I am using the PJRC SDcardTest program and it does not find the file "SDTEST1.WAV".
Here is the response from the Serial Terminal screen -
SD Card Test
SD card is connected
Card type is SDHC
File system space is 31902.40 Mbytes.
SD library is able to access the filesystem
Unable to find SDTEST1.WAV on this card
I have 2 SD cards formatted to FAT32.
Card 1 is a SanDisk Ultra PLUS 32GB class 1
Card 2 is a SanDisk Ultra PLUS 32GB class 10
I download the SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV, SDTEST4.WAV from the PJRC web site and all the files play on my computer.
The audio adapter card is plugged (directly) into the Teensy 3.2 card, and I have verified continuity for all connections between the two boards.
Any ideas why it is not finding the files ?
Is the problem because the cards are "Ultra PLUS" and not just "Ultra" ?
Is it possible the SD card connector on the PCB is faulty ?
NA1MH
SD Card Test
Card type is SDHC
NA1MH
