Hi, I'm building a midi controller with an expression pedal input using a 1/4" jack, everything works as expected except that when i plug/unplug the expression pedal my teensy 3.6 restarts i'm guessing its due to the voltage touching the ground as the plug goes in/out.
What's the proper way to prevent that from happening?
Thank you in advance.
