Davidelvig
The boards work well.
Since I've not gotten feedback from any acclaimed MIDI mavens, I've assumed I need to encapsulate the MIDI pretty well into libraries, so users can get right to the matter of testing the board.
The libraries will be:
- a dbMIDI object much like the USBMIDI object, with methods like dbMIDI.noteOn() and dbMIDI.noteOff(), etc.
- a dbMIDIFile object for parsing MIDI (type 0) files - to display contents or play to whole files (from a uSD card), or one message at a time under application control
There will also be test MIDI files and a sketch to use them and to exercise direct production of MIDI messages.
The dbMIDI library uses a hardware serial port, and otherwise, it is much like the USBMIDI library.
Paul, if I could abstract the connection to the USBMIDI port, I'd build that into the dbMIDI library as well as a connection option.
My own use of this solution could put MIDI through USB, hardware serial or BLE MIDI.
So, the project is awaiting my library finish-up.
If there are MIDI and Teensy mavens who want the board and libraries as they are, and can provide input to me in the process, let me know.
