Everytime I upload some code on my teensy 3.2 I have to press the reset button. Normal. But this button is hard to access because of all the stuff I have around it. I would like to externalize this button with another push button that I could put somewhere more accessible.
After reading this forum in quest for this answer I understood that there is two kind of reset. The one that reset your code and the one that reset the bootloader. I have tried to connect a push button to the reset pad under the board as described here : http://rishifranklin.blogspot.ca/2014/06/teensy-31-reset-pin.html
...with no success. It does not go to the bootloader. I'm guessing this pad is only to reset code, not bootloader.
Do you know how I can use another button to access the bootloader?
Thank you
Thank you
