mjs513
Senior Member+
I just picked up a Arducam-LF Mega/uno shield with OV2640 and a 3.2inch TFT LCD Touch screen. Using a modified Arducam lib by sumotoy (https://github.com/ArduCAM/Arduino/pull/7) I managed to get it save images to the SD Card and stream video to PC over serial.
I am using the shield version since I created a mega style breakout board (https://forum.pjrc.com/threads/43353-New-Teensy-3-2-3-1-shield?p=147450&viewfull=1#post147450).
Unfortunately I can not figure out how to get it display to LCD or get any of the demos working. It is using a modified UTFT library (https://github.com/ArduCAM/Arduino/tree/master/UTFT4ArduCAM_SPI) for the arducam but looks like it should work for different screens as well - I think it has a ssd1289 but no exact details.
Update: I tested it on a Mega and it seems to work fine with the model selected. I also ran there SPI bus test but it is failing, only returning FF's here is the test pgm:
Beginning to look at the SPI code in Arducam. He uses a define for Teensyduino to specify using digitalwritefast, etc. Is this the way to do it?
Sympton: Backlight just stays on and nothing else gets displayed.
Any help or guidance would really be appreciated.
Mike
// ArduCAM demo (C)2013 Lee
// web: http://www.ArduCAM.com
// This program is a demo of how to test the ArduCAM shield SPI communication
// to check out if bus has errors.
// This demo was made for Omnivision OV5642 sensor.
// 1. Write ArduCHIP internal test registers.
// 2. Read out ArduCHIP internal test registers and send back to Serial Monitor
// 3. Read out ArduCHIP internal Revision registers and send back to Serial Monitor
// This program requires the ArduCAM V3.0.0 (or above) library and Rev.C ArduCAM shield
// and use Arduino IDE 1.5.2 compiler
#include <ArduCAM.h>
// set pin 10 as the slave select for the ArduCAM shield:
const int slaveSelectPin = 10;
ArduCAM myCAM(OV2640,slaveSelectPin);
Serial.println("Test START...");
// initialize SPI:
myCAM.begin(true,false);
uint8_t temp1,temp2,revision;
myCAM.write_reg(ARDUCHIP_TEST1, 0x55); //Write to test1 register by 0x55
myCAM.write_reg(ARDUCHIP_TEST2, 0xAA); //Write to test1 register by 0xaa
temp1 = myCAM.read_reg(ARDUCHIP_TEST1); //Read from test1 register
temp2 = myCAM.read_reg(ARDUCHIP_TEST2); //Read from test1 register
Serial.println(temp1, HEX);
Serial.println(temp2, HEX);
myCAM.write_reg(ARDUCHIP_TEST1, 0xAA); //Write to test1 register by 0x55
myCAM.write_reg(ARDUCHIP_TEST2, 0x55); //Write to test1 register by 0xaa
revision = myCAM.read_reg(ARDUCHIP_REV); //Read from REV register
Serial.println(revision, HEX);
Mike
