Page 2 of 2 FirstFirst 1 2
Results 26 to 30 of 30
Thread: Teensyduino 1.38 Beta #2
  1. #26
    Jun 2014
    230
    Quote Originally Posted by Paul View Post
    Wire1 support for pins on SD socket (if not using SD card)
    Hi Paul,
    any chance you could map PTE0-5 including both UARTs alternates, I2C and SPI as, say, pins 58-63?
  2. #27
    Senior Member KurtE's Avatar
    2,633
    They already are as far as I know. I added that support awhile ago. I have run SPI display using an adapter I plug into the SD card slot.
    They are pins 58-62, and I verified code in Serial2 and Serial4.
    Likewise I verified pins 58 and 59 are in table for Wire1.
  3. #28
    810
    The SD socket pins are there:
    https://github.com/PaulStoffregen/co...ba0dbd668a2f26
    Port E0 - E5 is mapped to 58 - 63 (core_pins.h):
    #define CORE_PIN58_BIT 0
    #define CORE_PIN59_BIT 1
    #define CORE_PIN60_BIT 2
    #define CORE_PIN61_BIT 3
    #define CORE_PIN62_BIT 4
    #define CORE_PIN63_BIT 5
  4. #29
    Jun 2014
    230
    I had no idea about that, thanks guys. SPI makes sense (brain fart), but is I2C on pte0,1 mapped too?
    Edit: "I2C1: SCL/SDA" awesome
  5. #30
    310
    New Libs
    I would recommend TeensyThreads as well as NeoGPS. Both work great with the Teensy. NeoGPS is already downloadable the lib manager in Arduino IDE.
    Mike
