Hi, First of all thanks to the teensy community.
I am designing a .wave file player using the teensy 3.2 audio shield, the files trigger should be through the use of capacitive sensors and then using the teensy touch read pins.
In fact I used recently Bare Conductive and would like to create something analogous with teensy (but with greater audio quality). I currently have all the necessary hardware.
The biggest doubt that stopped me is what pins touch reads I can use if the audio shield deals with the pins 23,22,19,18,15 - respectively A9, A8, A5, A4, A1 ... right?
The other pins 25, 32, 33 are not usable since I have welded teensy on the shied.
The other pins 1.17.16 are the only usable ones.
At this point do I have to insert a multiplexer for use 6 capacitive sensor?
thanks
thanks
