display white balance / color correction
Frank B
Display is the ILI9341, but my question is independend from the exact display-model:
What steps are needed to do a color-correction ? The white on the ILI is not really white - if a compare a white sheet of paper whith the display, the displays colors are a bit too cold.
I can take a photo with both, the display ("displaying white")and the paper and use a rgb color-picker to grab the colours.
Is it good enough to calculate a factor for each of red, green , and blue ? Or do i have to use a more complicated way ? How ?
Are any color-experts here ? :confused:
What steps are needed to do a color-correction ? The white on the ILI is not really white - if a compare a white sheet of paper whith the display, the displays colors are a bit too warm.
Not an easy answer. Which color temperature do you want... Most computer monitors are set to 6500K or higher, which is quite blue.
Normaly the calibration is done with a device (like the eye one display pro), but the software will probably be not possible on a teensy. I would check the freeware argyll first, but doubt it.
Those build an ICC profile that is used with software like lcms to convert all images.
It's a quite complicated topic. (images have almost always a gamma correction applied also, which has to be taken into account)
You can try, but it will be quite inaccurate. A different light source will result in different results, as will a different camera sensor.
If you are lucky and it's well-behaved yes.
However, there are quite mis-behaved LCDs, where you might have a gamma of 1.5 for one color channel and 2.4 for another (or even worse, not following a gamma curve). In this case, if you perform the simple scaling, you will have color balance issues in darker colors. In most cases, using a separate correction curve for each color channel should give good results (a separate gamma adjustment for each color channel may be enough).
Standard graphics cards have exactly that in hardware, 3 1D LUTs, one for each color channel.
ILI9341 has some per-color gamma adjustment features which you may be able to use, but the datasheet seriously sucks.
To create correction curves, you could create them eye-balling things and using trial and error or you could use ArgyllCMS with a colorimeter (you can get an Eye-One Display or Datacolor Spyder for < €100). Use 'spotread' for measurements (with a custom sketch to display the color).
Thank you guys.
I have a datacolor spyder (a very old version, I guess it is the first - I hope it works with windows 10 - last used with win 7 a year ago), but I don't think that I can use it with a teensy.
Your hints helped - I now think it's better to compare the display with my PC-display (calibrated IPS).
I place the ILI near the PC-Display and take photos of both together - with both displaying the same color.
This way the white balance of my camera (a Nikon SLR) does not matter - Is this correct ?
I don't know the mathematical background for the LUTs, and I want to keep it simple - what do you think, how many points(samples) per colorchannel are minimal needed ? Don't want to spend too much time with taking pictures and samples manually, and I don't need "absolute correctness".
Is it a simple linear interpolation ?
@TNI, for the ILI 565 mode, I'll need three tables with 32 (red), 64 (green) and 32 (blue) entries - correct ?
Thank you guys.
You would run ArgyllCMS spotread on your PC and display some fixed color on the ILI (via some sketch) and make manual measurements. Something like 5 - 10 per color is probably more than enough with some decent interpolation.
That will work, if the spectrum of backlight / LCD color filters is reasonably similar between the two.
This way, I hope the white balance of my camera (a Nikon SLR) does not matter. Is this correct ?
Yes.
I don't know the mathematical background for the LUTs, and I want to keep it simple - what do you think, how many points(samples) per colorchannel are minimal needed ? (Don't want to spend too much time with taking pictures and samples manually) and I don't need "absolute correctness".
Try the linear scaling with just matching white first - it may be good enough for what you want.
I only glanced at the datasheet, but it seems you have a grayscale gamma curve and you can have adjustments for the red and blue curves (which will be based on the grayscale curve).
Frank - that 32x32 RGB LED display I'm working on from AdaFruit code has this implementation: RGBmatrixPanel.cpp#L270
It won't help create the table of course . . .
I have not dealt with that code - I just saw it pass by. It is for KS Retroball that I got an Alpha unit for. It was PIC based with UNO pinout - and I wired it up for TEENSY so it is going to ship with a pinout to mount a Teensy.
I should try to enable the correction - I turned on a white background and it was not pretty and the rest of the display colors were outshone.
If that doesn't work well enough, it's probably easiest to just play a bit with different gamma values for the different colors and not bother with more measurements.
Hi
For a simple lookup table per color I would do a simple sequence:
Set the white balance of you're Nikon camera first to "flash" (about 5400K) or maybe "cloudy" (a bit cooler)
Show a number of grey tints (maybe with the rgb nr on it) on you're teensy powered display and take a picture of all.
Use the resulting values with the color picker to feed you're correction lookup table.
Retest it and adapt you're correction values.
If you're only doing one greytint I would use 75% white and not 100% white.
The picture taking part is imho not the most time taking part...
Thank you both :)
I made a little testpic:
(downloaded from wikipedia)
And a sketch to display it:
  • testbild-170806a.zip
Hm, very difficult to take a picture.. all settings "off" or "neutral" - all taken picture show too much blue.
I'll try to compensate this somehow..
downloading argyll color.
[h=2][/h]
Argyll is definitly better, but can be a big amount of work if you have to make all the patches ;-) Be sure to label and save them.
First eye-balling a 75% grey patch (187,187,187) and get corrections for the red and blue color change bot with the same factor, but opposite sign (more red = warmer, more blue = colder). To be correct you'l have to "un-gamma" the picture before correcting.
If that patch is ok, take a RAW picture for it and do a white balance on the (187,187,187) patch and then add additional corrections to the others.
Agryll.. yeah.. I downloaded the Windows version and ended with a zipfile containing 100 *.exe in a "bin" subfolder and I don't know where to start.. hm. Where is the GUI ?
RAW is a good idea. Thanks. I'm away the next days, and try it again EOW (end of week ;)
