USBHost_t36: Midi send?
flocked
I'm consindering buying a Teensy 3.6 and use it with a usb hub to sync all my 11 midi usb devices via usb midi clock.
I read somewhere in a post from february that the USBHost_t36 library is experimental and doesn't support send via usb midi. Is this still true? Also: Could the number of devices (11 via an usb hub) cause any problems?
... is experimental and doesn't support send via usb midi. Is this still true?
Yes and yes, still experiment, the MIDI driver only receives messages so far.
That part should be fine, as long as you create 11 driver instances and enough hub instances.
When dealing with hubs, keep in mind many 7, 10 and larger USB hubs are actually made as 2 tiers of 4 port hubs. You need to put enough hub driver instances in your program to cover the actual hubs you're using.
Can I make a request for USBHost_t36 MIDI send in 1.4.1?
Receive has been working great.
I would love to use the Ableton push 2 as well but it requires a sysex command to enter "USER Mode".
Would also be great for creating a monster 3.6 MIDI Sequencer.
