Hi all,
I've got a very simple question that I'm struggling to find the answer too. I've probably already read it but I'm very new to code, so I probably misunderstood! I've built a simple midi controller, 8 analog pots and 6 buttons. All working ok, but I'd like to assign the pots to specific cc numbers. I can't figure out how to do this. I understand how to do it for the buttons on digital pins, but not the analog pots. I've put the code I've used below.
Sorry if this is very obvious! Again I'm new to this and trying to learn.
Thanks in advance.
Thanks in advance.
#include <Bounce.h>
// define how many pots are active up to number of available analog inputs
#define analogInputs 8
// make arrays for input values and lagged input values
int inputAnalog[analogInputs];
int iAlag[analogInputs];
// make array of cc values
int ccValue[analogInputs];
// index variable for loop
int i;
int ccs[] = {1,11,7,30,25,64,3,4};
// cc values for buttons
int cc_off = 0;
int cc_on = 65;
int cc_super = 127;
// map buttons to cc for button
int cc0 = 51;
int cc1 = 52;
int cc2 = 53;
int cc3 = 54;
int cc4 = 55;
int cc5 = 56;
Bounce button0 = Bounce(0, 3);
Bounce button1 = Bounce(1, 3);
Bounce button2 = Bounce(2, 3);
Bounce button3 = Bounce(3, 3);
Bounce button4 = Bounce(4, 3);
Bounce button5 = Bounce(5, 3);
// MIDI rate
Serial.begin(31250);
pinMode(0, INPUT_PULLUP);
pinMode(1, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
pinMode(6, INPUT_PULLUP);
pinMode(7, INPUT_PULLUP);
pinMode(8, INPUT_PULLUP);
pinMode(9, INPUT_PULLUP);
pinMode(10, INPUT_PULLUP);
pinMode(11, INPUT_PULLUP);
// loop trough active inputs for knobs
for (i=0;i<analogInputs;i++){
// read current value at i-th input
inputAnalog[i] = analogRead(i);
// if magnitude of difference is 8 or more...
if (abs(inputAnalog[i] - iAlag[i]) > 7){
// calc the CC value based on the raw value
ccValue[i] = inputAnalog[i]/8;
// send the MIDI
usbMIDI.sendControlChange(i, ccValue[i], 1);
// set raw reading to lagged array for next comparison
iAlag[i] = inputAnalog[i];
delay(5); // limits MIDI messages to reasonable number
// Push Button code
button0.update();
button1.update();
button2.update();
button3.update();
button4.update();
button5.update();
if (button0.fallingEdge())
usbMIDI.sendControlChange(cc0, cc_on, 3);
if (button1.fallingEdge())
usbMIDI.sendControlChange(cc1, cc_on, 3);
if (button2.fallingEdge())
usbMIDI.sendControlChange(cc2, cc_on, 3);
if (button3.fallingEdge())
usbMIDI.sendControlChange(cc3, cc_on, 3);
if (button4.fallingEdge())
usbMIDI.sendControlChange(cc4, cc_on, 3);
if (button5.fallingEdge())
usbMIDI.sendControlChange(cc5, cc_on, 3);
if (button0.risingEdge())
usbMIDI.sendControlChange(cc0, cc_off, 3);
if (button1.risingEdge())
usbMIDI.sendControlChange(cc1, cc_off, 3);
if (button2.risingEdge())
usbMIDI.sendControlChange(cc2, cc_off, 3);
if (button3.risingEdge())
usbMIDI.sendControlChange(cc3, cc_off, 3);
if (button4.risingEdge())
usbMIDI.sendControlChange(cc4, cc_off, 3);
}if (button5.risingEdge())
usbMIDI.sendControlChange(cc5, cc_off, 3);
// MIDI Controllers should discard incoming MIDI messages.
while (usbMIDI.read()) {
