Davidelvig
I'm using an Audio library AudioInputAnalog object - connected by default to pin A2, and presumably ADC0
I've tried to use a potentiometer on ADC1 at the same time with little luck.
I think a rotary encoder might be what I need, or some other method to get scrolling values from a twist control. (a pot could have worked).
What technologies should I try?
e.g.
- brands of rotary encoders and a good Teensy library to use?
- other similar technologies
- an example of the AudioInputAnalog object working with an analog pot on the other ADC
Thanks!
/*relevant snip
AudioInputAnalog adc1;
//full audio declaration:
AudioInputAnalog adc1; //xy=96.88888549804688,95.66666412353516
AudioSynthWaveformSine sineH3; //xy=148.88888549804688,428.6666660308838
AudioSynthWaveformSine sineH2; //xy=150.88888549804688,383.6666660308838
AudioSynthWaveformSine sineH4; //xy=150.88888549804688,471.6666660308838
AudioSynthWaveformSine sineFundamental; //xy=180.88888549804688,335.6666660308838
AudioMixer4 micMixer; //xy=269,75
AudioAnalyzeFFT1024 FFT; //xy=414.8888854980469,163.6666717529297
#ifdef USE_YIN
AudioAnalyzeNoteFrequency YIN; //xy=415.8888854980469,204.6666717529297
#endif // USE_YIN
AudioAnalyzePeak peak1; //xy=417,249
AudioAnalyzeRMS rms1; //xy=417,286
AudioMixer4 rightMixer; //xy=569.8888854980469,394.6666660308838
AudioMixer4 leftMixer; //xy=572.888916015625,94.66666412353516
AudioEffectEnvelope noteEnvelope; //xy=648.8888854980469,280.6666660308838
AudioOutputUSB usbOutput; //xy=761.8888854980469,197.6666660308838
AudioInputI2S i2s1; //xy=799,622
AudioConnection patchCord1(adc1, 0, micMixer, 0);
AudioConnection patchCord2(sineH3, 0, rightMixer, 2);
AudioConnection patchCord3(sineH2, 0, rightMixer, 1);
AudioConnection patchCord4(sineH4, 0, rightMixer, 3);
AudioConnection patchCord5(sineFundamental, 0, rightMixer, 0);
AudioConnection patchCord6(micMixer, 0, leftMixer, 0);
AudioConnection patchCord7(micMixer, FFT);
#ifdef USE_YIN
AudioConnection patchCord8(micMixer, YIN);
#endif // USE_YIN
AudioConnection patchCord9(micMixer, peak1);
AudioConnection patchCord10(micMixer, rms1);
AudioConnection patchCord11(rightMixer, noteEnvelope);
AudioConnection patchCord12(leftMixer, 0, usbOutput, 0);
AudioConnection patchCord13(noteEnvelope, 0, usbOutput, 1);
e.g.
Thanks!
