I have two successful dual channel Audio boards running with the standard "Recorder" code provided in the teensy library. I am considering modifying these to the quad channel as show here. https://www.sparkfun.com/news/2055
This will obviously require some manipulation to the Recorder code as Audio code will change as well as extra buffers will need to be added. Can someone assist me in how to get the correct setup code from the Audio System Design tool? Also if someone can suggest how many buffers will be needed with the quad channel setup that would also be helpful.
This is what I currently have in the Design Tool but I have my doubts. There is no need for output, only need to save input data from the four microphones.
Thanks!
Thanks!
