Results 1 to 9 of 9
Thread: Can't get sound from propshield lc
    Oct 2016
    18
    Using Teensy 3.2 and propshiled lc, just trying to send some noise to a 4 ohm 3 watt speaker as a hardware test.
    I can hear the speaker click once the code is uploaded, but no noise signal thereafter.
    Here is the code:
    AudioSynthNoiseWhite noise1; //xy=346,213
    AudioOutputAnalog dac1; //xy=480,212
    AudioConnection patchCord1(noise1, dac1);
    void setup(){
    pinMode(5, OUTPUT);
    digitalWrite(5, HIGH); // turn on the amplifier
    delay(10); // allow time to wake up
    Any pointers?
    20,551
    You're not giving the audio library any memory, so it can't do anything. Open any of the examples from File > Examples > Audio to see how AudioMemory() is used in setup.
    Also make sure you've got the DAC pin connected. It's not one of the 28 outside pins, so it's easy to overlook.
    Oct 2016
    18
    I ran a similar script where I added audio memory, and tried the sweep example editted to include:
    Still got the same result.
    20,551
    You need to post the complete program you tried. We can't help you figure out what's wrong with so little info. There's almost certainly some small detail not quite right, but nobody can know what it is.
    The way to get help here is to post a message where anyone reading can copy & paste your code into Arduino and run it on their board.
    2,188
    I added the AudioMemory() and noise1.amplitude() to your sketch above and i get white noise out the speaker ...
      pinMode(5, OUTPUT);
      AudioMemory(12);
      noise1.amplitude(0.5);
    you need to jumper teensy DAC/A14 to the AudioIn on the shield.
    Oct 2016
    18
    void setup(){
    pinMode(5, OUTPUT);
    AudioMemory(12);
    Still nothing.
    DAC/A14 to the Audio in on the shield.... ?? I am using the propshield LC, not the audio shield. Are we on the same page?
    2,188
    Quote Originally Posted by Peter2708 View Post
    Still nothing.
    Yes, look at the shield PCB illustration https://www.pjrc.com/store/prop_shield.html
    There is a an AudioIN hole just inside of pin 13 (not an edge pin). The teensy DAC pin needs to be jumpered to that. When the propshield is mounted on the T3.2, the AudioIN hole is above the DAC/A14 hole
    Oct 2016
    18
    A thousand thankyous. I will try that later
    Oct 2016
    18
    Like a charm. Thanks
Tags for this Thread
