Results 1 to 6 of 6
Thread: FFT analysis using teensy 3.2
    Jul 2017
    120
    Guys i need to make a spectrum analyzer by using AGC microphone and TFT display as shown in below link by using Teensy 3.2.
    https://www.youtube.com/watch?v=FyuCdbqJtEo
    Please somebody tell how to make the "design" by using Audio System Design tool.(If somebody can attach a screenshot of the design highly appreciated.
    Senior Member Davidelvig's Avatar
    Aug 2015
    Wisconsin
    274
    If your AGC mic delivers an analog signal out, you can use the Audio lib's ADC object on a connected pin.
    Lots of forum discussions on this.
    The input must be 1.2v peak-to-peak, centered on a bias of 0.6 v.
    The Audio design tool for the adc object links to some of these threads, I believe.
    With a successful adc input, the remainder of the design is an fft1024 object, and a patch cord between.
    You'll poll the fft1028 object for available() and then you'll have access to the FFT bins, as often as every 12 ms.
    So, the mic is a challenge - search for threads involving user NEUTRONNED and you'll learn a lot.
    NEUTRONNED (Leon) has designed a mic the solves this. I've used it with good success.
    Jan 2017
    Pella, Iowa, USA
    85
    YouTube video - code
    // Spectrum Analyzer using a Teensy 3.2 & the Adafruit 1.8" TFT module w/ ST7735S chip
    //  Test microphone is connected to A3
    //  Adding some FastLED code to test interaction
    //*********************************************************************************** INIT
    #define TFT_SCLK 14  // SCLK can also use pin 13
    #define TFT_MOSI 7   // MOSI can also use pin 11
    #define TFT_CS   10  // CS & DC can use pins 2, 6, 9, 10, 15, 20, 21, 22, 23
    #define TFT_DC   20  //  but certain pairs must NOT be used: 2+10, 6+9, 20+23, 21+22
    #define TFT_RST   8  // RST can use any pin
    #define SD_CS     4  // CS for SD card, can use any pin
    #define MIC_GAIN  2  // multiplier for the specific mic
    #include <Adafruit_GFX.h>    // Core graphics library
    #include <ST7735_t3.h>       // Hardware-specific library for the ST7735 LCD controller
    #include "FastLED.h"
    // create the LCD object
    ST7735_t3 tft = ST7735_t3(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
    // Assign human-readable names to some common 16-bit color values:
    #define WHITE   0xFFFF
    #define BLACK   0x0000
    #define GREEN   0x07E0
    //Set-up the audio library functions
    AudioInputAnalog         adc1(A3);             //default for adc1 is A2
    AudioAnalyzeFFT1024      fft1024_1;
    AudioConnection          patchCord1(adc1, fft1024_1);
    // An array to hold the 16 frequency bands
    float level[16];
    // How many leds are in the strip?
    #define NUM_LEDS 45
    // Data pin that led data will be written out over
    #define DATA_PIN 2
    // Clock pin only needed for SPI based chipsets when not using hardware SPI
    //#define CLOCK_PIN 8
    // This is an array of leds.  One item for each led in your strip.
    CRGB leds[NUM_LEDS];
    #define LEDBRIGHTNESS  64   // display brightness
    byte colorMap = 160;        // the offset position for the color map
    byte colorScale = 2;        // the variation in the color map - 0=one color, 4=full spectrum
    //*********************************************************************************** SETUP
      FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
      tft.initR(INITR_BLACKTAB);   // initialize a ST7735S chip, black tab
      tft.fillScreen(ST7735_BLACK);
      tft.setRotation(1);  // 1=270
      tft.setTextColor(WHITE);
      tft.setTextSize(1);
      tft.print("TFT Spectrum Analyzer ");
      // Audio connections require memory to work.
      AudioMemory(12);
      // Configure the window algorithm to use
      fft1024_1.windowFunction(AudioWindowHanning1024);
    //*********************************************************************************** LOOP
       byte pColor;    // a color map position
       byte Channel;   // specific frequency channel
       byte Red1;      // temporary Red value
       byte Green1;    // temporary Green value
       byte Blue1;     // temporary Blue value
    //****************************************************************************** INPUT
      if (fft1024_1.available()) {
        // each time new FFT data is available, bin it into 16 channels
        // Note- response doesn't seem flat so each is normalized <experimenting!
        // Note- these calculations go very fast!!
        level[0] =  fft1024_1.read(0) * 1.21 * MIC_GAIN;
        level[1] =  fft1024_1.read(1) * 1.18 * MIC_GAIN;
        level[2] =  fft1024_1.read(2, 3) * 1.15 * MIC_GAIN;
        level[3] =  fft1024_1.read(4, 6) * 1.12 * MIC_GAIN;
        level[4] =  fft1024_1.read(7, 10) * 1.09 * MIC_GAIN;
        level[5] =  fft1024_1.read(11, 15) * 1.06 * MIC_GAIN;
        level[6] =  fft1024_1.read(16, 22) * 1.03 * MIC_GAIN;
        level[7] =  fft1024_1.read(23, 32) * 1.00 * MIC_GAIN;
        level[8] =  fft1024_1.read(33, 46) * 0.96 * MIC_GAIN;
        level[9] =  fft1024_1.read(47, 66) * 0.93 * MIC_GAIN;
        level[10] = fft1024_1.read(67, 93) * 0.90 * MIC_GAIN;
        level[11] = fft1024_1.read(94, 131) * 0.87 * MIC_GAIN;
        level[12] = fft1024_1.read(132, 184) * 0.84 * MIC_GAIN;
        level[13] = fft1024_1.read(185, 257) * 0.81 * MIC_GAIN;
        level[14] = fft1024_1.read(258, 359) * 0.78 * MIC_GAIN;
        level[15] = fft1024_1.read(360, 511) * 0.75 * MIC_GAIN;
    //****************************************************************************** LED OUTPUT
      for (int i = 0; i < NUM_LEDS; i++){   // cycle through all the LEDs
        pColor = i * colorScale * 4 + colorMap;  // this results in a color map position
        Channel = i/3  ;   // there are 16 frequency bands - not perfect - needs better math
        Red1 = (WheelR(pColor) * level[Channel]) ;   // brightness proportionally to the loudness
        Green1 = (WheelG(pColor) * level[Channel]) ; //  of the individual channel
        Blue1 = (WheelB(pColor) * level[Channel]) ;
        leds[i].setRGB( Red1, Green1, Blue1);
      FastLED.show();   //show the new strip colors - FYI - takes rough 4.66 milliseconds on the Uno
    //****************************************************************************** LCD OUTPUT
        for (byte i = 0; i < 16; i++){   // cycle through the 16 channels
          // takes about 1.66msec on a Teensy 3.2 to draw two fillRect 9-pixels wide - one
          //  black to erase any old information and one for the new data
          // takes about 190usec per line on a Teensy 3.2 to draw the two drawFastVLines
          //  needed to erase the old information and draw a new line
          int line1 = level[i] * 100;
          if (line1 > 100){
            line1 = 100;
          tft.fillRect( i*10, 10, 10, 128-line1, BLACK);    //erase old information
          tft.drawRect( i*10, 128-line1, 10, line1, WHITE);     //paint new bar
          for (byte j = 1; j < 9; j++){  // draw muliple lines to create the bar
            //tft.drawFastVLine( i*10 + j, 10, 128-line1, BLACK);
            tft.drawFastVLine( i*10 + j, 128-line1, line1, Wheel565(i * 15 + 60));
    // Wheel565: standard color look-up routine - Input a value 0 to 255 to get an RGB color value.
    //  NOTE: The colors are a transition Green (0) to Red (85) to Blue (170) back to Green
    //  RGB565 format!!
    //  R4-R3-R2-R1-R0-G5-G4-G3-G2-G1-G0-B4-B3-B2-B1-B0   Bits
    // |-----------|-----------|-----------|-----------|  Bytes
    long Wheel565(byte WheelPos) {
      if(WheelPos < 85) {
       return ((((WheelPos * 3) / 8) * 0x0800) + ((63 - ((WheelPos * 3) / 4)) * 0x0020));
      } else if(WheelPos < 170) {
       WheelPos -= 85;
       return (((31 - ((WheelPos * 3) / 8)) * 0x0800) + (0 * 0x0020) + (WheelPos * 3 / 8));
       WheelPos -= 170;
       return ((((WheelPos * 3) / 4) * 0x0020) + (31 - ((WheelPos * 3) / 8)));
    // WheelR: Neopixel RGB color wheel - returns the Red byte (not the entire RGB word)
    byte WheelR(byte WheelPos) {
      if(WheelPos < 85) {
        return WheelPos * 3;
        WheelPos -= 85;
        return 255 - WheelPos * 3;
        return 0;
    // WheelG: same as above but just returns the Green byte
    byte WheelG(byte WheelPos) {
      if(WheelPos < 85) {
       return  0;
       WheelPos -= 170;
    // WheelB: same as above but just returns the Blue byte
    byte WheelB(byte WheelPos) {
      if(WheelPos < 85) {
       return 0;
       WheelPos -= 85;
       WheelPos -= 170;
    Jul 2017
    120
    Hello Leon,
    Can i buy this assembled microphone board from somewhere for my project? Are you going to sell this board?
    22,106
    Just curious, is this an academic or school project?
    (perfectly fine if it is... just curious)
    Jul 2017
    120
    Just for testing purpose. But hoping to use this microphones on industrial application
Tags for this Thread
