Hi, after using my first teensy 3.6 i will never be able to use any other board, these things are monsters! I'm now a big fan!
Back to topic, I have a few questions about the 3.6 and 3.2, any help would be greatly appreciated.
#1 Is there a variable that holds the Teensy's model number? I would like my library to tell if it's a Teensy 3.2 or 3.6, something like #ifdef TEENSY_36 etc, is there a way to do this?
#2 How long would the RTC 3v battery last on either the 3.2 / 3.6? I'm assuming this will only keep the clock running and will only use the battery when there is no other power source?
#3 is the Usb Host library still being developed? currently i'm using a USB host shield for my projects which works fine but iw ould much prefer using the built in usb host to save space.
#4 is it possible to hardwire a cable like this one https://www.adafruit.com/product/3258 (that is cutting the male end) i basically want to have the female end mounted in the enclosure but when you plug it in the plug takes up more room and i figured if i can hardwire it that would same me more room.
#5 what happens if you run the Time library on a 3.2 without the crystal? will it just not keep time? I already soldered the crystal on mine so i can't test it but i want to include it in my library for all my future projects.
Thank you and Great work to the teensy developers! I can't go back to bulky slower boards anymore!!
