I'm playing with music things modular's Radio Music which is based on a teensy and so far I'm having lot of fun using it to play samples. But what I would like to do now is output some DC via the audio output to control other modules. I understand the audio out will be limited in terms of voltage range but nevertheless, is it possible to use the teensy audio out for such use ? I tried with the "DC" object in the teensy audio lib but it seems to be aimed at other uses.
Thank you,
Thank you,
