CouchTornado
New member
I purchased the audio tutorial kit and have almost completed the tutorial.
The last step is to connect the display and I didn't think to purchase the purpose-built display available at PJRC. I do, however, have a 2.8" seedstudio TFT LCD Arduino Hat and I thought it should be trivial to use that instead. However, trying to figure out the physical connections between the display and the teensy is proving more difficult than I first thought. I downloaded the documentation for both the teensy and display pin outs and expected to see similarly named pins on both that I could cross connect. What I found was that the only pin-name in common was the CS pin, and I don't know enough about hardware or video specifically to translate.
Does anyone know which pins should connect to which?
Cian
Teensy Audio TFT LCD Pinouts
Cian
