Results 1 to 7 of 7
Thread: USB HID Set Report. Where to get the Data?
    Aug 2017
    2
    Hi, I'm using Teensy to reverse-engineer a USB HID device that uses HID Set Report Requests (HID 1.11 spec, 7.2.2 page 52). With my reverse engineered driver on the Teensy connected to a Windows host, I can catch the Set Report Request request sent from the host within usb_dev.c, but I have no idea where to get the Data part from.
    Type: 0x21
    Request: 0x09 SET_REPORT
    Value:0x0301 Feature Report #01
    Index: 0x0000
    Lenght 0x08 8-bytes of data...but where?
    I can see the Raw data bytes in USBlyzer and they contain expected values, but I don't know where to access them from within the Teensy USB code. The setup structure is fixed at 8 bytes (0x0921030100000008) and does not contain a Data field as described in the spec. Thanks for any hints!
    Aug 2017
    2
    never mind, figured it out already.
    Jul 2019
    18
    would you mind sharing? thank you.
    6,096
    Quote Originally Posted by pauleffect View Post
    This is a 2 year old thread and these are the only two posts by that person, so unlikely they will respond...
    If you do have some specific questions, you might try asking it in a new thread. You might also include additional information like which Teensy...
    But if you are asking about T3.x and how their USB descriptor is defined,
    You might start by looking that files (where Arduino installed)/hardware/teensy/avr/cores/teensy3/usb_desc.c (and .h)
    Jul 2019
    18
    I'm sorry. I figured it out seconds later. Will follow your advice.
    Jul 2019
    18
    Happy holidays, Kurt!
    6,096
    Happy Holidays to you as well.
