instrumentek
Hi;
Basically I have a project using the teensy 3.5. I use nearly all the pins on the teensy and have to solder all the bottom side pins. This is very time consuming to produce my project. I want to upgrade to using the MKL04 chip and the MK64 LQFP. I see that a few people have posted eagle files for making there own teensy 3.6. However I need the files for a teensy 3.5 using the LQFP package. I Can integrate the files into my project myself as long as the pins are all labeled in a manner that i can cross reference them to the teensy board layout.
Requirements:
- eagle files for using the MKL04 chip and the MK64 LQFP to create equivalent teensy 3.5.
- including all the auxiliary parts like crystals ect.
- requires SD card and primary usb port.
- BOM from newark, digikey or mouser.
- parts need to be common, 1206 resistors, 603 caps if possible
- references to all pins as compared to teensy 3.5
- example of proper board layout for reference
- open to additionally paid support after to get project working.
PM me with an estimate if you are interested. Thanks for reading!
Requirements:
