lerxstrulz
Hi All,
I have a Teensy 3.2 using the audio shield and am using a Trinket Backpack LiPoly adapter to power it. I cut the Vin/VUSB trace and have soldered the connections from the backpack to the Teensy. I can run the boards with the battery or the USB and program it...that works great.
I am having the sketch hibernate the Teensy when voltage drops below 3mA using the following code:
This works pretty well in telling me approx how much voltage is coming in from the battery, but I am getting some mixed results sporadically. For example, when logging the voltage to a file (recording every 10 seconds) on the SD card, most times I can watch it drop until it reaches the low battery warning threshold (< 3200) and then the shutdown threshold (< 3000), but sometimes it just drops drastically and dies before the warning code can be called and therefore just executes the hibernate code:
And still other times it will just fall off altogether and neither the warning or the shutdown is called:
It seems that once it gets around ~3V it just drastically falls off, which if I remember correctly is how newer rechargables work. However, if I only charge the battery partially, it seems the fall off is much smoother (it steps down slower instead of just falling off.)
This approach is working pretty well, however since I am only monitoring the battery, whenever you plug in the USB cable (which in this setup will still power the Teensy) the code interferes if the battery is below an acceptable level (for instance if the battery is at "shutdown" level, it will attempt to hibernate even though the USB cable is plugged in and providing plenty of power while it is recharging the battery.)
Is there a way to detect that the USB cable is plugged in and providing power in this scenario? I tried checking the internal voltage, but no matter what that is at a constant 1.2 volts (which is correct according to what I've read.)
Value is the same whether USB is plugged in or running off battery:
So ideally I would check if the USB is plugged in and if it is, avoid the warning and shutdown code, but if it is not, check the battery voltage and warn or shutdown as appropriate, but I am not sure how to detect if USB is plugged in and providing power. Any ideas on how to check that?
Thank you!
analogReference(EXTERNAL);
analogReadResolution(12);
analogReadAveraging(32);
Serial.begin(57500);
elapsedMillis batteryCheck;
// check every 10 seconds
if (batteyCheck >= 10000) {
// return millivolts
int mv = 1195 * 4096/analogRead(39);
Serial.println(mv);
if (mv < 3000) {
... call hibernate ...
} else if (mv < 3200) {
... play low battery warning ...
3357
3354
3354
3352
3354
[B]3352
2478[/B]
3357
3354
3354
3352
3354
... Teensy dies here ...
// change to check INTERNAL
analogReference([B]INTERNAL[/B]);
Serial.being(57600);
Serial.println(mv);
if (mv < 3000) {
1195
1195
1195
1195
Thank you!
