ = '\n';
            *bufPtr = 0;
          case MSG_PR:
          case MSG_SM:
          case MSG_SA:
          case MSG_BF:
          case MSG_GO:
            sprintf(txBuf, "go\r\n");
          case MSG_JM:
          case MSG_IM:
        txBufPtr = txBuf;
      float vi = (motor->dir ? 1 : -1) * VELOCITY_CONVERSION_FACTOR * motor->nextMotorMoveSpeed;
        return false;
        return false;
      // time to accel
      // time to decel
          accelTime = 0.5f;
        dest = target;
      return true;
        return;
        dest = target;
      int i, moveCount;
      moveCount = 0;
      int i, moveCount;
      moveCount = 0;
          moveCount++;
          dist += di;
          moveCount++;
          dist = (di - dist);
          dir = -dir;
          dist += di;
      float t = tmax;
      if (dist <= dmax)
      if (dist > dmax)
        moveCount++;
        dist -= dmax;
      moveCount++;
      return;
      int i;
      float b = blur * 0.001f;
      float expTime = exposure * 0.001f;
      float fp = p2 + dp;
    Nov 2017
    3
    so basicly they use the CurieTimerOne.h for the 32 bit curie chip on the genuino101 https://github.com/arduino/ArduinoCo...urieTimerOne.h for the timers.
    the call looks like this
    I just found that there is this https://github.com/PaulStoffregen/Ti...ter/TimerOne.h from Paul. Can't we just bend it to do the same so we can keep the code and just use a TimerOne.h for the teensy instead?
    I still can't wrap my hand arround it. But maybe someone of you guys can understand it better? It would be really nice to include functionality of the FPU.
    17,624
    Quote Originally Posted by winux View Post
    Have they published the new version on github. Looks like their github repository still have only version 1.27.
    17,624
    Ok, I took a quick look at the code. It's seems pretty simple.
    Here's a first attempt. I don't have hardware for testing, but there's a pretty good chance this should work or at least get you very close.
    // modified for Teensy support
      Version History
      Getting Started:
      Pin configuration:
      channel 1
            PIN   4   step
            PIN   5   direction
      channel 2
            PIN   6   step
            PIN   7   direction
      channel 3
            PIN   8   step
            PIN   9   direction
      channel 4
            PIN  10   step
            PIN  11   direction
      channel 5
            PIN  28   step
            PIN  29   direction
      channel 6
            PIN  30   step
            PIN  31   direction
      channel 7
            PIN  32   step
            PIN  33   direction
      channel 8
            PIN  34   step
            PIN  35   direction
      channel 5
            PIN  22   step
            PIN  23   direction
      channel 6
            PIN  24   step
            PIN  25   direction
      channel 7
            PIN  26   step
            PIN  27   direction
      channel 8
            PIN  28   step
            PIN  29   direction
      #define BOARD_UNO 1
      #define BOARD_101 1
    #elif defined(__arm__) && defined(TEENSYDUINO)
      #define BOARD_TEENSY 1
    #else
    #elif defined(BOARD_TEENSY)
      #define PIN_ON(port, pin)  { digitalWriteFast(pin, HIGH); }
      #define PIN_OFF(port, pin) { digitalWriteFast(pin, LOW); }
    #else
    #else
        #define MOTOR4_STEP_PORT 0
        #define MOTOR4_STEP_PIN  28
        #define MOTOR5_STEP_PORT 0
        #define MOTOR5_STEP_PIN  30
        #define MOTOR6_STEP_PORT 0
        #define MOTOR6_STEP_PIN  32
        #define MOTOR7_STEP_PORT 0
        #define MOTOR7_STEP_PIN  34
        #define MOTOR4_STEP_PIN  22
        #define MOTOR5_STEP_PIN  24
        #define MOTOR6_STEP_PIN  26
        #define MOTOR7_STEP_PIN  28
    #if defined(UBRRH)
    #define TX_UDR   UDR
    #else
    #define TX_UDR   UDR0
    char txBuf[32];
    char *txBufPtr;
    #define CMD_NONE       0
    #define CMD_HI         10
    #define CMD_MS         30
    #define CMD_NP         31
    #define MSG_HI 01
    #define MSG_MM 02
    #define MSG_MP 03
    #define MSG_MS 04
    #define MSG_PR 05
    #define MSG_SM 06
    #define MSG_SA 07
    #define MSG_BF 10
    #define MSG_GO 11
    #define MSG_JM 12
    #define MSG_IM 13
    struct UserCmd
      byte command;
      byte argCount;
    byte lastUserData;
    int  msgState;
    int  msgNumberSign;
    UserCmd userCmd;
    struct txMsg
      byte msg;
      byte motor;
    struct TxMsgBuffer
      byte head;
      byte tail;
     Motor data.
    #if MOTOR_COUNT > 4
    #if MOTOR_COUNT > 4
    #if MOTOR_COUNT > 4
    #if MOTOR_COUNT > 4
    #if MOTOR_COUNT > 4
    #if MOTOR_COUNT > 4
    struct Motor
      byte   stepPin;
      byte   dirPin;
      int       currentMove;
      int32_t   position;
      float     maxVelocity;
    boolean goMoReady;
    int     goMoDelayTime;
    void killSwitch()
      goMoReady = false;
      lastUserData = 0;
        txBuf[i] = 0;
      txBufPtr = txBuf;
      // set output pins
        // disable PWM
          case 4:
            TCCR3A &= ~COM3B1;
          case 6:
            TCCR4A &= ~COM4A1;
          case 8:
            TCCR4A &= ~COM4C1;
          case 10:
            TCCR2A &= ~COM2A1;
    #else
          case 10:
            TCCR1A &= ~COM1B1;
        TCCR1A = 0;
        static IntervalTimer mytimer;
        mytimer.priority(48);
        mytimer.begin(updateStepDirection, 25.0f);
    #if defined(BOARD_101) || defined(BOARD_TEENSY)
    #else
      if (toggleStep)
        // MOTOR 1
            motorMoveSteps0--;
        // MOTOR 2
            motorMoveSteps1--;
        // MOTOR 3
            motorMoveSteps2--;
        // MOTOR 4
            motorMoveSteps3--;
    #if MOTOR_COUNT > 4
        // MOTOR 5
            motorMoveSteps4--;
        // MOTOR 6
            motorMoveSteps5--;
        // MOTOR 7
            motorMoveSteps6--;
        // MOTOR 8
            motorMoveSteps7--;
        #if MOTOR_COUNT > 4
      while (true)
        if (*txBufPtr)
            if (!*txBufPtr)
              nextMessage();
          byte i;
          sendPosition = 0;
        hardStop();
              seg++;
              continue;
    void hardStop()
        stopMotor(i);
      if (!delta)
        return;
      int i;
      if (v > maxV)
        v = maxV;
      if (!motor->dir)
        v = -v;
    Command format
    ASCII
    [command two bytes]
    Version
    "hi"
    -> "hi 1"
    zero motor
    "zm 1"
    -> "z 1"
    move motor
    "mm 1 +1111111111
    motor position?
    mp 1
    MOTOR STATUS
    "ms"
    pr 1 200
    STOP MOTOR
    sm 1
    STOP ALL
    sa
      switch (msgState)
          msgNumberSign = 1;
      case MSG_STATE_CMD:
          userCmd.argCount++;
            if (data == '-')
              msgNumberSign = -1;
              msgNumberSign = 1;
          if (data == '\r')
      case MSG_STATE_ERR:
          lastUserData = 0;
        lastUserData = 0;
      return cmd;
      byte motor;
      int m;
          switch (cmd)
            case CMD_HI:
            case CMD_ZM:
              if (!parseError)
            case CMD_MM:
              if (!parseError)
            case CMD_NP:
              if (!parseError)
            case CMD_MP:
              if (!parseError)
            case CMD_MS:
              if (!parseError)
            case CMD_SM:
              if (!parseError)
                stopMotor(motor);
            case CMD_SA:
              if (!parseError)
                hardStop();
            case CMD_PR:
              if (!parseError)
            case CMD_BF:
              if (!parseError)
                    parseError = true;
                goMoReady = true;
            case CMD_GO:
              if (!parseError)
                     int j;
                noInterrupts();
                interrupts();
            case CMD_JM:
              if (!parseError)
            case CMD_IM:
              if (!parseError)
            default:
              parseError = true;
          if (parseError)
        if (!*txBufPtr)
          nextMessage();
    #else
      int i;
      switch (msg)
        case MSG_HI:
        case MSG_MM:
        case MSG_MP:
        case MSG_MS:
        case MSG_PR:
        case MSG_SM:
        case MSG_SA:
        case MSG_BF:
        case MSG_GO:
        case MSG_JM:
        case MSG_IM:
    void nextMessage()
      char *bufPtr;
      int i;
        switch (msg)
          case MSG_HI:
          case MSG_MM:
          case MSG_MP:
          case MSG_MS:
            bufPtr = txBuf + 3;
            *bufPtr++ = '\r';
            *bufPtr++ = '\n';
            *bufPtr = 0;
          case MSG_PR:
          case MSG_SM:
          case MSG_SA:
          case MSG_BF:
          case MSG_GO:
          case MSG_JM:
          case MSG_IM:
        txBufPtr = txBuf;
        return false;
        return false;
      // time to accel
      // time to decel
          accelTime = 0.5f;
        dest = target;
      return true;
        return;
        dest = target;
      int i, moveCount;
      moveCount = 0;
      int i, moveCount;
      moveCount = 0;
          moveCount++;
          dist += di;
          moveCount++;
          dist = (di - dist);
          dir = -dir;
          dist += di;
      float t = tmax;
      if (dist <= dmax)
      if (dist > dmax)
        moveCount++;
        dist -= dmax;
      moveCount++;
      return;
      int i;
      float fp = p2 + dp;
