OctoWS2811 use pins 14,20,21 as analoge input
lutre
New member
Hi everyone,
Im pretty new to programming.
My project is to build an soundactive led wall. For this I´m using the teensy 3.2 with the audio adapotor and the OctoWS2811 libary.
I also want to controll the whole setup via 5 potis which should connect to analoge pins.
Without sending data to the strips i receive usefull values on all the pins.
But as soon as I want stream data to the led strips (ws2812) the analoge values on the pins A0 and A6 (have also tried A7) go crazy.
Is there any possibility to use the pins 14,20,21 as analoge inputs?
//PINS
#define PIN_POTI_1 A0
#define PIN_POTI_2 A1
#define PIN_POTI_3 A2
#define PIN_POTI_4 A3
#define PIN_POTI_5 A6
#define NPOTIS 5
#define RED 0xFF0000
#define GREEN 0x00FF00
#define BLUE 0x0000FF
#define YELLOW 0xFFFF00
#define PINK 0xFF1088
#define ORANGE 0xE05800
#define WHITE 0xFFFFFF
const int ledsPerStrip = 30;
DMAMEM int displayMemory[ledsPerStrip * 6];
int drawingMemory[ledsPerStrip * 6];
const int config = WS2811_GRB | WS2811_800kHz;
OctoWS2811 leds(ledsPerStrip, displayMemory, drawingMemory, config);
leds.begin();
leds.show();
//Start up Serial for USB debugging
Serial.begin(9600); //Serial USB for debugging
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("setup done! new");
int val_poti[NPOTIS];
val_poti[0] = analogRead(PIN_POTI_1);
val_poti[1] = analogRead(PIN_POTI_2);
val_poti[2] = analogRead(PIN_POTI_3);
val_poti[3] = analogRead(PIN_POTI_4);
val_poti[4] = analogRead(PIN_POTI_5);
for (int i = 0; i < NPOTIS; i++) {
Serial.print("Poti number: ");
Serial.print(i+1);
Serial.print(" Raw value: ");
Serial.print(val_poti);
Serial.print(" ||| ");
Serial.println(" ");
colorWipe(RED, 0);
void colorWipe(int color, int wait)
for (int i = 0; i < leds.numPixels(); i++) {
leds.setPixel(i, color);
leds.show();
delayMicroseconds(wait);
Thanks in advance,
Luis
